(#426)
Default 02-15-2019, 06:24 PM
Originally Posted by nicotino15
just to add more, I couldn't get that same connector to clip either, I tried like 10 times and gave up, lol. It's just sitting there, but felt secure enough that it wasn't going to come apart so I left it. Will try pushing the retaining clip again and see if that works
This is how it looks when the pink locking clip is the way it should be. Seems some of these might have slipped out unlocked. Use something flat to push it in the direction of the wall of the plug as show with the arrow.
nicotino15 nicotino15 is offline
Car: 2018 Audi S4
Default 02-15-2019, 07:04 PM
that's not the connection I had trouble with, it's the BCM to the wastegate control connection. I just went and played with the retaining clip on that female connector and it finally stuck on.
tegxsi tegxsi is offline
Car: RS3
Default 02-15-2019, 07:08 PM
I revisited the connector and reinserted that piece today. I got it to lock in like above and the connector plugs in as it should. I drove for a week with it removed and it was fine. Doesn't seem to do much but maybe guide the mating connector better.
2018 Audi RS3
2013 Mazdaspeed3
2007 Acura TSX
Alvarezdavid Alvarezdavid is offline
Car: 2018 audi a4 qusttro
Default 02-15-2019, 07:50 PM
I have a 2018 audi a4 quattro. I purchased a jb4 3 months ago and lately only boost gauge would work and car felt sluggish. If I turned it off and let it sit for 10 min and turn back on all my gauges would work and it would come alive so I updated my firmware to audi vw_8 4. AND IT DIDN'T WORK . I need someone to point me in right direction plz.
Default 02-15-2019, 09:30 PM
Just email George@burgertuning.com!
Alanassar's Avatar
Alanassar Alanassar is offline
Car: Audi s5
Default 02-15-2019, 09:43 PM
Hello, i just installed the jb4 for my s5, i plugged the obd and There is no difference between map 0,1,2 and 3...
Im runing on gas 92 octanes
Its like the car was stock, i tested with the racelogic vbox and there is no difference, what could it be?
Default 02-15-2019, 09:46 PM
Post a JB4 log so we can look at the diagnostics and see.
Alanassar's Avatar
Car: Audi s5
Default here are the 4 logs! - 02-15-2019, 10:05 PM
map 0 to map 3
Default 02-15-2019, 10:08 PM
map 0 to map 3
Making more boost but you have a lot of timing corrections, even on map0. What fuel are you using? Can you improve it?
Alanassar's Avatar
Car: Audi s5
Default 02-15-2019, 10:13 PM
Im using 92 octanes, what can i do? What do you mean with timing correction? Sorry im new with this!
Thanks Terry!
Default 02-16-2019, 09:25 AM
I think for the short term stay on map1. And George can work with you to see if there is a way to boost performance on the octane.
Default 02-16-2019, 10:00 AM
There is another lock on the female connector side as well.
I'll have to get a picture when I get into the office today unless you can get one.
It's a small white tab that needs to slide over when the terminals are pushed to the top.
Alanassar's Avatar
Car: Audi s5
Default 02-16-2019, 11:20 AM
Thanks terry, I sent an email to george.
kanemari kanemari is offline
Car: Audi S4 B9
Default BCM - 02-16-2019, 11:34 PM
i had trouble with both connectors but they are ok now. the pink clip was in the way and i managed to adjust that. also on the other connector, part of it wasn't seated correctly (a grey circular clip at the base of the inside). i pushed that across with a screw driver and voila.
now i need to go have a run and take some logs so that i can get a nice custom map 6 worked out. any suggestions for that as a baseline? the settings on page 1 have it zeroed out but there were boost settings in there originally that i removed so it matched the recommended settings.
Default 02-17-2019, 12:22 PM
Log the individual maps first and see how the logs look. If the car runs well in map 5 which we recommend higher octane or a E30 mix we can help you set a map 6 to see if there is more room.
timmieh2 timmieh2 is offline
Car: b9 sq5
Default 02-17-2019, 02:41 PM
E85 straight will overwhelm the fueling system. Follow what we are doing for now as we test higher amounts and will will post if a higher percentage can be used.
Email me at george@burgertuning.com pictures of the inside of the two plugs so I can see why they wont click. Typically the pink locking tab jumps out of place and prevents it to connect.
I have gotten mine to click with no issue
Car: Audi S4 B9
Default 02-18-2019, 04:46 AM
ok I took a log in map 5. probably not the most calculated run or repeatable conditions but hopefully it will give some indication of performance? I dont have a dragy GPS yet (arriving tomorrow) so not sure how fast it was, and I didnt use launch control either but hopefully that wont change how well the fuel reads.
Default 02-18-2019, 05:38 AM
Log looks good but the pedal is not all the way down. Also need to run it in the higher gears like 3rd and 4th if possible where there is more load. If want do a few more and email them through to george@burgertuning.com which is easier than linking them here.
Volkschris Volkschris is offline
Car: B9 RS4
Default Just fitted my JB4 to RS4 - 02-18-2019, 03:24 PM
Just had run out after fitting the unit to do some logs and the car feels great. Only used map 1-3 but midrange already pulls great. . Sent logs over
Default 02-18-2019, 03:33 PM
Send me a picture too as I reckon its one of the first RS4's.
Car: b9 sq5
Default 02-19-2019, 07:47 PM
I noticed today on some of my logs the graphs seem to be off ? I am shifting at 6k and tje logs only show 5k and boost #ís seem to not be what im seeing on the guages. Is it just me? Lol
So it seems if i just sit at idol the data logging is counting the paramaters for time like idol guage is 823 -8-30 and the jb4 keeps logging increase rpm with relation to time same with boost! Odd?!
Default 02-19-2019, 08:09 PM
You're probably looking at the wrong log.
Car: b9 sq5
Default 02-19-2019, 10:53 PM
I thought that might be it at first but it wasent. I then changed maps and it would not record a log on map 4,3 the log came up still map 5 . So i tried to delete all the logs and it would not comply or even let me delete individually. So i just deleted the app and re installd and its working proper again. Weird!
Default 02-20-2019, 08:02 AM
IOS or Android? So far we haven't had any similar reports but worth keeping a eye out for it.
Car: b9 sq5
Default 02-20-2019, 08:20 AM
IOS ... it was definatly odd i tried loging out and back in and restarting the phone closing the app out ect. The app connected to the jb4 all the guages seemed to be in order but logging (taking,deleting,reading) all seemed off. I spent a good amount of time looking for user (my) error but ovbious error (by me) i couldnt find. I am happy i got it working again, i found the issue trying to take logs to send over to you for a map6 request sent them last night.
