Ke90 Ke90 is offline
B58_Dude
Car: M240i
Default Which BEF for E60+WMI - 07-30-2020, 02:08 PM
Which BEF do you use for E60 blend w/ WMI kit installed?
Currently using: JB4_BEF_E40-E60_1.BIN
The other options that I seen are:
JB4_BEF_E85_WMI
JB4_BEF_E85_WMI_4_TEST
The other BEF are either for pump WMI or Upgraded turbo.
Also, after reading install guide settings are still as follows:
Boost Additive: 40 (Can start higher w/ E85?)
Signal Scaling: 60
Min Flow Boost: 9
Only big upgrade I got is Dorch St. 2 HPFP.
Default 07-30-2020, 11:16 PM
Post a log of your current setup.
You would go to the newest e85 wmi one and get us some logs to compare
B58_Dude
Car: M240i
Default 07-31-2020, 08:21 AM
Here is a current log.
Gas: E60
Map:3
Mods: Dorch stage 2, Catlles DP, BMS intake.
Default 07-31-2020, 06:44 PM
What WMI kit? It's showing a flow signal off boost so that is an issue.
B58_Dude
Car: M240i
Default 08-01-2020, 06:42 AM
I do not have the WMI kit set up yet. I misunderstood when he said post a "current log", he meant with kit installed.
All I really wanted to know was which BEF to use for E60 and WMI when I install it? The WMI is Terry's kit to go with JB4.
Can I stick with the E40-E60 BEF and just run WMI with it? or do I have to flash it one of these:
JB4_BEF_E85_WMI
If so which one?
Can I still use E60 or do I have to run full E85?
Sorry for misunderstanding and thank you for help.
