(#4826)
mmx's Avatar
mmx mmx is offline
1992 world bingo champion
Car: 08 535xi
Default 08-08-2012, 12:51 PM
Originally Posted by BMW86
Just updated new FW. Will report back soon. What interface is everyone using? I'm using 6/23
As of right now, Interface 6/23 is the latest (see the first post in this thread).
JB4 G4, DCIs and '94 (RM2)
F335i F335i is offline
Car: 2012 335i 6AT
Default 08-08-2012, 02:58 PM
Originally Posted by 5soko
Yup i captured it in the logs too and seems to be the open fuel loop learning which is a known issue with some cars
Im set Future use A to '2' and open loop mapping to 75 as per instructions on page 1.. But i have yet to try it out.. But seems to be the fix.. Might try it tonite after i get done with all my work. Hope it works, everytime 100+ 3rd into 4th gear has been limps and codes! ill be happy as hell if it works out!!! will report back
Hey, I can I have a link of your logs in this limps you get into, I think this is the problem I been trying to solve. I want to see if my logs shows the same limp as yours.
Thank you.
JB4 S2+ISO Map 7, BMS dp, BMS chargepipe, BMS Intake, Flex fuel wires, BMS OCC.
strayman strayman is offline
Car: bmw 335i
Default 08-10-2012, 08:35 AM
hello MAP 6 run with meth boost additive or only set up ?
thanks
335i coupe 2007, AA DPS, JB4 15 ohms 1.5 fuel ressistor, CPS, AA FMIC, dual HKS blow off, BMS DCI, Coolingmist v1.07 meth flow integrated, 2 DO10, N2O integrated 35 shot at 950 psi.
BMW86 BMW86 is offline
Car: BMW 135i
Default 08-10-2012, 11:06 PM
Is this new FW legit? I haven't had a chance to test it out yet, at all. Am going for a drive tomorrow and will be doign plenty of WOT in 2-4th, don't want any issues.
Car: BMW 135i
May take my laptop as backup
nvrana nvrana is offline
Default 08-11-2012, 08:19 AM
I have a feature request, is there anyway we could use the JB4 as a D-CAN passthrough to allow programming of features like window up/down on lock, unlock on park, etc.?
Default 08-11-2012, 10:19 AM
Deleted the support/log requests. As always if you want public assistance, use the support forum. If you need BMS assistance, email us the CSV log.
We've thought about it but nothing planned.
Default 08-11-2012, 10:37 AM
If it ever happens it would be appreciated, heck, provide the pass-through and I'll write a basic UI to enable all of the known features
jacobniell jacobniell is offline
Default 08-11-2012, 11:25 AM
Originally Posted by mykal335xi
I'm getting rid of my G5, if anyone wants it PM me.
Could you please explane in more detail why you are getting rid of your G5?
Are you having problems with it?
mykal335xi mykal335xi is offline
boom
Car: BMW
Default 08-11-2012, 11:26 AM
No, just parting out the car.
2011 335i m-sport
2008 335xi (Sold)
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 08-11-2012, 11:44 AM
Pn me with a list of parts please...actually I am sending you a PM now!
Car: BMW 135i
Default 08-11-2012, 11:36 PM
Tested the new FW today and it's legit, runs fine on Map 5 on FBO. No where near as aggressive as 5/23 but at least there was no misfires
Look forward to running it at next track day
Default 08-12-2012, 02:09 AM
Hi there
Can any of you tell me if I upgrade the wires for the G5 board that has both CPS and SLD, connected using wires on the DB9 connector, Will that still work with the JB4 G4 If I decide to switch back to the "old" G4 board?
Default 08-12-2012, 09:53 AM
Hi there
No, you would need to disconnect the wires from the harness end in that case.
rudypoochris rudypoochris is offline
Default 08-12-2012, 11:22 AM
If anyone is running lagfix 100 and getting something akin to lag then snap boost at 3200rpm or so. Try setting lagfix from 100 to 80. Fixed the problem for me and smoothed it out. I always used 100 lagfix before.
robc1976's Avatar
Car: 2007 335i
Default 08-12-2012, 07:38 PM
I have mine set to 100...what is your car exactly doing?
Default 08-12-2012, 07:53 PM
I just noticed a change from the last to current firmware. The old firmware didn't overshoot the target at 100 lagfix. This current one often does. 80 lagfix fixes it.
robc1976's Avatar
Car: 2007 335i
Default 08-12-2012, 08:44 PM
Ah, I see...mine overshoots at the end once in a blue moon.
bmw loe bmw loe is offline
Car: e92 N54 335i
Default 08-13-2012, 05:20 AM
From a "responsive" standpoint, is the G5 in it's own league to wear having the setting set at 80 is fine? I had my G4 board set at 90. I can't wait for mine to arrive this week and finally not only hit 17.5 peak boost (like I was able to on the g4 18ohm), but to hit target boost after all the way to redline (which I wasn't able to do). Especially since I botched my 15ohm mod and also cracked the G4 board while doing so
vereak82's Avatar
vereak82 vereak82 is offline
Default 08-13-2012, 10:32 AM
dont worry i did this also (loving the new G5 )
JB4 pnp, Afe dci, Riss Racing ''Dp, Cyba intake scoops, ZS-Charpe pipe w bv, BMS ww Meth kit,
12.06@117 6-speed manual
robc1976's Avatar
Car: 2007 335i
Default 08-13-2012, 11:12 AM
The G5 is stronger (less restrictions) I had my G4 at 100 and also have my G5 at 100. You will notice the throttle response instantly compared to the the G4.
Eracer76's Avatar
Eracer76 Eracer76 is offline
Car: 335xi
Default 08-13-2012, 02:27 PM
I dont know how you guys can stand driving the car with the lagfix set at anything higher then 80!
I have my G5 set at 60 because I like it smooth and linear, where the more gas you give it, the harder it pulls.
I found that when I set at 80 or higher, the gas pedal was WAY to sensitive in city traffic. I dont need the car to snap my head against the headrest when I'm trying to take off slow from a stop! LOL
Besides, even with it at 60, my car will still snap your head back without a problem if I push the pedal down fast... there is no lag and it hits target boost just fine!
2009 BMW Z4 35i 6spd mt: Speedtech single turbo w/ all the goods!
Default 08-13-2012, 02:50 PM
I always ran 100 lagfix until last map something changed. Felt laggy then boost snapped in. I am at 80 now and like it better.
G5 is much better than G4 18ohm. I also botched the 18 to 15 conversion.
robc1976's Avatar
Car: 2007 335i
Default 08-13-2012, 03:15 PM
I am going to have to try this....I don't feel any ag to much though...it is fairly smooth.
