terrik terrik is offline
Car: 2018 M240i
Default B58 JB4 pull codes error/no stats - 03-24-2019, 06:03 PM
Hi all,
I installed my new JB4 in my 2018 M240i, and I have two issues.
First issue is that I have no stats in the Android phone app showing in the gauges, other than Map # and boost pressure. I don't get anything at all for RPM, temps, gear, etc... should I be?
Second issue is when I go to pull codes I get "Invalid read. Please try again." I tried with both a PC and the Android app via the JB4 USB cable. Car was turned onto electronics only, with the engine off. I had a CEL I wanted to check and had to use my plain old OB2 scanner to pull it because I couldnt pull from the JB4. Am I doing something wrong?
Thanks! Please let me know if you need any logs. I have the firmware labeled 'BMW_B48_B58_OBDII_9'.
Andrew1810 Andrew1810 is offline
Car: M140i
Default 03-25-2019, 03:12 AM
Is the OBD adapter connected properly ? This is where the JB4 will pull figures from for the gauges and reading error codes.
I believe the App also had an update which broke error code reading with the 'invalid read' issue, however there was a further update a couple of days later to correct this. Might be worth checking to make sure yours is up to date from the play/app store.
Edit, also just noticed you said through the USB cable.. does that mean you do not have the bluetooth kit ?
Car: 2018 M240i
Default 03-25-2019, 05:12 AM
Hey, thanks for the response. I'm only using the BMS USB data cable. Was the OBD adapter supposed to come with the kit? There wasn't one in my box...though I noticed a connector for it on the JB4.
That might explain everything....
Car: M140i
Default 03-25-2019, 05:24 AM
Did you buy the kit new ? I believe it does come with it, however I bought mine off someone I knew with it so cant say 100%.
Hopefully someone can provide additional info on that.
The OBD will give you all the data you're missing.
Car: 2018 M240i
Default 03-25-2019, 07:14 AM
Ok, I'll see if I can get it all sorted. Thanks for your help!
BMW After BMW
Car: BMW M240i
Default 04-01-2019, 08:47 PM
B58 JB4 comes with obdII/CANbus wire that connects to JB4 board. Can’t do most of the control functions without it, and can’t read DME-specific info without it. You can buy a replacement cable at burgertuning. Android phone app needs Bluetooth kit instead of USB data cable. Also available on website. Either go with USB and windows, or Bluetooth and mobile.
