(#526)
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 11-05-2018, 07:39 AM
Hi Arthur,
Welcome to the forum. Firstly it looks like you may have flashed the b48/b58 firmware as opposed to the mini firmware which ends in hex4. Go to the mini section and the last firmware( though old but reliable) will be under Terry’s post as I have also seen you post under b48/b58 which is the wrong section. Use the settings on that post to ensure you are back up and running and post a log of map 1 in the support section requesting a review by BMS (Terry/ Payam) are very proactive and helpful but are also very busy. Piece of advice as you are new here being patient will get you a lot of support!
Link to where you can find mini section is here and under the post from Terry first post you will find the file ending in 4.hex. I have assumed the engine to be b38/48 and newer mini version.
https://www.n54tech.com/forums/showthread.php?t=33083
ArturCavalcanti ArturCavalcanti is offline
Car: Mini Cooper S F55
Default 11-05-2018, 09:15 AM
Originally Posted by Jay1312
Hi Arthur,
Thanks, just found the correct file!
Car: B46 F56S
Default 11-08-2018, 02:21 AM
If I mix E85. Are flex fuel wires required on MINI Platform?
If so, what settings am I changing when I do the mix?
Default 11-11-2018, 05:13 PM
Log and evaluate it, the fuel pressure wire may be required. Open loop would be set to 60 if equipped.
Car: B46 F56S
Default Yesterday, 03:09 AM
Got it. One thing to note, my car is equipped with a BMS Meth kit, Nozzle 7.
What would be a good starter? Map 1, FF Wires, FOL 60, Meth (50/50), 2 Gal E85 with 91?
Or is FF wires and FOL Setting not needed with the presence of meth?
Thanks in advance.
