Divian Divian is offline
Car: M235i
Default M235i - Low power - Map2 - 03-04-2017, 04:11 AM
I am new to BMWs and drive a M235i with the following mods:
DP
Intake
JB4 (no EWG wire)
95oct
I did dyno the car with just DP and intake and the readings were 213kw and 420nm, after JB4 on Map 2 on the same dyno it makes 225kw and 450nm.
Please can you assist with reading my log and helping understand what the problem is.
hubblyking's Avatar
hubblyking hubblyking is offline
Car: N55 135i
Default 03-04-2017, 12:27 PM
Hi divian are you from south Africa?
Your intake Temps are getting up there .You will probably need a upgraded intercooler or meth.
You will need to up your octane for that map aswell.
Car: M235i
Default 03-04-2017, 12:40 PM
Hi Hubbly,
Thanks for the feedback.
Yes i am from SA. Yes i plan on doing meth. I suspect the car needs new plugs. it will be going in for a service this coming week.
hubblyking's Avatar
Car: N55 135i
Default 03-04-2017, 12:56 PM
Why don't you add nf ,give it time to adapt and relog.The fuel quality in SA sucks so rather stick to map 1 or map5 with 95(91oct).
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 03-04-2017, 01:01 PM
Map 2 on our sh*tty South African fuel is not going to work as proven by your elevated AVG_IGN values. Our 95RON is equivalent to US 91.
I'd suggest getting the EWG harness, leaving it on Map 5 and adding NF if need be.
2016 F22 M240i | 8ZF
Car: M235i
Default 03-04-2017, 09:44 PM
awaiting delivery on the EWG wires.
Switched to Map 1, car feels the same as Map 2 if not better.
claude1604's Avatar
claude1604 claude1604 is offline
Car: f30 335i
Default 03-05-2017, 02:05 AM
i think maybe add some ethanol, I would say start with 15% by volume and work you way up. The stock fuel system will be ok with low volumes of eth. I am personally not a big fan of NF.
F30 335i | BMS JB4 | ER ***** DP | Akrapovič Exhaust | ER FMIC | BMS Intake | ER CP |Platinum Fuel-it TBI-Kit (triggered via FSB) with inline ethanol sensor | Fuel-IT LPFP Stage 3 | Pure stage2 Turbo| Pure Turbos Intlet | GFB DV+ | RennZport boost pipe | RennZport Thermostat | Bootmod3 BEF | N20 gapped plugs |
N54 135i | FBO with JB4 and MHD BEF|
Default 03-06-2017, 10:13 PM
Not a very good log. Looks like you hit a bump in the middle of the log causing you to pull timing. Try another log and lower your FOL to 40.
Car: M235i
Default 03-07-2017, 02:58 AM
Thanks for the feedback Steve.
i will make the change and re-log.
Default 03-07-2017, 07:05 PM
