AmarN54 AmarN54 is offline
Car: 11' Z4, 11' M3
Default Stock F10 M5.. JB Stage 1 or JB4 + BCM? - 09-28-2015, 11:26 PM
Hey guys! I have a stock F10 M5..
Not going to do much more than a new exhaust (only mufflers... MAYBE DP's down the road)
I read through all 11 pages of the BCM/S63TU tuning thread and no one answered/asked the question...
Can I run JB4 + BCM and run map2 to get the 22psi target or would I run Stage 1 and add 5psi using the datalogging cable?
And to add on, I know the clutches slip in between shifts with 22 psi and higher... is it worth the extra $650 to get the JB4 + BCM if I have to then deal with a slipping DCT during gear changes.
I understand it has all the data-logging capabilities and whatnot.. but I'm more interested in power. I know that stage 1 runs 18psi if I'm not mistaken?
Thanks guys!
Z4 35is - JB4 and that's it.
Stock time: 12.768 at 108mph.
Tuned time: 11.935 at 116mph.
Default 09-29-2015, 10:24 AM
The BCM is not an easy install. But if you're able to do installs yourself in your home garage then definitely go for the JB4+BCM route. If you have to pay a mechanic I'd just stay Stage1.
SkyDan SkyDan is offline
Car: 2014 M6 Vert
Default 10-20-2015, 08:30 AM
I have stage 1 installed and I am interested in stage 2 + BCM. Do you have install partners near 10309? 2014 M6. Thanks.
Car: 2014 M6 Vert
Default :bump: - 10-22-2015, 08:38 AM
Nothing for me? Legitimate customer here.
lfelunden's Avatar
Car: 335i e92
Default 10-23-2015, 02:42 AM
SkyDan,
It all depends on your fuel tbh. I ran the Map 2 on my car with dp and full exhaust - moved nicely. But if you want something that adds power, the stage 1 is a good way to go
