drcardenas drcardenas is offline
Default Best methanol/water mix for bms mwi kit - 04-23-2019, 12:46 PM
2007 335
FBO
JB4
BMS WMI kit, single nozzle
I am currently using a 50meth/50water mix on map 3 and it is running good.
A performance shop has 70meth/30water mix available and I am wondering if I should give it a try.
Is the 50/50 mix the best? Or should I give 70/30 a try. Don't want to damage the engine. Thanks for any imput!
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 04-25-2019, 12:53 AM
I don't think there is specific answer as it depends on your boost target on the map 3 adder and how your timing and avg ign looks like, colder season I run 60/40 or 70/30 and hot season I run 50/50. in short with higher meth I'm able to get higher adder boost and more meth support the octane, with higher water I'm able to keep my timing and intake temp happy.
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 04-26-2019, 10:03 AM
In various scientific tests, 100% meth gave the best performance but it was marginally better than a 75:25 meth:water mix.
If you want more cooling and cost effectiveness, add more water. Up to 50:50.
If you want more performance but at a higher cost, add more meth. Up to 100%
Of course you can do your own testing. Do some logs with various mixes. See how your IATs are. See how your cylinder timing is. Use the free (PC) version of virtual dyno to impor your JB4 logs and see what's producing the most power.
Default 04-26-2019, 12:28 PM
Thanks for your replies!
Very usefull to me as I am a very basic beginner at this .
Will try that pc version of virtual dyne.
Thanks again .
