ferocious's Avatar
ferocious ferocious is offline
Car: 335i N54 2008
Default Ford o2 Sensors on N54 (They Work) - 03-06-2019, 11:42 PM
I thought i would share this with everyone,
Im not sure if this has been mentioned before but its new to me..
our local N54 guys have been installing FORD Motorcraft o2 Sensors part # DY-1184 for bank 1 and bank 2 (the ones that connect beside the valve cover to the harness)
on the Single turbo DOC kit the wire harness is long enough
not sure about the other kits tho
and accordingly they work with no codes and read well, AFR Trims and all..
the cost for each is around $60
what do you guys think?
not sure about the life expectancy especially on a ST setup
2008 335i N54 FFtech Top Mount single turbo Precision 5862
JB4 G5 , VRSF 7" FMIC , VRSF CP + HKS BOV, Tial Wastegates
BMS METH KIT IN CONJUNCTION WITH MMP PI WITH 1055CC INJECTORS, PURE M1 METH,TMAP 3.5,
FUEL-IT STAGE2 BUCKETLESS LPFP, RB PCV. CUSTOM TUNE, xHP Stage2 v1.5
more to come...
Car: 2003 Forester
Default 03-07-2019, 05:09 AM
Ford doesn't make O2 sensors. It's just a major manufacturers with Ford labeling. Like my VDO water pump has a BMW symbol and PN on it.
It's a "Bosch" LSU4.9 wideband. Literally any one from any car will work unless they changed the plug.
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 03-07-2019, 09:35 AM
True, but there are Bosch 4.2, 4.9, and ADV sensors. I think its important to know which ones these are to make sure they are calibrated properly. What do they come out of? I think 4.9 came out in 09 and ADV more recently.
09 335 - 6266
07 335i - 6870, E85 - SOLD
Car: 2003 Forester
Default 03-07-2019, 11:54 AM
True.
Look at the picture again.
Ford Emblem
Ford part number
Bosch part number
Bosch emblem
Type the Bosch part number into Google
PAH!
A reverse lookup of the Ford part number will tell you what it goes in. Minus pigtail length every 4.9 sensor I've every actually seen is exactly the same. I used a "VW" one as a replacement sensor for my PLX wideband in my Mitsu. Was like $40.
tks535i tks535i is offline
Car: 08 535i 6spd
Default 03-11-2019, 10:06 AM
So you are for sure that the Motorcraft o2 Sensors part # DY-1184 fit directly onto an 08 E60 535i N54? Do these work for all 4 sensors? Just the upstreams? Just the downstreams? They have the same connector? No splicing needed?
Dayton, Ohio
2008 E60 535i 6speed Sport Suspension
JB4, MHD BEF, DCI, D0wnp1pes, 7" VRSF FMIC, CP and BOV, H20/Meth Injection, Stage 2 LPFP, OCC
ferocious's Avatar
Car: 335i N54 2008
Default 03-12-2019, 12:13 AM
both upstream sensors, the bottom ones are different
yes the connector is the same, and the sensor will fit also.. but according to wiring it depends if you need to extend or not.
on single turbo DOC kits on 335 and 135 no extension needed, but for twins i think you should
here is a video to help you get a clear picture regarding wire extension, you can use your old sensor wiring as they are the same diameter and ohm tolerance
How to Extend Oxygen Sensor Wires - YouTube
more to come...
Car: 08 535i 6spd
Default 03-12-2019, 04:01 AM
Attachment 84423
Awesome. I am going to go for these to save some $$$. Have anywhere to buy for the best price?
Dayton, Ohio
ferocious's Avatar
Car: 335i N54 2008
Default 03-12-2019, 04:11 AM
for example :
MOTORCRAFT DY1184 SENSOR,OXYGEN | eBay
more to come...
Island Road Island Road is offline
Default 03-14-2019, 12:43 PM
My understanding of this is you should not splice wideband sensors. Reasons being is a wideband (5-wire) sensor connector has a resistor that is calibrated to the wide band output in the plug. Splicing to use your existing connector would result in a improper sensor calibration. While it will work the AFR readings to the ECU might be incorrect. I am not sure by simple just extending the wires using the same connector would be an issue but I would not risk it.
Also Bosh makes a lot of LSU4.9 wideband sensors, more than likely the "DY-1184" is not the only sensor that will work. BOSCH 17098 can be used for both banks the part number difference is for different cable length. I just bought some NTK O2s to replace all my senors. A lot of ST guys went with NTK seems as though its a high quality sensor that also last longer and corrected a lot of users issues from ADV. If you are looking for replacements I did all 4 for under 200 just need to look for the deals.
ferocious's Avatar
Car: 335i N54 2008
Default 03-26-2019, 04:14 AM
Hi Island Road,
can you help me out with the part numbers of the N2k sensors for my N54 335i 2008
thanks
i might consider them for next time
more to come...
Default 04-05-2019, 10:12 AM
Hi Island Road,
thanks
I have a E61 so they are going to be Slightly different aka Wire Lengths but just go in the NTK/NGK site via Part lookup and it will provide the part numbers.
07335i's Avatar
07335i 07335i is offline
Default 04-13-2019, 08:41 AM
Hi Island Road,
thanks
NTK - 24322
NTK - 24345
also I think, you can use bosch 17187 which is same part number with ADV sensor .
ferocious's Avatar
Car: 335i N54 2008
Default 04-14-2019, 01:09 AM
Originally Posted by 07335i
NTK - 24322
NTK - 24345
much apreciated
thanks
more to come...
Maniac0908 Maniac0908 is offline
Car: 07 BMW 335xi JB4 G5 DP DCI BOV
Default 04-21-2019, 01:26 AM
Nice find! Will have to do this
2007 335XI SEDAN // ACF/VM 6266 SINGLE TURBO// MMP PORT INJECTION // VRSF CP W/ TIAL BOV // XHP 6AT FLASH // MOTIV TUNED // BMS OCC // VRSF EXHAUST // DIY STAGE 3 LPFP// VRSF FMIC //
Gonza335i Gonza335i is offline
Car: 08 bmw 335xi
Default 08-13-2019, 02:27 PM
Anyone try this yet? and on what website did you find those deals, I have been looking and haven't found any. Also which part number is for which side ?
DeepEddy DeepEddy is offline
Car: E92
Default 08-13-2019, 06:03 PM
I bought two Bosch 17098 (bank 1)for $67.99 on Amazon for my single turbo.this was cheaper then the ford option , I checked everywhere
Car: 08 bmw 335xi
Default 08-14-2019, 11:40 AM
Yeah I found those, the code I have is for the rear after *** 2C7B
Car: E92
Default 08-14-2019, 12:19 PM
u can always upgrade to single turbo and not have to deal with two seprate o2 sensors. Or just extend the engine harness so it will reach
Did that on a buddy's car and worked out fine instead of messing with the o2s harness
