(#76)
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 10-04-2015, 08:51 AM
All,
Some of you ask me whether I am happy or not with Trebila custom flash works. Here is my answer below. Hope this helps.
David ( Trebila ) is very knowledgeable and extremely helpful. I recommend a custom backend flash versus any off-the-shelf flash, *especially* with a twin turbo application. After this tune, there was a noticeable increase in power, and the driveability is even greater than before. David's tuning style focuses on squeezing the most out of your individual application while maintaining maximum reliability and safety. Have not had any hiccups whatsoever after 5000+ miles on his tunes. Hands down my favorite purchase towards my 335xi.
Do more with less !
montyp86 montyp86 is offline
Default 10-10-2015, 09:37 AM
Being new to this kind of tuning, the car i purchased being set up so poorly (random ecu flash stacked with JB4), and having an EU spec car further complicating using the US spec back end flashes widely available i decided to give Trebila a shout for some hep.
I have only tried the first custom .bin and his recommended settings so far and i am VERY happy. Car is hugely improved, logs look much better. Looking forward to flashing V2.
David replies to almost every email within minutes, and is extremely helpful. The best value mod you can make to your car (if you don't know what you are doing, like me) is get this man to make you a custom back end flash!
2008 135i M
JB4, Alpina trans fash, Trebila Custom flash, P3 gauge, BMS DCI, BMS ***, VRS 7" FMIC, VRS CP, Tail BOV, BMS Wheel Spacers, BMS oil catch can, KW V1 coilovers, E92 M3 front and rear lower control arms, BMW M3 Anti roll bars, Quaife Limited Slip diff, Custom Quad exhaust
Car: BMW E90 335XI
Default 10-10-2015, 09:40 AM
Exciting ! Post a csv please.
Do more with less !
Default 10-10-2015, 09:50 AM
CSV's as requested
2008 135i M
Car: BMW E90 335XI
Default 10-10-2015, 09:58 AM
With only intercooler iat suppression is not well enough to enhance the cooling weather which the turbos like the most. . Iat was raising up at the end of the logs and that induce a bit high avg ign retard , but not that much important. Timing is fine to me. Trebila is perfect to determine the things. Try using methanol with dual cm7 nozzle to reach higher boost levels. If you don't have fueling limitations, He can do more with less !
Do more with less !
Default 10-10-2015, 10:04 AM
I cant decide if i want to run Meth or not. Lots of hassle, plus insurance issues, and its my daily drive. Think i will save up and get pure turbos eventually, more power but still stealth under the bonnet for insurance purposes!
2008 135i M
Car: BMW E90 335XI
Default 10-10-2015, 10:10 AM
If the matter is the longevity of your engine , meth and water are a must, but I am unsure about your insurance though. . But it worths to do a meth kit in your car even if you don't want to use it except doing a race roll. But keep in mind that , in summer it greatly helps for iat suppression. You can use it with dual cm7 for higher boost levels safely , and also you can use it with single cm5 nozzle spraying only distilled water for sensible iat's. I did All these comments considering you don't have access to E85 in your area.
Do more with less !
trebila's Avatar
trebila trebila is offline
Default 10-10-2015, 10:52 AM
Originally Posted by montyp86
CSV's as requested
first try with my pump bin with straight 93 pump gas (no meth, no ethanol), stock knock tables untouched, next step is raising the boost.
ThreeDirtyFive ThreeDirtyFive is offline
Car: BMW E92 335i
Default 10-10-2015, 12:13 PM
Good job
tc535i tc535i is offline
Car: 95 M3, 01 330i, 07 335i
Default 10-10-2015, 05:42 PM
I'm really putting this guy to work, sent him logs on crap 91 octane at 100F ambient today... must have seemed like a practical joke!
That said he's been very responsive to my emails and getting me new maps back immediately with our discussed changes. 91 octane is quite a puzzle but he's putting the pieces together very well.
abailey269 abailey269 is offline
Car: 2008 BMW 535i
Default 10-10-2015, 06:33 PM
I just wanted to give my two cents and mention how happy I've been with both the results and the customer service from David. I highly recommend him to just about anyone. He's extremely patient and helpful with any requests. He's very responsive and is great at explaining things when needed.
