ExParrot ExParrot is offline
Car: Genesis G70
Default Stock G70 6MT Pinging - 07-27-2021, 09:53 AM
Has anyone else experienced pinging on the 2.0T engine in either a G70 or Veloster N? The car is bone stock, but pings every now and again at around 2000-2300 RPM and moderate load on the accelerator when going up hill. Car will ping anywhere between 1 and 4 times successively and then it feels like it pulls timing or boost. I only run 93 or occasionally 91 if that's all that's there for premium. Only 11k miles on the car. Dealer has so far been "Unable to replicate". Should I be looking at colder plugs?
Chanluder's Avatar
Chanluder Chanluder is offline
Car: Stinger
Default 07-27-2021, 02:14 PM
Got any log?
Car: Genesis G70
Default 07-27-2021, 02:33 PM
Originally Posted by Chanluder
Got any log?
Not yet, but I'd like to. I have not pulled the trigger on a JB4 or other tuner yet - at this point with it pinging at stock levels, I am hesitant to. Any recommended tools for datalogging through the OB2 port?
KillerBeeAirsoft's Avatar
KillerBeeAirsoft KillerBeeAirsoft is offline
Car: 20' G70 3.3T
Default 07-27-2021, 05:33 PM
Have you checked your oil between oil changes? If so , has been been consuming any?
Car: Genesis G70
Default 07-27-2021, 05:39 PM
I check oil every couple thousand miles, little to no consumption over the 6k mile interval.
Car: 20' G70 3.3T
Default 07-27-2021, 06:17 PM
Well that’s good!
What brand gas are you using?
Car: Genesis G70
Default 07-28-2021, 04:36 PM
Well that’s good!
Mobil, Sunoco, EXXON, sometimes KwikFill. Usually try to stick to Top Tier
