(#76)
E30 Racer E30 Racer is offline
Car: 1M
Default 08-20-2019, 04:47 AM
Now that some of these kits have been used for a while, can some users comment on how much oil the BMS OCC is catching (i.e., in the vacuum side application)?
BIMMIN BIMMIN is offline
Car: 2009 335i AT
Default 08-20-2019, 07:01 AM
I cant comment on this design, but it pretty much mimics the RB external setup. I do have that one, it gathers a quarter of the can every 2k miles or so. The high side continues to be dry and near useless
2009 E92 335i AT
Engine
Rev9 Hybrid 16t twins, Injen cyborg intake, CP-e charge pipe with HKS SSqv BOV, RB external PCV catch can, BMS catch can, Cobb intercooler, HKS Legamax exhaust, RB inlets, VTT single barrel hpfp, fuel-it! stage 2 lpfp, MOTiV Flex fuel flash only w/ trans tune by Cedar Performance
558rwhp and 523rwtq on e60 110* ambient air
Mendozaz31's Avatar
Mendozaz31 Mendozaz31 is offline
Car: 07 335i
Default 08-24-2019, 06:17 PM
Hello I just installed my OCC for the low side it’s a great fit but I have question. I currently have the Phoenix intake and I tried using one of of the vacuum ports but there is not enough space to install the check valve (it touches the starter).My question is if I can get my vacuum from my charge pipe at least while I get the throttle body adapter. Thanks.
07 335i
Jb4mhdbackend,VRSF7.5steppedFMI,Index12injectors,V RSF Charge pipe,Tial bov,Fuel it ethanol kit,Fuel it stage 2 bucket pump,Xhp stage 3 auto,(2)BMS CC vac/boost ,NGK Plugs, Phoenix manifold, Port injection, VRSF 3.5 Exhaust, Custom down pipe, BMS Trans cooler, MSD81ecu upgrade, Eldor coils, LSD conversion, On 3 single turbo 67/64, Tial 44 Wastegate.
Default 08-26-2019, 02:05 PM
Originally Posted by Mendozaz31
Hello I just installed my OCC for the low side itís a great fit but I have question. I currently have the Phoenix intake and I tried using one of of the vacuum ports but there is not enough space to install the check valve (it touches the starter).My question is if I can get my vacuum from my charge pipe at least while I get the throttle body adapter. Thanks.
1/8 NPT M to F adapter might work to leave it on the intake manifold.
Maybe something like this?
EATON WEATHERHEAD Hydraulic Hose Adapter - 20KF683400X2 - Grainger!
Mendozaz31's Avatar
Car: 07 335i
Default 08-26-2019, 02:29 PM
Exactly what I used. Thanks.
07 335i
Default 08-26-2019, 04:35 PM
nyt nyt is offline
Car: 335ix
Default 10-22-2019, 03:30 AM
You couldn't mill these down a bit more so those of us that like to keep the stock cowl don't have to modify?
After making these adjustments to each clamp, the stock cowl now sits nicely.
2010 335ix - speedtech 6466g2, cams, ported head, built bottom end, 7.5in hd ic, jb4, pi, fuel-it stg3, upgraded 6hp21+cooler, pr coils
Default 10-22-2019, 04:09 PM
Thank you for the info. Let me see what we can come up with.
We have a few thousand of those made
faffo faffo is offline
Car: E93 335i
Default 11-19-2019, 04:26 PM
this OCC kit will be available in some shops for europe? i'm from italy and i can't found it
Default 11-21-2019, 01:49 PM
We ship to EU daily just order off our site! Shipping cost is pretty reasonable.
I think most EU dealers are not stocking it yet since there are so many options it's a PITA for them to stock each variant.
