Car: 2007 335i sport package jb4 g5 iso BMS DCI
10-31-2015, 12:59 PM
Only problem now is that gas is going empty and full like crazy anytime i press gas pedal!!![/QUOTE]
Sounds like gage hijacking.
http://www.n54tech.com/flash_files/jb4_wheel_1.jpg
2007 E92 335i sport package 6mt jb4 g5 iso Fw 31.8
BMS 7/1 pump flash, DCI, OCC, clutch valve,
VRSF dp, 7.5 IC, Inlets, CP, tial bov.
12 & 15 mm Wheel spacers, Lux V5.
Car: 2008 335i
10-31-2015, 03:28 PM
That will do the trick!!!
I'll let u know when done...
2008 335i A/T, JB4 G5, CPE DP's, BMS DCI, BMS CP WITH TIAL BOV, MAGNAFLOW EHXAUST...😈😈😈
Car: 2009 135i Coupe
10-31-2015, 05:27 PM
Tried 31.8 with menu 11 at 5000 and menu 12 at 2k5. Jerkiness on light throttle is gone, everything seems cool.
11-01-2015, 11:57 PM
Does anybody have the Stock Flash JB4 default settings they can post? The screenshot has been removed from all stickies that I can find
11-02-2015, 08:36 AM
It's in the 3rd post.
11-02-2015, 06:19 PM
Understood.
For clarification for anybody else, there are now only one set of AFR Bias values for stock or backend flashes.
11-02-2015, 09:57 PM
I was wondering if anyone could chime in on if this is fine to run for the winter.
I have a jb4 and run it in map 5 and mode 42 with the mhd backend pump flash. For winter I'm planning on running map 0 on the jb4 because with all the snow we get I have no need for the extra power. Will everything run fine if I leave the mhd pump flash with jb4 set to map 0 with option 4 2 enabled?
Thanks.
11-02-2015, 10:00 PM
Use map4 for stock performance on ISO firmware.
11-02-2015, 11:07 PM
Thanks terry.
should I leave option 4 2 enabled?
Car: 2008 335i
11-03-2015, 05:18 AM
Thanks everyone for the support, car's just running fine with no codes or errors for now!!!
11-03-2015, 08:37 AM
Originally Posted by Dcara
Thanks terry.
If you have our back end flash map loaded, yes you leave it on 4/2.
11-04-2015, 04:30 PM
Originally Posted by dawhiz
5) If using a 3.5bar TMAP sensor you need to set "N20 TMAP" to 1 after installing it, and also realize your FF/duty bias values will be approx 20% lower than they were with the 2.5bar factory sensor. An easy way to offset this is by setting your duty bias to 65 across the board instead of 50 (or 0) across the board to rerange the FF parameter.
Does this apply to if we have a backend flash (since 0 is mentioned)? Should we have the duty bias set to 0 if backend flash & 3.5 or should we adjust it to 65 (assuming 15 would then be the same in this sense?)
this is from post 9944......any more info on this? it seemed to have been skipped over and forgotton about lol
Setting all duty bias tuning rpm fields to 50 would essentially disable it (like when I had it set to 0 before) regardless of what fud is set to, right?
Current: 2008 e92 335i coupe.
Car: 335i e90
11-05-2015, 10:06 AM
Terry, curious if you could update the interface to allow steering wheel control past 10, blew out my clockspring and until I get a new one I can't adjust settings in menu 12 form the laptop. Any options?
Car: 2007 BMW 335i
Which jb4 do I have? -
11-05-2015, 01:41 PM
I have a jb4 with two boxes. Is this G4 and what firmware would I need. Also do I need the other box once I upgrade to G5?
Car: 2007 BMW 335i
Other box -
11-05-2015, 01:42 PM
What's this for?
Car: 135i 09'
11-07-2015, 05:30 AM
Hello, the last update 31_8 affect the 2step during the procédure.
The rpm increase and decrease and never stay to my rpm settings.
It is Just me or it's due to the New firmware ?
Car: 2008 Sapphire black 135i
11-07-2015, 09:41 AM
Did you read the firmware release notes at all?
Check note 5...
5) Change to the 2STEP logic to improve fueling coming out of a 2TEP. The changes may also effect the 2STEP RPM targeting. Needs testing.
... I've noticed the same thing and I think Terry is working on it :-)
'08 135i 6-Speed... BMS Pump Flash, BMS JB4 G5, BMS 3" ***, BMS OCC, RB PCV, VRSF 5" Stepped FMIC, aFe DCI, Racewerks Charge Pipe w/ TiAL Q BOV, Modified Berk Exhaust
11-07-2015, 02:12 PM
The 2STEP targeting isn't perfect, but works as well or better than previously.
Car: 135i 09'
11-07-2015, 11:59 PM
Check note 5...
Yup I read it but don't work really.
The antilag works very well.
Terry do you think it s dangerous to got 19 psi with cats ? I use sp98 and 70% e85
Car: 07 335i
11-09-2015, 07:10 PM
Will this not work on a 32bit system? I'm having trouble installing on winxp 32bit.
2015 FBO 550i msport(Daily)
2007 e92 MT single turbo 335i
11-09-2015, 07:38 PM
No known issues with 32bit systems.
11-09-2015, 07:39 PM
With E85 EGT is going to be much lower than it would be on petroleum, so its probably fine.
Car: 2008 535xiT
11-10-2015, 02:40 AM
Terry,
Would it be possible to have a constant on output for "engine temp ready for full boost", so to speak. I know the JB4 can flash the hazards when operating temp is reached for full boost.
The reason I ask, is it would be nice if the JB4 connect kit could display a very small indicator on the display screen of when the engine is at temp. Light a small green light or something. He can not do so unless there is an output that stays on once the engine is at temp instead of just a momentary indicator, such as flashing the hazards.....
11-10-2015, 04:52 AM
Originally Posted by Timmay77
Terry,
This would be a nice add for the 5 series guys (and anyone else whe does not have a oil temp gauge).
11-10-2015, 09:01 AM
Terry,
We could work something out with Donnie on that. What if we had it hold the JB4 in map4 when not up to temp then map switch once it is?
Velislavr
