AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default Meth turning off slowly? - 05-27-2019, 12:28 PM
has anyone encountered a situation where meth appears to turn off quite late after throttle closure?
Any suggestions for the cause or a fix?
AWSAWS's Avatar
Default 05-31-2019, 03:58 PM
Bump
Still having issues.
codesx's Avatar
codesx codesx is offline
Default 07-22-2019, 02:12 PM
Subscribed.
AWSAWS,
How long did it run over? (I was unclear from the image)
Did you get this resolved?
In theory, I'd like mine to run for 1 - 2 seconds after, just to help cool for the extended time.
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
