(#151)
h1dden87 h1dden87 is offline
Car: 2019 Stinger GT
Default 10-12-2020, 10:49 AM
Originally Posted by AWDGT2
Is this a Stinger or Hyundai?
Stinger 3.3
Default 10-12-2020, 01:28 PM
Looks like you have fewer timing corrections under meth flow at 20psi than you do without at 14psi.
If you're trying to tune for no timing corrections you'll be leaving power on the table but just lower the WMI additive as needed.
neonland neonland is offline
Car: kia stringer
Default 10-16-2020, 08:25 PM
Going into first winter with Meth.
Anything I should be aware of any additional risks?
I assume you lose much of the IAT benefit but retain knock reduction due to added octane?
Meth is more than just an IAT reducer right? It is added fuel for added boost?
Default 10-17-2020, 12:51 PM
Run at least a 50/50 mix to avoid freezing other than that works basically the same. Turbos still generate plenty of heat in the winter.
bbrillon998 bbrillon998 is offline
Car: Stinger GT AWD
Default Today, 08:27 AM
I have a WMI question, On multiple 1/4 mile runs testing map 7 @ 75 additive 50/50 mix (just boost Juice for now) The car consistently trapped 109 MPH speeds over and over again on multiple test days at the track at various temps ranging from 88 to 53 outside. That's nice from a consistency stand point but, what's stumping me is running map 3 when the car is cooled off will trap 110 mph + on the same day with the 91 + E85 E30 mix.
What gives ? I really like the cooling WMI provides I can see the IAT drops in the logs but why is it coming up short on power compared to non meth maps ?
Im sure I ironed out WMI flow issues/ bubbles in the line etc.
Do I have to go onto higher mixes of Meth to water ?
Dial down additive or set meth trigger 1 and use on map 3 for example ?
wardyl36 wardyl36 is offline
Car: Kia stinger gt
Default Today, 09:05 AM
I also am seeing similar things, what are the mods you are currently running, highest I've trapped is 112?
Default Today, 02:10 PM
Can't do anything with this log. Need the original JB4 CSV to open in the JB4 software.
Car: Stinger GT AWD
Default Today, 04:10 PM
Just the brake snip, JB4 With WMI- fuel wires & AEM panel filters.
The car can trap solid 112s on map 3 on a nice cold day on the draggy and on WMI map 7 in the same conditions after that run its 109.XX everytime.
CSV files fixed attached wrong files before.
Default Today, 08:40 PM
Looks like high elevation? That explains why traps speeds are down overall from what we'd expect.
What fluid are you injecting? Trims are not dropping under WMI flow as I'd expect. Since timing is solid on map3 already, and IAT looks good, there would be minimal benefit for WMI for you in this situation.
