alexpanteaa alexpanteaa is offline
Car: 2019 BMW M5 competition
Default BMS WMI Kit F90 Help - 10-07-2020, 06:50 AM
Hello, I've been running a stage 3 DME Tuning tune with the JB4 as a piggyback as well. On map 5 (27psi absolute profile) and Octane 100+ the car used to run 10.3-10.4 Quarter mile and 6.5-7 second 60-130s. After installing the BMS Meth kit with the MSR Racing meth plates that mount above the throttle body underneath the charge air coolers, the car seems to be running a lot slower. Best 60-130 I have gotten since I installed the kit was a 6.96 60-130 on octane 100+ and map 5 (27psi absolute profile) I am using the same nozzles and same parts, the injection location is just different, that's all. Anyone can advise me on what to do ? Does the DME tune possibly affect it ? I'll attach a picture of a the log for the 6.96 60-130. Please let me know, Thanks !
Default 10-07-2020, 09:59 AM
Post up the CSV!
Default 10-07-2020, 10:51 AM
Post up the CSV!
Here it is.
Default 10-07-2020, 01:18 PM
For kicks set meth trigger = 1 and log map3 for comparison's sake
Default 10-07-2020, 09:34 PM
Meth trigger was set to 1. Here is the CSV on map 3. Ran a 7.38 on this log
luchocamp's Avatar
Default 10-08-2020, 02:48 AM
Could you upload .csv when your car was running 6.5sec before the installation of Meth plates to compare.
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD
18 BMW XXXX Car in Process
Default 10-08-2020, 02:16 PM
Set FF to 60 and relog!
Default 10-09-2020, 12:08 AM
Set FF/Wastegate adaptation under User adjustable map to 60. Ran a 7.88. Attached is the CSV Log.
Default 10-09-2020, 12:10 AM
Here is the 6.75 log. Donít have the 6.5 one, got a new phone. This was back in the summer, so IATs were higher. Iím located in Michigan so the weather now is around 50-60į F. The car was not on meth at this time, just octane 100+ and 27psi map
File Type: csv P24_M5_R1_200830_212820 6.75 60-130!!.csv (9.5 KB, 70 views)
Default 10-09-2020, 01:01 PM
It's back to map7 which is running stock boost levels with your additive = 0 settings...
FF = 60, map3 log.
Default 10-09-2020, 02:42 PM
FF = 60, map3 log.
Hereís map 3 again. 7.66