I can't say enough good things about him and his custom tunes
2008 535i 6AT | JB4 G5, DCI, ER FMIC, ER CP, VRSF ***, e70 mix, BMS 2.3 Gal Meth Kit, Custom Trebila Flash, FuelIt Stage2 LPFP
432rwhp 466rwtq
12.7@115mph, 2.1 60' on Toyo All Seasons. Boost limited to 12psi in second, 19 in 3rd & 4th.
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default 10-11-2015, 06:34 AM
All I can say is Trebila is a god send. I have been working with him tunewise for over a year now. And he makes me feel that my car is the only car he is personally tuning 24/7. And only he knows how fussy and pedantic I am...lol
Can't really ask for much more than that
Looking forward to seeing what you can do with my Pure Turbos Stage 2 and RB inlets when it arrives David!
Cheers
2009 N54 335i coupe, 6AT PD trans, Stage 3 XHP, Built Motor, 9.6:1 Comp Ratio, Ported Head, Trebilia Custom Flash, JB4, Mhd flasher, Ngk 97506 0.018 gapped, PI Kit 100% E85, Jb4 PI integration, Stage 2 Pure Turbos 25.6psi, 17.2 deg timing, TFT inlets, Stage 3 Fuel-it Fpr, FBO, 431rwkw Mainline Dyno Aus
2016 M4 Competition Pack, 7-sp DCT, Jb4 Map 6
25.0 psi, s55 ign e85 Bef, E70, M4 plugs gapped 0.020, stock everything else, 374.9 rwkw Mainline Dyno Aus
trebila's Avatar
Default 10-13-2015, 08:26 AM
Thanks guys, I'm doing my best
another EU FBO 335i MSport Highline DCT, stock turbos and stock inlets, with E30 and 2xCM7 nozzles:
Actual Torque seen by the DCT is maxed out at its limiter, for the higher clamping pressure physically available.
Next step: an upgraded LPFP and upgraded inlets to have more room for more boost.
Default 10-13-2015, 08:42 AM
now that's a pretty log!
sorry for the delay on my side, Los Angeles is still pushing 100F temps so it's tough to get you good info right now
hell, it's already 84 and it's not even 9am
Bullitt1841's Avatar
Default 10-13-2015, 12:44 PM
Why in the world are you running 91 octane in LA? There are plenty of E85 stations close by if you're not in downtown. Even West LA has a station right off the 405.
2018 Audi RS3 | APR Stage 1 E85 | JB4 | APR FMIC
SOLD: 2017 F36 440i Gran Coupe | PS2 | JB4
SOLD: 2007 E90 335i | PS2's | JB4 | 160k+ miles on the car, 120k+ miles on the JB4
Default 10-13-2015, 12:55 PM
Yup, it's 4 miles from me... which is 1/2 hr round trip at any normal hour
I just don't have the free time to do it every fill up, or any real reason to run more power than I can put down on my 95% city street driving
I just want to get a clean log for the fuel I run, not sure what the problem is?
Default 10-14-2015, 07:43 AM
No problem, just giving you **** because I hate 91 octane that much compared to E85,
Sorry to get off topic!
Default 10-14-2015, 08:22 AM
moving to washington in a month or two, so at least I'll have cooler air and slightly more octane soon
trebila's Avatar
Default 11-02-2015, 03:23 AM
update
now tuning custom hybrids with really slow spool, mostly as a single but can handle high boost up top, also as a single (boost below is far from max wgdc).
tweaking VANOS/timing/AFRs during spool made a huge difference in spool:
in green and blue: previously
in red, after VANOS/timing/AFRs tweaks:
to be continued
elijahcole92 elijahcole92 is offline
Car: 97 Supra
Default 11-02-2015, 05:53 AM
update
to be continued
Looks great David! Do you think these tweaks would be beneficial on regular rbs or similar setups? I'm willing to test them out if you need more data.
trebila's Avatar
Default 11-02-2015, 06:02 AM
do you have a slow spool with your RBs, Elijah ?
It's usually for big singles, but you can give it a try on your RBs if you feel them slow to spool.
Car: 97 Supra
Default 11-02-2015, 06:14 AM
Slower than i'd like
I'll shoot you an email.
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 11-02-2015, 07:51 AM
update
to be continued
Looks like my advice paid off
trebila's Avatar
Default 11-02-2015, 08:01 AM
Hi Jake
does mine paid off also ?
Car: BMW E90 335XI
Default 11-02-2015, 03:10 PM
Hi David ; is there any benefit for pure turbos, Could you give more informations please ? What makes this better your innovation sir ?
Do more with less !
