(#2926)
LycanX4M40i LycanX4M40i is offline
Registered Users
Car: 14' F25 X3 xDrive28 M-Sport AlpineWhite DHP
Default 12-11-2016, 12:51 PM
Originally Posted by risktaker76
So what was the final conclusion? Its hard to derive a conclusion if there was any.
It looks like MAP 2 had some decent gains. In the end did you have to raise the boost safety to 20? Did it make a difference in max tq or max hp?
Conclusion based on testing at drag strip and dyno, 93 offers minimal gains on map1/2 maybe if you have a competent tuner or near Terry who can tune the best with JB4 most likely will be done on Map6. Otherwise, the gains were good with E85 blend. The other problem is, lack of X4 M40i guys testing or providing logs so not much Terry can do with only 1 car at this moment on the other coast of the states.
Bimmer28312 Bimmer28312 is offline
Car: E90 N55 BMW 335xi
Default 12-13-2016, 12:19 AM
Any update on f87 jb4? Have had it for a a bit now, sent Terry a few logs, on map 1 and map 6 with 3.3 gallons of e85 and still getting an off idle. Anyone else suffering off idle on their M2??
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 12-13-2016, 12:54 AM
Do you have an I take with the m2? If you do then it's probably that causing the rough idle as MAF based vehicles are particularly sensitive to new intakes. If you have the latest jb4 soft ware you may run maf-less, contact Terry for further instructions.
If you don't have an intake and are experiencing rough idles post a log in the support section along with user adjustment page, and ensure all connections are ok.
Mods: Stock for now
Default 12-13-2016, 01:05 AM
No intake just exhaust Dp and jb4. Logs are up
orteeze orteeze is offline
Car: 08' 335i
Default 12-21-2016, 09:35 AM
Can you simply remove the MAF wires and pins from the AMP connector to clean up the harness? Going to install FF wires; no need for the MAF with latest firmware right?
E90 LCI M Sport
Default 12-21-2016, 09:38 AM
If you have an old harness that still has the purple connector you can just cut if off to clean up the harness if you want.
Sicmadek Sicmadek is offline
Car: 2013 335i sportline
Default 12-26-2016, 08:13 PM
overall my user settings page looks different from the one in the op. so should i still set my defaults to the ones in the op? mine says avg ign instead of avg ign retard.
Chavoos's Avatar
Chavoos Chavoos is offline
Default 12-26-2016, 08:18 PM
Hi Terry
Just trying my luck again.
Any chance the eco map (8) and oil temp indication is near inclusion like on the N54.
Chavoos
RS3 Sedan
Ex: N55 M135i EWG
Ex: N54 135i , JB4 , Backend Flash , AFE intakes, Big Tom Intercooler , BMS CP, Meth with FSB . Custom made resonators , Turbosmart DVs.
jkj jkj is offline
Car: 13 335i
Default 12-28-2016, 09:58 PM
Can you use a newer ewg JB4 on a PWG 2013 335i?
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 12-28-2016, 10:32 PM
No. EWG is for Electronic Wastegate cars only, not Pneumatic like yours.
Mike Levy
2021 Tanzanite Blue II M550i - 8/20/20 build date.
2017 Carbon Black X3 xDrive35i
2018 Silver Equinox LT 2.0T
wjjkoevoets's Avatar
wjjkoevoets wjjkoevoets is offline
Car: BMW M235i
Default 12-29-2016, 08:06 AM
Sorry if this has been answered before, but does the F-series N55 JB4 offer shift indicator capabilities in the instrument cluster (flashing indicator lights)? Can't find it anywhere.
BMW ///M235i (EBII) - JB4 - BM3 - One sneaky Wagner high flow boi - ER CP - ER TIC CP - CSF FMIC - GFB DV+ - Pure Inlet - K&N Drop-in AF - MPE
Proud ex-owner of an:
MG TF 135 - 80th Anniversary Edition (Starlight Silver) - Stock
Default 12-29-2016, 10:13 AM
No shift light for the F series, yet.
Car: BMW M235i
Default 12-29-2016, 10:26 AM
Chavoos's Avatar
Default 01-15-2017, 08:40 PM
Terry and team , please give us an oil temp warm indication and and eco/ low boost map, even if Map 6 could be modified for lower boost.
Praying and hoping
Chavoos
RS3 Sedan
Ex: N55 M135i EWG
anrec330 anrec330 is offline
Car: F30 335i
Default 01-20-2017, 02:03 PM
Just went FBO and tune last night (f30 335i). However my JB4 Bluetooth connect kit doesn't seem to work? it says " No BLE found" I've tried tapping into another red wire in the wire loom as well as plugging and unplugging the connection inside the jb4 box. Hoping i don't have to run the OBD inside the car as i heard its a pain in the F30 6 speed.
Any suggestions?
Default 01-20-2017, 02:07 PM
OBDII is required for the JB4 to work properly and is easy to do.
For support on the JB4 Mobile adapter refer to this thread: http://www.n54tech.com/forums/showthread.php?t=21742
Car: BMW M235i
Default 01-21-2017, 08:04 AM
Terry, sorry if this has been answered before, but from what I understand the JB4 is still being actively developed for both the N54 and N55 platforms.
Are you at liberty to share any details of what you guys are doing in terms of development? Is it mostly fixes for encountered problems or are we talking new features? If it's the latter, could you disclose more information?
Not that I'm in any way dissatisfied with what the JB4's currently offering, but I would love to see something like:
- Eco map
- Speed limiter removal (probably requires a flash )
- Cluster shift indicator
I was late to the JB4 party, so I have no idea if any of these have been discussed at all.
Default 01-21-2017, 11:27 AM
From time to time we'll discuss active development items but generally I try to avoid it for several reasons. The least of which it's a competitive business and we don't want to tip off competitors and copy-cats of new features we're working on. I'm always open to listening to ideas though.
Car: BMW M235i
Default 01-21-2017, 11:39 AM
Noted! Yeah, it's a seriously competitive business. Thanks, looking forward to whatever you guys are doing
Anthony235's Avatar
Anthony235 Anthony235 is offline
Car: m235i
Default 01-23-2017, 03:53 PM
- Eco map
m235i already has an eco map....just set the car to eco mode
harkes harkes is offline
Registered Users
Car: M135i
Default 01-23-2017, 07:03 PM
So what does the ECO map do that map4 does not?
My ECO map is map0 = turbo OFF haha
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 01-24-2017, 11:47 PM
- Eco map
Sell your N55 and buy something with a B58 in it if you want further development. Terry has a major hard-on for the new 6cyl turbo
2016 F22 M240i | 8ZF
dem0nkill dem0nkill is offline
Car: 2009 535i
Default 02-03-2017, 01:51 PM
i have a 2014 x5 sdrive 35i so i should buy the http://burgertuning.com/N55_JB4_F_ch...BMW_tuner.html
with a type b connector with electronic wastegate thank you
mbarry212 mbarry212 is offline
Car: 2015 335i
Default F25 steering wheel controls - 02-15-2017, 06:50 PM
Okay guys I'm working on a F25 X35. Installed jb4. Updated to more recent firmware. Changed future use D to 2. Still not steering wheel controls. Anyone have any suggestions?
Car: 2015 335i
Default 02-15-2017, 06:52 PM
Okay guys I am working on a F25 X35. Installed jb4. Updated to more recent firmware. Changed future use D value to 2. Still no steering wheel controls. Any suggestions?
