(#3926)
DCTepper DCTepper is offline
Car: '07 SGM 335i
Default 02-20-2012, 08:14 AM
Originally Posted by pnosker
You guys really shouldn't use water temp as the factor to decide when the boost is increased. I took a pic of my steering wheel (reports water and oil temps) to show you why. By the time the water temp hits 160 F, the oil temp is only 91 F which if you look at an oil viscosity chart is much thicker than at 160 F (which is close to operating temp viscosity). You're adding a significant amount of wear to your engine running it at high boost under 100 F oil temp. Your turbo bearings are taking a beating and your cylinder walls are more likely to scour as well as your main bearings.
This is a good supplement to Terry's notation that this feature is for those who are not concerned with long-term turbo longevity. While there are those out there that may not fully comprehend the inherent risks involved, I like the freedom of knowing the power is there should I choose to utilize it.
BES335xi's Avatar
BES335xi BES335xi is offline
FBO+ N54xi
Car: '07 E90-335xi
Default 02-20-2012, 08:18 AM
idk, but i've come to notice that as soon as the oil drops from 0 the boost is there after..
JB4+usb | BMS OCC | P3 Vent Boost Gauge v2 | BMS DCI | AMS FMIC | AR xi CL DP's | BT Tool | Stett Tial BOV W/Meth Charge Pipe [soon] | Cyba Quad Exhaust tips | M-Tech Rear & M3 Front Bumpers | Cyba Red Air Scoops | Blacklines | Vinyl Overlays | ACS Roof Spoiler | Matte Black Grilles | LED Side Mirrors | Rear Euro Fogs | Matte Black Finishing Rods | 30% Tints | Sports & Winter package | Black Leather Int. | Aluminium Trim | & few extras not listed. Car: '07 E90 335xi vrrooom lol'
Car: '07 SGM 335i
Default 02-20-2012, 08:20 AM
Same for me, the moment the oil temp needle twitches my flashers flash. Coolant warm up time was about about 3-4 min at 30°F here in MI.
BES335xi's Avatar
FBO+ N54xi
Car: '07 E90-335xi
Default 02-20-2012, 09:44 AM
Just changed last night 3 Injectors and coded them via INPA, routed the USB cable through the glove box, didnt need to disconnect anything just lifted the dme tray upward and it gave me enough room to fit a cable through there, Updated to 2/7 firmware....Now time to do some dataloggin' when i get some time.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 02-20-2012, 10:29 AM
This is all true for the most part, but keep in mind, just because the tune activates doesn't mean the driver has to immediately start driving at WOT. I started using this feature and I just like the fact I get the full responsiveness and feel of the tune much sooner, since my commute is very short. I still try not to push beyond low boost and low RPMs until the oil temp hits 160.
Also, your pic is huge you might want to resize smaller.
Stranger2k1 Stranger2k1 is offline
Default 02-20-2012, 04:34 PM
switched to the new software today and was surprised. after some short troubles in higher gears, the car was pulling just amazingly forward.
even on 95 octane (euro-spec!) fuel, which was not working really well with the old software (i had to put it in the car because there was no other gas station around...), the pulls on map5 made me smile BIG time!
Wheelspin in 2nd over the whole range + also spinning in 3rd gear.
the new possibility to enable the tune in dependence of water temperature is on one side quite nice, because it takes a lot of time to get the oil to temperature with low rpm, but on the other side it somehow feels so wrong to step on the floor without seeing the oil needle moving. i think it takes a strong-minded driver here that thinks about the possible consequences...
Brahmzy Brahmzy is offline
Car: 2010 135i
Default 02-21-2012, 09:22 AM
Loaded up 2/7 everything and tried map 5 for the first time. WOW. I'm very impressed. I was on map 2 and getting some really weird things going on in 3rd-6th gear up here at 6,200ft. Map 2 may have been a bit too aggressive for this altitude, without dp's. I am running the equivelent of 93/94 octane, so it ain't the fuel.
Anyway, map5 seems to be pulling like a raped ape in all gears, and much smoother as well. Very happy.
2010 135i | 6MT | Le Mans | Prem Pkg | M Pkg | CA | Hi-Fi | Boston | Other Cool Stuff
MuCcIo MuCcIo is offline
Car: 135i FBO
Default 02-21-2012, 10:00 AM
Ok, 7-2 loaded, map6 is simply amazing.
Never heard something like that before, and i've tryed all tunes with all maps (aggressive included).
Many compliments Terry, some logs will coming.
PS: only one thing... i've noticed, when jb4 turns on, a little "pull back" (i was at steady throttle and i've turned on blinkers)... Just a little hesitation.
PPS: only the first time... never happened after that.
