Car: 2008 335i
10-09-2014, 06:26 AM
That's VERY cheap for meth.best price here in my area is 40.00 for 5 gallon pail of VP M1
E90 SEDAN '08
-SiNGLE TURBO AUTO TRANS*FSB G5 ISO*100%METH**FUEL iT!STAGE 2*ALPiNA FLASH- -NGK PLUGS*BMS OCC*RB VALVE- -E85 MHD FLASH-
10-09-2014, 08:05 AM
My pails are 34.99 for 5g. Or i can buy as i go, usually bring one of my empty ms109 pails and have him fill it up 22$for 5g lol.
Car: 2011 335xi
10-09-2014, 10:26 AM
Originally Posted by CHECKERED
But on a boosted car you want to have the coldest burning fuel (this is why E85 is so popular) because it burns cooler (and you need more of it) allowing more boost and more timing. For meth injection on a boosted car you want to cool the air charge and prevent detonation with a percentage of what you injection being water, the water % is your safety it too dangerous to tune your car in such a way that the water saves the engine at every combustion cycle.
Some of what you say is true, but it isn't the whole picture. Power is made from the expansion of air, that is what moves the pistons. How do we make a mixture expand? We heat it through combustion (PV=nRT - the ideal gas law). The reason E85 is so popular is that it has a high octane and is very stable in the burning process (it is quite lenient to AFR and timing changes). It also does a decent job of cooling the intake charge when injected (but not as good as meth). You want the coldest charge going in the engine so it is the most dense and the hottest discharge going out that will not cause harm. That gives you the most power.
10-09-2014, 10:40 AM
Originally Posted by ajsalida
I've seen the 55 gal barrels on ebay but my UPS guy would kill me...if the shipping charges hadn't already.
I bought mine from a fuel supplier. You can search for your local gas supplier and chemical supplier. I picked mine up from the supplier so it save a lot on shipping.
 2008 e93 MODS: BMS JB4 G5 ISO, bms trunk, RB PVC, Lukeperformance flash, mount meth kit, OCC, ******* ********, VRSF 7" FMIC, charge pipe, DCI, Alpina flash,
Car: e92 335xi
10-09-2014, 04:50 PM
Good tip thanks, I will look around here. In process of setting up meth for the first time on this car. Got a case of boost juice just to get started.
10-09-2014, 05:21 PM
I use a mix of MS109, meth and water. I know the 109 probably isn't any good for the pump but who cares.
Car: 2009 335i AT
10-09-2014, 06:55 PM
Why ask for problems when you know MS109 will kill the pump.
10-09-2014, 07:12 PM
It's not certain it'll kill the pump, maybe shorten it's life but I like to create problems and then fix them.
Car: 2008 335i
10-09-2014, 10:38 PM
Found a supplier up in SLC. They sell 99% pure methanol for $25 for a 5 gal bucket. I'll be picking some up next weekend when I'm up that way.
Car: 2008 135i
10-12-2014, 09:03 AM
Where at? I'm in slc and that's dirt ass cheap. Would be helpful for when I go meth next spring
2008 Aw/Coral Red Manual 135i Coupe-
JB4 G5 + BMS race flash, BMS meth kit, VRSF DP, Big tom Ic, BMS chinese tester CP, Custom Muffler Delete, BMS Oil Cooler Valve, Cowl Filters, Clutch Stop, B&M Short Shifter, Spec Stg 2+ Clutch W/ Oem dmfw, Vmr V710, KW v2, M RSFB, 1M Front and rear Bumper, Performance Side Skirts, slek trunk, Lci blacklines
Car: 2008 335i
10-13-2014, 08:54 AM
Jaradine Petroleum
1117 North 400 East
SLC, UT. 84054
Car: 2008 135i
10-13-2014, 11:41 AM
Sweet thanks. that's not too far from my house.
