scarfacebling scarfacebling is offline
Car: x3
Default f25 n55 X3 - 11-20-2016, 11:21 PM
Will there ever be a JB4 that works for the x3 f25 N55? Is it just to wildly different? I am planning on adding a ** an upgraded FMIC but dont even know if it is worth it if I cant up the boost. If I go with the stage one and the data cable will i be able to add additional boost to take advantage of the other upgrades? Thanks in advance.
Montegoblue335's Avatar
Montegoblue335 Montegoblue335 is offline
Car: 335I
Default 11-22-2016, 06:03 PM
I actually just installed the f series JB4 on my 2011 X3 with N55. Also I've found a ******** for it but not a fmic, where did you find that.
Car: x3
Default 11-22-2016, 06:28 PM
WHAT? Berger told me the Jb4 would not work on my f25 N55? Are you 100% sure you have the JB4 on an f25 N55 and it is workign with the CAN Bus etc? Please post a link of the porduct that you purchased.
The inter-cooler dosent state F25 but we have more room and the inter-coolers are the same between the 3 series. This one looks like it will work.
http://www.modbargains.com/vrsf-inte...-335i-435i.htm
The other hard part that is needs to be specialized is the charge piping
http://www.ebay.com/itm/like/4012154...&ul_noapp=true
here is the ********
http://www.ultimate-racing.com/colle...3-35i-********
Car: x3
Default 11-22-2016, 06:29 PM
weird is it blocking ******** what about down pipe...
Car: x3
Default 11-22-2016, 06:36 PM
In looking through your recent posts it looks like you are running a berger tuning stage1 - not a JB4... if that is not correct please clarify and let me know if it seems to have full capabilities or if you need the Bluetooth module or something because of the CAN bus.
I am trying out a different tune that should work to help me get the boost up and give me boost control per rpm not just a blanket boost +3 for example ... The stage 1 just didn't seem like the right piggyback to center my build around. I want a lot more power as you can probably tell from the links I have dropped in.
Car: 335I
Default 11-22-2016, 06:48 PM
I have f series JB4 not stage one it communicates with my can network but cant change map through cluster I have to use the mobile app
Car: x3
Default 11-22-2016, 07:01 PM
http://www.burgertuning.com/N55_JB4_...BMW_tuner.html
which option did you get the one for the 1/2/3/4 series with pneumatic waste gate or the 5/6/x series with ODBII?
did you have to buy the Bluetooth module?
http://www.burgertuning.com/bluetoot...nnect_kit.html
Car: 335I
Default 11-22-2016, 07:03 PM
5/6/x with pneumatic type b but check yours before ordering. Also what year is your X3
JB4 F series should work with the F25. I presume most are EWG.
Car: x3
Default 11-22-2016, 07:08 PM
Mine is a 2013 X3 35i N55 F25
Terry- I emailed in and received very short replies that only the stage 1 would work for me and the Jb4 would not. This is great news I will be placing an order tomorrow after I verify the waste gate - I haven't even looked. I will hopefully be returning the other piggy back before I even open it. If I buy the bluetooth module can I change maps from the phone app? or how can I flip from 0 to 5 for example?
Default 11-22-2016, 07:15 PM
No worries, we can work with you to get it sorted. The sales guys tend to just tell X3 people we don't offer a JB4 for it since we've not done the formal installation guides, etc.
With JB4 mobile you change maps with your phone.
Car: x3
Default 11-22-2016, 07:20 PM
Terry-
Thanks for the clarification one more quick point of clarification - I was told the CAN system wont work for this car. In the instructions it states that it will stay at map 1 if no ODBII CANbus. With the bluetooth app will I still be able to change maps and get the benefits of the autotune for example with map5?
7) OBDII CANbus -- Required for in dash map switching via BC button, CANflap, datalogging, and all other in dash features. If you fail to install this connector the JB4 will act as if its on map1 (default map) regardless of what map is selected.
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 11-23-2016, 07:33 AM
Does the F25 X3 not still use the N55 from the E-series?
2016 F22 M240i | 8ZF
Car: 335I
Default 11-23-2016, 07:38 AM
It uses N55
705's Avatar
705 705 is offline
Car: E90
Default 08-07-2017, 03:42 PM
[QUOTE=Terry @ BMS;508990]No worries, we can work with you to get it sorted. The sales guys tend to just tell X3 people we don't offer a JB4 for it since we've not done the formal installation guides, etc.
With JB4 mobile you change maps with your phone.[/QUOTE
Hi Terry,
I read the forums and read the JB4 is indeed compatible for a 2011 X3 35i (N55) has harness B and Pneumatic wastegate.
I ordered this with the rev 3. Bluetooth to switch maps but my order was canceled.
BobVader's Avatar
BobVader BobVader is offline
Car: 335xi 2008
Default 08-08-2017, 05:57 PM
Mine x3 2013 pwg and jb4 work perfect with bluetooth app.
Run 12.8 at 105mph on 1/4 with e25 map 7
Go with jb4
Need bluetooth app....bc button don t work with f25
Thanks Terry for some setup
See on my youtube channel ... firepoule... some kill with my sleeper X3
And shift at 5500rpm each gear with this n55...I lost .5 if I let shift trans by itself.
'08 BMW 335xi // Sedan // Black Sapphire // Sports Package//Mods: JB4 G5 iso|MHD bef Race|Hexon rr600|inlets|stage 2 fuel pump|N20 tmap 3.5|Chargepipe|Diverter valve|RB pcvalve|BMS Meth kit|AA Speed Delimiter|BMS tuning gauge|UR CL **|BMS DCI|AA Exhaust|HELIX fmic|CDV|H&R coilover|10mm Spacers H&R on 4 wheels|**Record for XI's on dragtimes.com, before new turbo and inlets...new results soon...11.768s@118.70**Top speed 186,4 mph GPS, vbox 60-130mph 7.9,
705's Avatar
705 705 is offline
Car: E90
Default 08-12-2017, 07:57 AM
Jb4 indeed works on my x3 35i.
Map 1, I did notice a difference right away.
705's Avatar
705 705 is offline
Car: E90
Default 08-12-2017, 08:28 PM
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 08-17-2017, 12:03 PM
Go with jb4
Got a slip?
F90 M5 Comp - @BM3Tuning 100-200 5.29s / 60-130 6.5s | @HCP.US
F97 X3M Comp - Tuning Soon!
F80 ZCP DCT Tune Only | @BM3Tuning Stg1+ E85 60-130mph 6.7s "World Record Dragy Verified"
BobVader's Avatar
Car: 335xi 2008
Default 08-17-2017, 11:04 PM
Originally Posted by Frikiton
Got a slip?
Just go on dragtimes.com
Bmw/x3....you will see
Or
https://youtu.be/wEkRnQEGQzg
Frikiton's Avatar
Default 08-24-2017, 08:03 AM
Or
Not bad I did 12.7@105mph JB4 Map2 E30
Then did 12.43@106.58mph Bootmod3 STG2 93 oct (back in April)
Going to see what I run this October 1st with latest map going to try Bootmod3 Flash only, then Bootmod3 with JB4 map6, then Stock Map w/ JB4 Map2/6/7 since i have a full day of drag-racing and roll-racing Oct 1st .