BMW 135i: Jb4 2-7 Map6 // Vk ********* // ETS Intercooler // BMS DCIs // Z-Shift BOV // Bilstein B12 // Ferodo DS2500 // Goodridge Brake Lines+Motul RBF660 // 1M Wheels // PZero Corsa
jclariel jclariel is offline
Car: bmw 335i
Default 02-21-2012, 06:12 PM
I thought JB4 won't get activated untill the oil temp hits 160?
mzman mzman is offline
Car: 135i, 944T, M3, MRoad, Miata
Default 02-21-2012, 08:38 PM
By default that is true, and it is the recommended setting. But you do have the option to use the coolant temp instead. A few members requested it because they lived in a very cold climate and understand the consequences.
Car: 135i FBO
Default 02-22-2012, 04:03 AM
Amazing... Terry, simply AMAZING.
Every time I push WOT it's incredible. This map6 is really awesome.
Car: 135i FBO
Default 02-22-2012, 10:30 AM
Jb4 2-7, map6, 3rd gear:
MathR601's Avatar
MathR601 MathR601 is offline
Default 02-22-2012, 11:04 AM
What fuel?
Car: 135i FBO
Default 02-22-2012, 11:15 AM
Well, it's italian fuel pump 100RON.
Consider that usa's 91 is our 95RON, and usa's 93 is our 98RON...
So about 94/95oct.
Car: bmw 335i
Default 02-22-2012, 04:36 PM
So about 94/95oct.
So r u using Meth?
BMW E92 335i: JB4 2/7/12 Map5 // AR design catxxxx ********* // aFe DCIs // Bilstein PSS10 // AP racing front 6 pot with red Caliper // AP Brake Lines + brake oil // BBS RG-R 19' diamond black // Michelin PS2
myotherbaby's Avatar
myotherbaby myotherbaby is offline
#sleeper#
Car: 335i convertible
Default 02-22-2012, 06:30 PM
How safe is map 8? I mean if I drive on that 5 days a week and wake up the turbos on the weekends, is that safe for turbos to just sit there. How about map 8 for long cruises when I just wanna feel what a 328 feels like?
CURRENT: 07 335i e93
Arctic mettalic..
jb4: map 5.......
Previous:
06 Range Rover HSE
02 Passat
'89 Conquest (was fun to drive)
Want free electricity!!!!!
go to:
http://freelectrik.joinambit.com
Default 02-22-2012, 06:58 PM
Perfectly safe long term as long as you don't mind the CEL on the dash.
dfjaws's Avatar
dfjaws dfjaws is offline
Car: 2007 335i 6MT
Default 02-22-2012, 07:10 PM
I've got a long drive coming up this weekend. Thinking about seeing what the range difference is for a tank of gas between maps 8 and 6. I'll keep you guys posted!
mykal335xi mykal335xi is offline
boom
Car: BMW
Default 02-22-2012, 07:56 PM
I wonder, could you use 87 octane on map 8? Maybe that's going a bit too far to save money
2011 335i m-sport
2008 335xi (Sold)
mcc mcc is offline
Car: 335xi
Default 02-22-2012, 11:44 PM
Dumb question. What is an FBO car?
boom
Car: BMW
Default 02-22-2012, 11:51 PM
Full Bolt On (FBO) = FMIC + DP + Intake
2011 335i m-sport
2008 335xi (Sold)
hooliyo hooliyo is offline
Car: 2009 135i
Default 02-23-2012, 03:18 AM
Originally Posted by My 135
Can JB4 be trained at 2nd gear in addition to 3 and 4 th gears since I do not want to risk getting a speeding ticket for doing this?
Also, if I flipped between map 0 and map 5, do I need to re-train the map 5 or Jb4 has it stored in its memory?
Thanks for the help in advance.
Originally Posted by Dirty Dog
The feeling of a 3rd gear pull is worth the ticket. The feeling of a 4th gear pull isn't work jail time.
Once you switch to map 0 your car will have to relearn on map 5. Not saved.
Auto tuning does not learn in 2nd gear. From my experience even a conservative Map 5 will spin at the wheels in 2nd gear. Therefore the JB4 will not learn accurately in 2nd as you wont get a full launch all the way up to redline without the wheels spinning. I find using only 3rd gear to learn works fine for me
MikeF MikeF is offline
Default 02-23-2012, 05:29 AM
How many 3rd gear pulls would you suggest I do for Map 5 to learn?
aoschadlin's Avatar
Car: 535i
Default 02-23-2012, 05:33 AM
I think Terry mentioned somewhere that 3 pulls should do it. You should notice the difference before and after.
Default 02-23-2012, 05:53 AM
Thanks ... off to do my 3 now ...
