06-28-2011, 03:37 PM
Probably not possible.
Car: '08 535i
06-28-2011, 03:45 PM
Hey Terry, just a quick question: Does the max cool mode somehow cause the battery to pull a higher than average amount of charge from the battery after the car is shut off? Because about 3 times since I've turned on max cool mode the car given me the discharge error, and nothing has changed except that. Then I heard today at the BMW place that the fan being constantly on could cause that (overheard another conversation about a car's battery constantly dying). LMK if this could be a problem or if it's something else I should look at.
2008 535i || JB4 || BMS DCI || Custom Mandrel Bend Borla Exhaust || AR Design C@tless *** || More to come!
06-28-2011, 03:54 PM
Haven't come across any issues like that with it.
Car: '08 535i
06-28-2011, 04:08 PM
Alright, cool thanks! :D
Car: e92 335i
06-29-2011, 12:18 AM
Hey Terry, i am going to upload the software tomorrow, as for maxcool when is the proper time to use it?
Car: 08 e90 sedan
06-29-2011, 10:15 AM
I'm not Terry but I believe he said you could leave it on all the time
Car: 2013 335i M Sport
06-29-2011, 10:17 AM
I just installed the new firmware yesterday (had the February Firmware prior) and It feels about the same to me (the jerkiness) but it's not bad. I don't mind it at all. I wonder if it's because of the DCT? At Any rate, Terry, I emailed you a few logs yesterday but I'm not sure if they are going to do you any good. I couldn't get past 3rd gear due to where I was and for some reason the Map 0 log didn't record RPM's or a bunch of other prameters. Outside temp was 106 degrees. The Map 1 log showed IAT's in the 140's. Seems high to me but nothing I can do about it without Meth or FMIC I assume. Only other mod I have besides JB4 is the DCI
06-29-2011, 03:29 PM
I've been running map 5 for a week or so now and it's really good, spiking at around 17psi and generally holding 15psi. Only other mods are AR DP's and Supersprint mufflers, running on Tesco 99ron (UK).
Car: 2009 335i AT
06-29-2011, 03:40 PM
Map 0 logs will not show any CAN supplied information because in Map 0 allmost all CAN functions are turned off. If you want to log stock values then use Map 4 at least for the time being.
Yes it's HOT here in Phoenix!!! Your IAT should be 20 degrees over ambient while on the highway and up to 170 or so at the end of a long pull without meth.
06-29-2011, 03:52 PM
Thanks. I already can't wait for summer to be over. This N54 feels like a slug compared to when it was in the 60-80's.
Terry let me know about the user error on the data logging so I know for next time.
Car: 08' 335xi
06-29-2011, 04:05 PM
Originally Posted by GSXR_MARKY
Try a windows update!
Installed a bunch of updates.....still says USB device is unknown and I can't connect.
Terry, do you know of anything else I can try?
06-29-2011, 04:43 PM
Can't offer much help there. Maybe try a local computer whiz or another laptop. You just install the FTDI driver package in our install folder and it works like a charm every time.
Car: 08' 335xi
06-29-2011, 05:14 PM
Is there any chance it could be the cable? It's been folded up under the hood and tucked in the passenger side fender since I installed it a few months ago.
MY TR6 needs Bimmer power
Car: 07 335i coupé cabriolet
USB cable -
06-29-2011, 05:37 PM
Try this right click on my computer go to Manage.
Click on device manager.
With it open plug in you cable.
If you do not see a new tab called port your computer is not recognizing your cable or the drivers.
If nothing shows up look in the event viewer at application or system and see if you have any errors.
I am using a netbook with XP with no problems.
Car: 08' 335xi
06-29-2011, 06:11 PM
Yeah, the port doesn't show up since it says USB Device not Recognized. I tried another computer and have the same issue. I really think it's the cable now.
Its the cable -
06-29-2011, 06:21 PM
Yes it is the cable of the connection to the JB4 is loose.
06-30-2011, 03:47 PM
Terry, I think I remember you saying you didnt have plans to have a jb4 program for mac, but is there any chance?
06-30-2011, 04:41 PM
I may do it some day. But busy with other fun stuff for us.
pursuit of performance
Car: 2007 E90 335i
06-30-2011, 06:03 PM
I LOVE when Terry says things like this!!! It means lots more of this!!! -->
2007 E90 335i // sparkling graphite metallic // sport package // logic 7 // light grey leather w/aluminium trim // m-sport steering wheel // HID foglight conversion // LED angle eye upgrade // M3 style CF hood w/vents // matte black kindney's // AFE dual cone intake // ********* DP's // custom SS exhaust w/ high-flow cats, H-pipe, single magnaflow muffler // 265/35/18 - 225/40/18 Yokohama s-drive's wrapped around TSW machined lip wheels w/car colored centers // Burger Tuning JB4
Engineer
Car: 2008 BSM 335i Coupe
07-01-2011, 06:25 AM
You can create a windows virtual machine on your mac laptop with vmware fusion. I have a linux laptop and use a virtual windows machine to connect to my jb4. Just an idea.
2008 BSM 335i coupe-jb4.BMS intake.meth
1999 Pontiac Grand Prix-10.5PSI.PRJ LL Cam.supporting mods
Enginerd
Car: 2009 135i
07-01-2011, 11:00 AM
Or Oracle's VirtualBox, which is free. Thats what I use on both my Mac and Linux machines.
--2009 BMW 135i--2016 Nissan Titan XD (Turbo Cummins ISV)--2016 VW Tiguan 2.0Tsi --1988 Beechcraft Bonanza--Suzuki GSX-R 1000--Honda CBR-600RR--
JB4 G5 ISO | MHD | E85 | Fuel-It S3 LPFP / PI | MFactory S3+ Clutch / SMFW / LSD / Mounts | Diff Lock | UUC Tranny Mounts | DwnPipes / Exhaust / FMIC | Chargepipe / Tial | KW V3s | HR Sways | HPA full M3 Suspension | BMS DCI / Oil Cooler Valve / Cowl Filters / 4bar / 2Step / OCC | RB PCV | Stri Gauges | Pole Position 225/265 | Installing: DR 6466ST
Car: E90 335i 07
07-01-2011, 01:57 PM
I love how easy it is to install/uninstall the JB4!
I just had the injector recall/campaign done and reinstalled JB4...so smooth so powerful!!
Car: 2009 E60 535i
07-01-2011, 10:48 PM
i turned on the max cool.
The fan was running crazy and loud on the 5 ser.
Any solution Terry??
Turbo Lover
Car: 300zx TT, 1M
07-01-2011, 10:58 PM
Huh? It's supposed to.... hence the term "Max Cool".
Humid 535i
Car: 535i
07-02-2011, 10:32 AM
Yep. That means it's working.
