nikmi nikmi is offline
Car: 420i
Default JB4 420i boost pressure - 12-02-2016, 02:45 AM
Dear all, I have installed the JB4 on a BMW 420i, including the FF wires. The thing is that boost on MAP 5 does not go above 0,88 and when it bearly goes the JB4 app says instantly that JB4 switched to safety map. Have I done anything wrong? Do I have to adjust anything? I also want to mention that on the JB4 app the FF field is always zero. Waiting for your soonest answer
PS When the boost little overgoes 0,8 that car idles a little
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 12-02-2016, 02:51 AM
Your user adjustments are all zero'ed.
Change them to the following: http://www.n54tech.com/forums/attach...1&d=1449277624
2016 F22 M240i | 8ZF
Car: 420i
Default 12-02-2016, 02:57 AM
Thanks a lot men, yes when the JB4 app goes on it mentions what you said. Where did you find those settings?
Element's Avatar
Car: BMW 135i N54
Default 12-02-2016, 03:08 AM
This stickied thread in the N20 section of the forum: http://www.n54tech.com/forums/showthread.php?t=15536
Herc Herc is offline
Car: F20 125i
Default 12-02-2016, 03:13 AM
Dear Element, any knowledge if that have to be applied for all N20 (28i) or is it just for the 20i?
Car: 420i
Default 12-02-2016, 03:50 AM
Please check again now. The boost went to 1.04. Is everything seem normal?
Default 12-02-2016, 08:59 AM
Looks pretty normal to me.
Car: 420i
Default 12-04-2016, 02:25 AM
And can I get a little more psi with map5? Is it a matter of gas or is it because of the self-learning map 5?
Default 12-04-2016, 11:10 AM
Are you running EWG wires? If not, you'll need those.
Car: 420i
Default 12-04-2016, 01:45 PM
And with the wires up to were can we go regarding boost? And is it safe?
Default 12-05-2016, 09:27 AM
Those allow the JB4 to control boost directly and achieve more boost.
