(#76)
robc1976's Avatar
robc1976 robc1976 is offline
Default 11-30-2013, 06:45 PM
Originally Posted by Ocean
Sounds really high. I have never used VD myself, so forgive my ignorance. Does it indicate WHP or BHP?
475 WHP on stock turbos is probably a world record!
VD is probably calibrated to put a smile on people's faces rather than sending them home depressed. Marketing?
not that accurate...some the hp is low, some the hp is high....still fun though lol!
rudypoochris rudypoochris is offline
Default 11-30-2013, 08:51 PM
You need to run in VIRTUAL DYNO mode. Dynojet mode multiplies everything by 1.09x. VD is reasonably consistent if you do a few runs on flat ground. I used to get 432-437 whp with 50% E85, intercooler, and dci. With the new flash I got 455 whp with the same mods. Feels about right. I need to do some more pulls though to see where it groups around. The next pull may be 450whp and the one after that 460whp, I don't know. After about 5 you will see a relatively clear picture.
2008 335i Coupe 6MT
JB4G5, DCI, Wagner FMIC
Wedge1967's Avatar
Wedge1967 Wedge1967 is offline
Car: '07 335i e92
Default 11-30-2013, 09:45 PM
Not a bad gain with just a flash.
Default 11-30-2013, 09:52 PM
Yeah! I think the timing is its a little past MBT though (maybe its just my fuel). Will keep playing with it.
2008 335i Coupe 6MT
DOCRAMON DOCRAMON is offline
Car: 2008 535i
Default 06-21-2014, 06:54 AM
I read the thread, looks amazing! to clarify you are running 100% e85 with this tune?
Terry's flash end race? with ISO G5 27.9? correct?
Car: 2008 535i
Default 06-21-2014, 06:56 AM
100% meth?
rustyminded rustyminded is offline
Car: Bmw 328i F30
Default 06-21-2014, 11:33 AM
Why not try the 5" dp you'll probably get 10-15 whp more
F30 328i - 8 auto.. JB4+FF+EWG, OCC, Injen Intake+scoop, AFE dp, AA axle-back - H&R springs, H&R rear SB - Front Strut - F&R BMS spacers..
robc1976's Avatar
Default 06-24-2014, 11:11 PM
Running much more aggresive map 6 settings with 15* timing via wedge flash.
N54 TuNeR's Avatar
N54 TuNeR N54 TuNeR is offline
Cool ///Member
Car: E90 SEDAN
Default 06-25-2014, 10:46 AM
Rob when are taking it to the dyno/track?want to see some #'s.the car looks to be a beast!
SOLD
2004 E46 ///M3 MODDED
PRESENT RiDE
2008 E90 SEDAN G5 iSO-FBO FSB-100%METH-DUAL NOZZLES,Fuel iT!Stage 2
frmtl2_335i's Avatar
frmtl2_335i frmtl2_335i is offline
Car: 07 e92 M/T
Default 06-26-2014, 07:34 AM
why 27.9 over 27.15?
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
12.23 @ 118.9mph (RBs)
2.3 60' lol (single pass night, bog shifting)
GtiGyver GtiGyver is offline
Default 06-26-2014, 07:57 AM
Hi Wedge, beyond the performance tuning that you obviously control, are you also able to code-out certain elements of the ECU such as the cold-start enrichment and valve overlap (used to warm up the cats). Since i have a PE and aftermarket midpipes it gets stupid loud for the first 60-90 seconds and annoys the neighbors.
thanks
Seavita Seavita is offline
Car: BMW 335 CSI
Default 06-26-2014, 01:09 PM
^x2
Sleeper edition Cabrio 3 series
Performance: JB4/G5 ISO MHD Flash, RB's and HiFlow oil returns, BMS DCI, PLM ***, cp-e FMIC & OC, aFe scoops & Throttle body spacer, Alpina TCU Flash, Stage 2 LPFP bucketless and Platinum PI by SteveAz, Mspec LSD, Cp-e charge with tial BOV, RB inlets and VTT outlets (let them fight my car doesn't care)
trebila's Avatar
trebila trebila is offline
Default 06-27-2014, 01:37 AM
it's an old thread.
27.15 was even not released.
cityazndan cityazndan is offline
Default 07-08-2014, 10:32 PM
Man, I wish Wedge wrote Cobb maps...can't seem to let it go.
SOLD 2007 BMW 335i | 6AT | ZSP | ZPP | ZCW {Smurfin' before it was cool}
|JB4 G5 ISO|Cobb|S&B Filters|RB|Evolution Racewerks|Synapse|ar design|JetHot|Active Autowerke|Bastuck|
||Amuse Ericcson|M-Sport|M5 SMG Knob|V1 Yellow Stripe Steering Wheel||
SOLD 2009 BMW 335i | 6AT | ZSP |ZPP
|FBO, PS2, Meth and #spacegraybrigade|
OTW 2018 Audi RS3 |7DCT |Dynamic | Black Optics | Tech | RS Design
Wedge1967's Avatar
Car: '07 335i e92
Default 07-08-2014, 10:39 PM
I do... but it's a lot more more work...
Default 07-08-2014, 10:50 PM
Pmd
robc1976's Avatar
Default 07-08-2014, 11:08 PM
Quite complaining old man!
Car: 07 e92 M/T
Default 07-12-2014, 10:16 AM
thanks
same here, i had my neighbors ask me to back into my driveway because i wake them up in the morning when my car is facing their home.
mohammed mohammed is offline
Car: bmw 335i
Default 07-13-2014, 06:48 PM
Bro it is more power to I using this file for my car ?? G5_ISO_27_9_FBO-METH_RB_WEDGE FLASH_MAP3_60ADD.csv
Car details
1- RB turbo
2- AMS intercooler
3- meth kit
4- BMS charge pipe
5- JB4 G5 + Flash
6- AR down pipe
7- Mister shift exhaust
8- BMS intake filter
9- AEM fuel pump
robc1976's Avatar
Default 07-13-2014, 07:16 PM
Car details
1- RB turbo
2- AMS intercooler
3- meth kit
4- BMS charge pipe
5- JB4 G5 + Flash
6- AR down pipe
9- AEM fuel pump
map 6 with custom boost settings will yeild you more power, all him for some settings since he can advise add he has your logs and info
Car: bmw 335i
Default 07-13-2014, 07:38 PM
how i can do that?? just we need to upload this file in jb and Already am using the terry flash??
robc1976's Avatar
Default 07-13-2014, 07:46 PM
use map 6 instead of map 3 with custom boost settings.
Car: bmw 335i
Default 07-13-2014, 07:53 PM
how I can get the custom boost settings and additive setting for map 6?? did you can post the default setting for that bro..
thank you
robc1976's Avatar
Default 07-13-2014, 08:00 PM
thank you
my boost settings are very aggressive and take lots of logging to use, if your car does line then you could blow something. Without knowing your current flash, timing, fuel, engine health ect I won't post then. Contact wedge, he will give you the settings since he has seen your logs ect and can better advise.
Car: bmw 335i
Default 07-21-2014, 09:47 PM
Hi guys,
Who can help me how to set map 6 custom tune with higher timing lool
