AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default dual catch cans - 04-30-2019, 04:25 AM
I've had a BMS catch can installed for well over 2 years. Probably for about the same amount of time I've seen people championing the dual catch can setup, catching oil recirculating under low or no boost situations. I don't intend to plug the port holes. Is it still worth installing a second catch can if the ports aren't plugged?
I've looked at lots and lots of posts. Can someone explain simply, where this second catch can setup connects. Thanks
DeepEddy's Avatar
DeepEddy DeepEddy is offline
Car: E92
Default 04-30-2019, 09:15 AM
Next to flapper valve where pcv is
DeepEddy's Avatar
Car: E92
Default 04-30-2019, 09:17 AM
The fitting i have blocks the passage so u do not need to tap and block ports , but I did anyway
DeepEddy's Avatar
Car: E92
Default 04-30-2019, 09:21 AM
AD Engineering N54 8AN Crankcase Breather/PVC Delete Fitting
Default 04-30-2019, 12:06 PM
Wait for our Dual OCC kit, no need to plug the ports on the head
Rob@RBTurbo's Avatar
Stalker
Car: 335I
Default 04-30-2019, 12:14 PM
Please, not this again...
There is never a NEED to plug the head ports. It is just a damn good idea, otherwise you will have pressure/vacuum exposure ALWAYS on the valve cover/valve cover gasket where it is otherwise avoidable and unnecessary. In short it IS ALWAYS a great idea to plug these ports whenever you can, whether you are going to VTA or running External PCV.
Rob
