(#76)
Chavoos's Avatar
Chavoos Chavoos is offline
Default 05-20-2015, 12:41 PM
Terry, would you please do this for your free flashes.
Have differentiated EU and US maps to make it easier for people like me who are scared to mess something up.
Thanks in advance
Alex!'s Avatar
Alex! Alex! is offline
Car: 135 I N54
Default 05-20-2015, 02:15 PM
Good thread!!!
Terry i have also probelms with the 1m. I did 3 and all of them have this code in map 3:
2f30 no description found.....
135I - 6 MT -JB4 G5 ISO Map 3 - BB Race Flash - Riss Rasing ******* DP - AFE CAIs - BMS SDL - 93 Octanes - Sistem X wather meth - SPEC 2+ - RB Twins!!
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 05-20-2015, 02:23 PM
Originally Posted by Alex!
Good thread!!!
2F30 - Charge air temperature sensor
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 05-21-2015, 12:46 AM
Originally Posted by Nordic335IM3
could someone in this tread give a clearcut answer to what the benefits are from getting a flash vs just JB4 ?
if Im FBO(europe) and using pump gas, the recommend is getting "the pump flash" from what im reading on the forums..
what will I gain from this vs just using MAP 5 on my JB4 ?...
Wrong thread. Search/post in the main "BimmerBoost N54 free flash tuning" sticky.
Thanks in advance
This has been asked several times and dealt with in this thread. Terry will not be providing an additional version so you'll need to follow the instructions here or get someone who is more confident in doing this to help you out.
2016 F22 M240i | 8ZF
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 05-21-2015, 01:33 AM
Is there anything stopping a member here doing these "EU specific bins" and uploading to this thread?
enrita's Avatar
enrita enrita is offline
Default 05-21-2015, 09:45 AM
no... i can make them for 100 millions dollars muhaha! no seriously if someone need help i can fix one up ....
07 335i AT - MOTIV 750 - MHD BMS E85 Flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
Element's Avatar
Car: BMW 135i N54
Default 05-22-2015, 02:15 AM
There is nothing stopping anyone from doing so. Whether it's a good idea to use another BIN rather than moving the defined changes to your own I guess is up for debate. That said, it should at the very least be less prone to the issues we've seen in using the US BINs.
miksebik miksebik is offline
Car: E92 335i
Default 05-22-2015, 05:15 AM
I tried to follow the instructions but after the search in the difference tool I did not find fields:
2C77
2C78
Map Max Voltage
And for the Torque Monitor Ceiling I found 14 fields, compared to 13 fields in the OP's post
What next?
E92 335i N54, Hexon RR500, JB4, DCI, MMP inlets, ER chargepipe, Turbosmart Kompact Dual Port BOV, ATM IC, Wagner downp*pes, MPerformance exhaust, oil cooler, trebila flash (via MHD Flasher), E60, M Performance 370mm brakes, styling 313 wheels, M Performance suspension, Fuelit Stage2, MFactory LSD, MFactory SMWF
Element's Avatar
Car: BMW 135i N54
Default 05-22-2015, 05:38 AM
2C77
2C78
Map Max Voltage
What next?
Search for the item title, not the address
Car: E92 335i
Default 05-22-2015, 05:46 AM
Yes, I did.
Maybe I start again from the beginning..
Element's Avatar
Car: BMW 135i N54
Default 05-22-2015, 06:28 AM
Yes, I did.
Ok. Make sure you're using a recent XDF version for your DME as well.
Car: E92 335i
Default 05-22-2015, 02:24 PM
So, I used the last xdf file, my backed up BIN (via MHD), BMS E85 BIN, all for I8AOS. Again, I found no fields 2C77, 2C78, Map Max Voltage.
And I have 14 Torque Monitor Ceilings instead of 13 in the description.
