luchocamp's Avatar
Default JB4 + BOOTMOD from 131 to 138 miles in 7 days - 10-07-2020, 02:55 AM
September 30th, Johnny m5_blackmonster contacted us and we started working with his installed parts.
F90 M5 Full Weight DP & Intakes Proyect Gamma and BM3 ots flash.
After reviewing and making various adjustments to the newly installed JB4, we dial in everything to eliminate throttle clousures and adjustment to fuel mixture, we continue to use his BM3 and JB4 above.
No WMI, No super expensive gasoline ... E85 and 93 octane mix for daily use, went from its best record of 10.53@131.6mph to 10.39@138.1mph
We know that with that speed we can do 10.0 to 1/4 so we continue with the advice.
Vamos con todo !
starting here :
last night :
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD
18 BMW XXXX Car in Process
luchocamp's Avatar
Default 10-17-2020, 02:33 AM
luchocamp's Avatar
Default 10-17-2020, 02:34 AM
luchocamp's Avatar
Default 10-18-2020, 04:39 PM
Keep improving using low budget fuel E30
luchocamp's Avatar
Default 10-19-2020, 06:37 AM
some better road test, difficult to achieve good 60ft low ambient temp and more hp....almost 110mph using same E30 fuel
luchocamp's Avatar
Default 03-09-2021, 10:18 AM
some updates, now with better E85 using same BM3 OTS 30 + JB4 custom map 6.
60 to 130mph 6.02
10.13@139mph with 1.65 on 60ft
Car full weight, all weather tires.
Probably could achieve a constant 9sec with better 60f in summer time.
luchocamp's Avatar
Default 03-10-2021, 07:03 AM
luchocamp's Avatar
Default 03-11-2021, 03:45 AM
YanoNardoM5 YanoNardoM5 is offline
Car: 2018 BMW M5 Individual Nardo Grey
Default 03-26-2021, 09:29 PM
Wow awesome. I need this for my F90!
Car: Stinger
Default 04-16-2021, 07:29 AM
Great Work. Can you share the map 6 settings?
luchocamp's Avatar
Default 04-16-2021, 10:05 AM
I could, but unfortunately I do not recommend transferring the settings from one car to another without having a clear idea of ​​other modifications and how to improve performance. It's not a good idea.
