(#3726)
DCTepper DCTepper is offline
Car: '07 SGM 335i
Default 12-09-2011, 12:50 PM
Originally Posted by bigboost980
Interesting!What were you mods,fuel,and condtions.???I thought map 5 was weak and was for the summer heats to keep the car more safe then map 2?
Only mods are JB4 and DCI (also from Burger) running 93 oct. That's the nice thing about Map 5 though, it doesn't matter what your mods or conditions are, it will automatically tune for peak performance based upon your car and conditions. Map 1 and 2 are preset maps, whereas Map 5 will allow for more boost if the conditions are right (ambient temp, airflow, octane rating, etc).
i2istudios's Avatar
i2istudios i2istudios is offline
Photog
Car: 335 Coupe 6MT
Default 12-09-2011, 12:59 PM
Originally Posted by DCTepper
Map 5, it will automatically adjust (auto tune). I saw higher boost levels and felt more power than Map 2 on Map 5
Map 5 is safer, I'm all for longer life.
2007 E92 335i / 6MT / Monaco Blue Metallic / Gray Dakota Leather / Comfort Assist / Premium / Sport / Heated Seats / Navi / Active Steering / Active Cruise Control / Park Distance Control / Rear Sunshade / Sirius MODS PicoTray / M3 Steering Wheel / Front OEM Aero Lip / Bimmian Aluminum Pedals / CDV / Ram Air Scoops / Painted Reflectors / HID 5000k / LED Angels / M Perf. Shifter / Euro Light Switch / 8500 x50 Hardwired / Center Armrest Pouch / JB4/ BT
Car: '07 SGM 335i
Default 12-09-2011, 01:01 PM
Speaking of safety, I assume it would pull timing/ignition/boost if someone were to choose too aggressive of a map for their car or conditions, correct?
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 12-09-2011, 03:46 PM
How long does it take for Map 5 to adapt. I run map 2 with a mix of 100 racing gas but the proportion changes depending on how much fuel is in the tank when I get gas.
I generally try for 30% of 100 70% of 93.
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
Default 12-09-2011, 05:04 PM
It learns at WOT in 3rd and 4th gear. You can just leave it on map 5 full time and it should be fine. For more power run 80% race gas and use map 7.
xbox_fan xbox_fan is offline
Car: BMW 335i E92
Default 12-10-2011, 12:17 AM
If the DME pulls timing the jb4 will lower boost (on map5).
stpijb stpijb is offline
Default 12-10-2011, 08:55 AM
Terry, I am highly impressed with map 5. Ran Map 5 for a month and switched to Map for a month. All I got done so far for mods is injen DCI. I feel a much better pull with map 5 than map 2. Im going to guess its changes timing, boost based on conditions seems to have better results.
saxplayr's Avatar
saxplayr saxplayr is offline
Car: 2007 335i e90, 6MT, Milltek exhaust, DCI
Default 12-10-2011, 09:09 PM
I read somewhere that you had to get to 4500 rpms in map 3/4 to get Map 5 to autotune. Is it EITHER 3 or 4, or both?
Default 12-10-2011, 10:34 PM
Map 5 learns at 4500-redline in 3rd and 4th gears.
kawchkjf kawchkjf is offline
Default 12-11-2011, 04:01 AM
Hey Terry,
Didn't want to make a new thread...just wondering if your CAN tool is compatible with the E92 M3? I've picked one up and was wondering if I am able to use only the clear CEL function of it...
saxplayr's Avatar
Default 12-11-2011, 05:54 AM
So do I have to get it up to 4500 in BOTH gears to learn.. in other words hit 4500 twice... OR just getting it to 4500 in EITHER gear will autotune for me? What if I ht 4500 in 3rd and not in 4th... where will it leave me?
335is 7DCT/JB4
Default 12-11-2011, 08:37 AM
Second part of this question - how many times does this need to be done to fully setup the JB4?
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
Car: BMW 335i E92
Default 12-11-2011, 09:45 AM
No i think it learns in either, but I agree revving to redline in 4th is kinda fast
Default 12-11-2011, 10:36 AM
It's a continually learning process, designed so you just drive the car and when the opportunity is right for the JB4 to learn something it will. It will never be "done" and will always be changing based on the conditions of that moment.
saxplayr's Avatar
Default 12-11-2011, 11:10 AM
+1 (love my 335i)
Guam135i's Avatar
Guam135i Guam135i is offline
Car: 2008 135i
Default 12-11-2011, 04:11 PM
+1 (love my 335i)
+2
1970 Morris Cooper S
2008 BMW 135i Coupe
2008 BMW 128i Cabriolet
"Aerodynamics is for people who cannot build engines" Enzo Ferrari
2008e90 2008e90 is offline
Car: 08 e90 sedan
Default 12-12-2011, 06:58 PM
"""It's a continually learning process, designed so you just drive the car and when the opportunity is right for the JB4 to learn something it will. It will never be "done" and will always be changing based on the conditions of that moment.""""
Is this how MAP 3 works too?
Default 12-12-2011, 07:24 PM
Similar, only map 3 never goes higher than the meth boost additive.
e90man's Avatar
e90man e90man is offline
N54ever
Default 12-12-2011, 09:21 PM
I want to know where this new 12/1 firm update?
C'mon guys...Terry will release it when it's ready. I'm sure he has his reasons to wait.
i2istudios's Avatar
Photog
Car: 335 Coupe 6MT
Default 12-13-2011, 08:24 AM
Terry will release it when it's ready. We have a remarkable tune as it is, no need to rush.
Ash83 Ash83 is offline
Car: 10 E82
Default exhaust burble - 12-14-2011, 04:33 PM
Is the exhaust burble that BMW is marketing on their PPK ver.1 something that we can get with JB4?
illrider illrider is offline
Default 12-14-2011, 04:50 PM
Is there a way to enable the meth on oil gauge hacking only while in Map 3 automatically?
For example, as soon as you switch to map 3 the meth on oil is activated, and once you switch to another map it goes back to oil temp without having to go into the commands to manually change it.
Default 12-14-2011, 06:01 PM
No, there isn't.
geterdone's Avatar
geterdone geterdone is offline
Boosted
Car: 2007 335is E90
Default 12-14-2011, 11:38 PM
What you need is programming to shift sooner. It may be possible to have the JB4 hijack your paddle shifters and shift for you at 6000rpm, for example. It's something we're planning on looking at some day.
That would be awesome, I believe this would be very beneficial to some of us.
markman130 markman130 is offline
Car: '07 335i
Default 12-25-2011, 01:35 PM
I just wanted to thank Terry for always being available to his customers. Today, Christmas, I sent him an email expecting a response later this week at the earliest. I received an email within 30min and he answered questions for me all day. You won't find better service anywhere!
Thank you, Terry and Co.
