Rebeka Rebeka is offline
Car: Baleno
Default Quick disconnect fittings for Can wires? - 02-10-2021, 08:33 PM
Hi everyone, I did a search for this topic, but couldn't find anything. Due to various reasons, I've had to remove and re-install my JB4 a few times over the past few weeks, and I'm getting a little bit tired of unwrapping and rewrapping that sticky tape around the wire bundle. I was curious to see if anyone has tried placing a quick disconnect fitting in the JB4 can wires between the module and the big wiring bundle, so it's just plug and play. It seems like a simple electrical connection, but I know it gets finnicky already if the connection isn't solid, so I wasn't sure if this would degrade the signal enough to cause issues https://showbox.tools/.
To be clear, I'm talking about a connector along the lines of this:
Thoughts? I figure if I can't find a lot of info where anyone has done this it might not be the best idea, but I wanted to check anyway.
ckethe99 ckethe99 is offline
Car: 2014 335i
Default 02-11-2021, 06:39 AM
No, don't do this. Instead, upgrade from the CAN Wires which are not supported anylonger, to the OBD2 based solution which you can find here: https://burgertuning.com/products/jb...29178623098995
Home to the worlds slowest 335i !
2014 335i xDrive | ZF8HP | JB4, MHD w/ Custom E85 BEF (by @ckethe99), Evolution Racewerks Chargepipe, IC, and DP,
AFE Intake, MPE, N20 TMAP, and a lot of time on the garage floor!
Default 02-11-2021, 09:29 AM
This...^^^^^^^^^^