8-)
nyt nyt is offline
Car: 335ix
Default 05-22-2015, 02:25 PM
8-)
Make sure you reload the xdf in tunerpro. It's not enough to just replace the file.
ba114's Avatar
ba114 ba114 is offline
Car: 135i 6MT
Default 05-22-2015, 04:21 PM
just so you know, it's actually easier if you dont have those fields defined in the xdf. means you dont have to de-select them when making the changes.
marconi118 marconi118 is offline
Default 05-24-2015, 02:04 PM
Gas pedal has a more linear mapping. 40% input = no boost while 100% input equals the full target. While OEM is more like 30% = no boost while 80% input = full target.
is there an XDF containing the scale for the throttle table?
In orig bin it goes from 0 to 70% pedal
I would like to scale it from 0 to 100%
Car: E92 335i
Default 05-24-2015, 02:55 PM
So guys, I installed the E85 flash (unmodified) and I got no code (after 300km). Should the fuel consumption be less with the modifications or not?
ElSaigel ElSaigel is offline
Car: E93 335i '07
Default 05-25-2015, 12:47 PM
I've got I8AOS (EU-specced) car. TunerPro difference tool can't find Map max voltage or 2C77 or 2C78. I do find Torque monitor ceiling and 2C7B + 2C7C and deselect them. I've gone trough all the lines for 5 times so I'm quite sure they are missing. I'm doing the comparison to I8AOS_E85bin. But why am I missing those few lines?
And someone mentioned about DMTL codes. Why are they still copied and selected from US-specced bins? Am I supposed to deselect them to keep stock (euro-specced) if I don't want them popping up?
JB4 G5 ISO, BMS DCIs, BMS 3" ***, VRSF 7" FMIC, BMS OCC, CP-e charge pipe with Tial BOV, BMS cowl filters, Fuel-it Stage 2 LPFP, BMS short shifter, BMS clutch stop, CDV valve deleted, Spec Stage 2+, map7@E60
ba114's Avatar
Car: 135i 6MT
Default 05-25-2015, 03:55 PM
Like i said previously, if the values you're looking for, aren't defined in the XDF, this is a good thing. it means you dont need to deselect it when using the difference tool and will automatically retain your stock values
ba114's Avatar
Car: 135i 6MT
Default 05-25-2015, 04:14 PM
I could probably figure out how to do it, but why dont we just have 2 xdf files; one for US cars with the DTML, torque monitor ceiling and whatever those other codes are defined, and one for EU spec cars where these values are not defined, thereby removing the need to deselect these options in the difference tool.
Would probably make the whole thing a little bit more noob friendly and remove the need/request to have BMS make EU bins...
Dirty Dog's Avatar
Default 05-25-2015, 05:11 PM
This is a good idea. May reduce the amount of confusion also.
_ink's Avatar
Car: 335i DCT
Default 05-25-2015, 10:38 PM
And this is my suggestion I've been trying to ask for all along!
Sigh.....
Element's Avatar
Car: BMW 135i N54
Default 05-26-2015, 04:46 AM
Ok guys i modified the most up to date xdf so that you simply load the BMS flash and use the difference tool to copy everything over to your Stock bin.
No need to deselect anything.
Nb. This is only for BMS BB flash bins. If you want an xdf for MHD based flashes, its pretty simple to add torque monitor ceiling back in.
good luck!
Nicely done
HairyWelshSteve HairyWelshSteve is offline
Car: '07 335i MSport Convertible
Default 05-26-2015, 11:43 AM
Great work ba114, could you also do a MHD iteration? Both could then be called Euro_MHD and Euro_BB followed by the release date of the xdf so we all know what version we are using.
Element - could you sticky that to the first thread?
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 05-26-2015, 01:02 PM
Download the xdf as zip here : https://github.com/dmacpro91/BMW-XDFs
then you can edit the breakpoints.
ratapeludismo's Avatar
ratapeludismo ratapeludismo is offline
Car: E92 335i
Default 05-26-2015, 02:07 PM
good luck!
Please, can you change for xdf I8AOS EU?
Thank you very much.
EURO - E92 335i - AT - I8A0S - JB4 G5 32.2 - MHD Flash Pump - DCI - DP
