sparky_phantom sparky_phantom is offline
Car: 2011 BMW 135i DCT
Question Ghost Cams MHD - 01-09-2017, 09:44 AM
Will there be this for the N55? I know the N54 has and I was curious. Have only had MHD and JB4 for a small amount of time.
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 01-09-2017, 12:31 PM
light your car on fire, it's a better mod.
Weehe Weehe is offline
Default 01-09-2017, 01:07 PM
Just go into tuner pro and change the vanos values at idle to more overlap. Can have the lumpiest idle then.
fryj00's Avatar
fryj00 fryj00 is offline
Car: 2011 e92 n55 xDrive 6MT
Default 01-09-2017, 02:08 PM
2011 E92 N55 xDrive 6MT
1slowN55 1slowN55 is offline
Default 01-09-2017, 08:52 PM
Lmfaooooo
2011 N55 335i E92
PURE STAGE 2 FBO
JB4+BMS MHD BEF E50
FX500 Clutch
KevinC39 KevinC39 is offline
Car: 335i 6MT RWD
Default 01-10-2017, 11:40 AM
This is the first I've heard of this so I looked up a bunch of videos on YouTube. If we're going purely on noise from tuning tricks, this is a heck of a lot cooler than the PPK pops and bangs everyone seems to have a hard on for.
Default 01-10-2017, 01:39 PM
****ing up your afr at idle to sound like a massive vacuum leak sounds good? Ok...
Car: 335i 6MT RWD
Default 01-10-2017, 03:17 PM
Do I think it sounds better than a backfiring old truck with a rusted off muffler, yes.
bradsm87 bradsm87 is offline
Car: E90 LCI 335i
Default 01-11-2017, 01:31 AM
THANKFULLY, this would be very difficult to do on the N55 because it uses valvetronic so duration and lift is very low at idle.
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 01-11-2017, 02:10 AM
2016 F22 M240i | 8ZF
carguy19 carguy19 is offline
Car: 335 cpe
Default 01-11-2017, 10:25 AM
The ghost cam adjustment in the tune is designed and sounds just like a muscle car with a big cam in it. I don't know if you have ever heard it, but it certainly doesn't sound like a vacuum leak and doesn't mess up the AFR.
Not everyone likes the sound, and to each their own, but if you know the sound that it mimics from a high performance big cam in a muscle car, it is very close to the same sound.
Element's Avatar
Car: BMW 135i N54
Default 01-11-2017, 10:38 AM
Except that:
1) It isn't a muscle car.
2) The sound is not the result of an aggressive cam change.
So essentially it's for posers and should be mocked accordingly.
Car: 335i 6MT RWD
Default 01-11-2017, 10:45 AM
I feel it's no different than PPK. There's no performance reason to have the pops and bangs. It's just for show.
Car: 335 cpe
Default 01-11-2017, 10:56 AM
Except that:
Like I said, to each their own. I personally wont have it in my car.
I have a 14 GT500 with big cams in it, so I dont need my daily driver to sound like the GT500 'should' sound.
Default 01-17-2017, 04:12 PM
I know all the hate lol. Does the DIY for ghost cams work for the N55 or is it just N54? I assume it would work because I don't think Vanos changed between the engines. Anyone have any insight on this?
Default 01-17-2017, 04:52 PM
N55 vanos range is different than N54. Just set intake and exhaust vanos to the lowest number at 20-25 load. Should give the lumpiest idle.
Default 01-17-2017, 04:57 PM
I am still getting used to the whole tuning with TunerPro. The DIY shows to change the top bar of 13.5 to 40.0 all to 100 and similar for the exhaust idle warm up at 101.6 Should these be 20-25 or am I getting this backwards?
Ozzie335i Ozzie335i is offline
Car: 2011 335i Coupe
Default 01-17-2017, 06:54 PM
If I had your GT500 it would be my daily driver while my he man 335i garage queen waits for the weekend.
Default 01-17-2017, 07:00 PM
I have no interest in trying this, but know people will try. I don't know what vanos tables do what, since there are so many. But I would look into the vanos IN and EX warm idle and idle 2 tables. Decrease all values by 15 to start. The lower you go, the more valve overlap, the lumpier the idle.
Car: 335 cpe
Default 01-21-2017, 10:13 AM
My GT500 could not be driven daily with the drag radials and 778 whp. And my Porsche is worth too much money to be driven more then a few hundred miles a year (1997 993 Twin turbo 28K miles)
Besides, my 340xi is leased, not a limited production car that will be worth more money in the future, and I use it every day pretty much, I have a company car too as well so I get to use a variety of different cars (I run a Maserati/Alfa Romeo dealer, and we have a good amount of used exotic cars that I slap a plate on and drive on the weekends when the weather is nice). The GT500 would be too loud, too much exhaust fumes, to sketchy in the rain and bad weather and definitely not as comfortable as the BMW or whatever car I have from work.
fostergfx@gmail.com's Avatar
fostergfx@gmail.com fostergfx@gmail.com is offline
Car: 2012 bmw 335i
Default 07-19-2017, 05:30 PM
dont mean to hijack but can you raise the idle with this program? from 600 to lets say 800
2012 BMW 335i F30 N55/6MT
JB4 | BMS Intake | ER Charge Pipe | VRSF ** | VRSF FMIC | E85 | NGK Plugs | MFactory FW | 335is Clutch | 255/40ZR18 Michilen Pilot Super Sports
Default 07-19-2017, 05:56 PM
From what I understand yes, but only if you have the N54. N55 doesn't have that feature yet. I wish it did.
Car: 2012 bmw 335i
Default 07-19-2017, 11:06 PM
Ahh yeah, forgot to mention that part. I'm n55..
xQx xQx is offline
Car: 2008 BMW 135i E88 N54 6AT
Default 07-26-2017, 09:29 PM
Except that:
You raise a really good point - Why don't we mock people who use the MHD exhaust burble for the same reason?
Given that:
2) The fuel over-run is not the result of an aggressive tune or cam change.
It seems to me running ghost cams should be mocked LESS than the exhaust burble - at least you're not risking excessive exhaust gas temps or cylinder wash with ghost cams.
Stoolz Stoolz is offline
Car: 11 135i
Default 07-26-2017, 11:30 PM
Given that:
Anything over about 0.2 sec of burble is for posers yes.
EDIT. But I suppose everything is, exhaust, paint, wheels...
