(#1576)
bradsm87 bradsm87 is offline
Car: E90 LCI 335i
Default 10-12-2015, 03:14 AM
Originally Posted by Bullitt1841
What is the purpose of not clearing all other modules after a map write? I now have to manually clear these modules and their codes every time I change maps.
Now the overall process is much, much longer than the original time, not 10 seconds faster.
Agreed.
Martial, would you consider making this an option. I don't mind the shadow faults but it's annoying clearing the errors on the i-drive screen every time.
jwdominick's Avatar
jwdominick jwdominick is offline
Car: 08 535ix
Default 10-12-2015, 06:49 AM
havent seen it posted anywhere in this thread but I may have missed it. For those of us using the n20 tmap does the mhd allow for that signal without the jb4? additionally, what are the boost ranges of the built in stand alone mhd maps?
'08 535xi 6m, ACT 6 Puck Race Clutch / AR Design DP's / AFE Twin Power DCI / VTT Inlets / VRSF CP / TIAL BOV / Big Tom style IC / Fuel-It Stg2 LPFP / NGK 5992's @.022 / N20 T-Map / MHD Flash....100% e85 @24psi on stock snails!
Russjonesr's Avatar
Car: Bmw e92 335i
Default 10-12-2015, 07:23 AM
http://www.e90post.com/forums/showth...096247&page=39
Looks like anything over 22.5psi a JB4 is still required.
Duperstar Duperstar is offline
Car: 2009 535i xdrive
Default 10-12-2015, 08:38 AM
Originally Posted by Blind35
hello
i have FBO and !!!JB4 G4!!!
can i flashing PUMP MAP?
or it's map only for JB4 G5 ISO???
G5 ISO only for backend flashes
2009 535xi - JB4 G5 ISO -BMS Race Flash- BMS Intake - ER CP- Forge DVs- Active Autowerke intercooler- Gone
Activehybrid 3 - JB4 EWG/OBD- CTS Turbo Intake- VRSF CP- Bavsound Stage 1- current
HunterR HunterR is offline
Car: 07 335i
Default 10-12-2015, 10:01 AM
Sacked up and just bought a $50 laptop at walmart, flash went as planned. Works great!
jwdominick's Avatar
Car: 08 535ix
Default 10-12-2015, 11:02 AM
darn! thanks for the link
iWorkTooMuch iWorkTooMuch is offline
Car: 2009 E90 335i
Default 10-12-2015, 05:34 PM
I'm sitting in my 09 335i going through the directions step by step, I have updated the JB4 software and am ready to apply a MHD /JB4 backend flash but when I open the JB4 app and look under "read only" it does not show me the type I will need. It is only displaying ( Baro Pressure, Firmware Version, Interface Version, AVg Ign Retard, Future Use F )
Would someone please let me know what I am doing wrong?
-Justin
500hp500tq 500hp500tq is offline
Default Does BT Cable work with MDH - 10-12-2015, 06:07 PM
Does BT Cable work with MDH?
|2008 135i N54 | VRSF FBO| Motiv Port Injection | BMS PI Controller| AD-E ST Kit 6062 | JB4 G5 ISO 13.0 | BMS ST/MHD E85 Flash | 60% e70 | Fuel-It Stage3 LPFP | Spec2+/SMFW |3.5 TMAP | NLS
"stock"
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 10-13-2015, 06:04 AM
No. You need the Dcan and USBOTG
UK FBO 335i, ̶V̶T̶T̶ ̶G̶C̶s̶ China 19T, JB4, PI meth, BMS CP, OCC, Braided brake lines. Diff Lockdown. TMAP sensor, custom bucketless stage2
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 10-13-2015, 10:50 AM
Or MaxBoost from Wedge
Izero Izero is offline
Car: 2008 E90 335 xi
Default 10-13-2015, 01:58 PM
Are there any suggest Tablets for the MHD flasher?
What has everyone seen the best results with? I'm having trouble finding information all in one place... and I'm not sure if I should just do a JB4 back end flash and spend the $200 for the BT Cable or if I should spend my money on the MHD flasher....?
It's been difficult reading through 57-ish pages of this thread... so just curious if there is a beginner guide to get started with this....?
Car: 2013 Genesis Coupe
Default 10-13-2015, 03:17 PM
What does map 7 target with MHD flash now? I keep getting kicked to map 4 and looks like I'm hitting 20 psi or so
Car: 2010 535i
Default 10-13-2015, 03:44 PM
This is the tablet a lot of us were buying when the flash came out. It is sold out now, but there are some used ones available which would be just fine, save a few bucks even.
http://www.amazon.com/gp/aw/d/B00MYG...roduct_details
I use it for MHD flasher and with the JB4 mobile app for gauges and logging and it is plenty to do those things. Any android tablet with OTG usb capability should work though. This one was nice because it was $40 and came with an OTG cable.
I also bought this USB power cable to keep it charged while using th OTG port.
http://www.amazon.com/gp/aw/d/B00IPE...s=dc+2.5mm+usb
Dirty Dog's Avatar
Default 10-13-2015, 04:03 PM
My map 7 is also targeting 20psi recently. It use to target 18.5psi. Mine isn't kicking me to map 4 though.
PLF's Avatar
PLF PLF is offline
Default 10-13-2015, 04:21 PM
I have noticed that when I change my max boost threshold (ex: 19, 20 or 21psi) then my Map 7 target changes accordingly to (ex: 17.5, 18.5 and 19.5)
Default 10-13-2015, 04:23 PM
Where do you change that at?
Default 10-13-2015, 04:24 PM
What is your fail safe set at? Are you running the n20 tmap sensor?
Default 10-13-2015, 04:27 PM
My sister gave me her old Galaxy s3 and that works very well. MHD is worth it, I literally just switched 2 days ago from BB and it fixed a slow spool issue I was having. I also get 3 more mpg on the same trip.
Dirty Dog's Avatar
Default 10-13-2015, 06:23 PM
Failsafe is set to 21psi. Stock tmap sensor.
Default 10-14-2015, 06:51 AM
Would this one work? Or does it have to have kit*** 4.4?
http://www.amazon.com/gp/aw/d/B00VO1...nfL&ref=plSrch
I'm very new to this MHD thing but I need something that will fix my timing problems on the JB4... And I'm having trouble finding how-to's and FAQs for it that don't contradict each other or don't make sense (yet)
Default 10-14-2015, 01:04 PM
Makes sense why you're not going into map4. Just didn't realize map 7 targets boost that high???
rmj335i rmj335i is offline
Car: e90 335i 2009
Default 10-14-2015, 05:37 PM
Has anyone used VMWare and Android to run MHD Flasher? I previously did but now i am having issues where the application will not open.
Car: 2010 535i
Default 10-14-2015, 06:10 PM
Yeah it should work, I couldn't tell from the description of it comes with the OTG adapter or not.
Bullitt1841's Avatar
Default 10-15-2015, 12:05 AM
If we send someone our stock bin by selecting 'back up the ECU,' then they tweak it for us, do we load it by choosing 'flash a custom map' or 'flash a JB4 backend?'
Vehicle info: ECU already has BMS JB4 backend loaded, along with JB4 still physically installed.
dorci's Avatar
dorci dorci is offline
Car: 135i 09'
Default 10-15-2015, 05:36 AM
Hello,
I flashed my car with the mhd flasher, the ijeos mhd backendflash e85. My car won't start. I was to map 0. I tried Different map.
Tested my own .Bin and modifying it with the xdf in tunerpro. Never starting..
I'm desesperat. Maybe I need to unplug the jb4 and flash the
Ecu directly. Let me know backendflash don t need to be modified normally ?
