Default Iso_22 - 05-25-2013, 10:34 AM
Have a new JB4 N54 ISO firmware to test. ISO_22 is the same as ISO_21 only menu 12 in dash allows you to adjust base duty cycle between 25% to 38%. ISO_19 is set to 26% while ISO_21 is set at 32%.
This setting is used during low throttle and will have an impact on low throttle response as well as wasteagte rattle during these conditions. Higher settings seem to better mask rattle but can cause over boosting down low (e.g. 4psi instead of 2psi, etc), which makes throttle input less smooth. Lower settings are smoother but with less response and more of a rattle propensity. Default wastegate duty governs wastegate position until boost goes over 1.5psi so this setting would cover the 1.5psi up to say 5psi range.
I'm not sure we'll leave this field user adjustable so consider this an experiment. Any questions emailed in regarding this field will be redirected to this thread. So if you don't know what to do or why to do it, and don't want to experiment, don't touch it.
Maximum996's Avatar
Car: 08 535xi
Default 05-25-2013, 02:54 PM
Up to what throttle percentage would be considered base duty cycle?? Whatvwas the base duty cycle of g5 integrated and stock?
NihonX NihonX is offline
Car: 1M
Default 05-26-2013, 01:00 AM
Sweet. Testing now!
Default 05-26-2013, 11:40 AM
Curious to see if this proves useful for any of you.
Jnat Jnat is offline
Car: 09 335xi
Default 05-26-2013, 12:26 PM
Honestly, I welcome more user adjustability as I come from Cobb/STI ATR (very useful tuning tool). 21/22 felt real good to me at 32% so I went to 33% then 34%, car feels great. We'll see.
Car: 1M
Default 05-26-2013, 12:57 PM
It seemed like rattle was completely gone on the 1M, but of course each car is different, and on my friend's 335i it didn't really reduce his rattle.
Is this one supposed to be adjustable or not yet? Settings would not save after being adjusted.
Maximum996's Avatar
Car: 08 535xi
Default 05-26-2013, 05:17 PM
Right, my settings do not save too...
Car: 09 335xi
Default 05-26-2013, 07:49 PM
Mine saved?
wreckz's Avatar
wreckz wreckz is offline
Car: n54 TOOPL3SS
Default 05-26-2013, 09:26 PM
Almost done downloading can't wait to try it out
Default 05-26-2013, 10:34 PM
If set between 25-38 it should return to that setting when you go back to menu 12.
wreckz's Avatar
Car: n54 TOOPL3SS
Default 05-27-2013, 12:00 PM
No rattle on 21 or 22 with can flap on or off
I've been playing with it from 34 to 38 how much higher can I safely go
Or better yet what number should I not pass
Default 05-27-2013, 12:05 PM
The maximum you can set is 38. After that the software will roll it back to 32.
Maximum996's Avatar
Car: 08 535xi
Default 05-27-2013, 01:55 PM
Ohh i see now, i must have been going over 38, then it would roll back to 32, got it now.
Axing Axing is offline
Car: 3dirty5
Default 05-27-2013, 02:00 PM
I just uploaded the ISO 22 and tried different base duty cycle settings.
Is it normal that my car feels better (and louder) with a setting of 25? There is also less rattle.
At 38, there is definitely more rattle than at 25 and it didn't feel more responsive vs 25 (and 32).
All this testing was done with a lagfix 0.
I still can't use any lagfix settings above 20% or else it rattles like crazy (at any base duty cycle settings). I used to be able to use lagfix 100% with the G4 with only little to no rattle.
Default 05-27-2013, 02:08 PM
The short answer is use whatever feels best for your car. Each wastegate setup seems to respond differently to various settings.
Car: 3dirty5
Default 05-27-2013, 02:12 PM
^ ok good thanks! I'm happy with the way the G5 feels now.
I will do some logs soon.
2007 335i coupe AT
JB4 G5, *********, 7'' intercooler, DCI, Alpina B3 Flash
Aero Lip, M3 Sideskirts and spoiler
To do : BMS meth trunk kit and elbow, M3 rear bumper, RB turbos
Default 05-27-2013, 05:16 PM
Seems stable enough so I added it to the ISO sticky.
Milwaukee135's Avatar
Milwaukee135 Milwaukee135 is offline
Car: 2008 135i
Default 05-27-2013, 05:50 PM
ISO 22 works great. That new 12-menu feature is awesome.
I did the following to set up the WG's:
1. Set default position to largest value such that I get no rattle on decel
1a. This is 100 b/c I have new turbos, but I used 96 just to be cautious.
2. Set default duty cycle to lowest value such that I do not get rattle on low throttle
2a. Also easy since I barely got any rattle in the first place.
2b. This was 27.
3. Increase default duty cycle from previous point until response is what I like.
3a. This was 29.
At 29, I do not get any overboost at low throttle, but at 30 duty cycle I do. So I figure 29 is the best value.
Also, this is all with 93 octane. I suspect that when I go back to E85 mix I'll need to lower the duty cycle default.
With the above settings, the car is the best it has ever been. Extremely responsive and very linear throttle. No oscillation. No rattle.
Tuning Obsessed Central Oregon Engineer
08 E82 N54 (bimmerboost flash tuned by me)
Default 05-28-2013, 09:11 AM
2b. This was 27.
3a. This was 29.
Perfect that is exactly how these user adjustments are supposed to be utilized.
tofu tofu is offline
Car: 335i e92
Default 05-28-2013, 12:09 PM
terry what was the approximate setting on 20B for reference?
RBloodscalp's Avatar
RBloodscalp RBloodscalp is offline
Power slide freak
Car: 09 E82 MT6 JB4 ST3
Default 05-28-2013, 01:05 PM
Will 38 % near 4rpm on tach or.....
If you are not going JUICE BOX then you are going SLOW
[N54 with RB`S, E82 MT, DCI aFe,CHARGEPIPE,SINGLE BOV&FMIC ACTIVE AUTOWERKES, NST CRANK PULLEY, 3' BMS **, M PERFORMANCE EXHAUST, BMS MCV, BMS OCC, BMS 2STEP, JB4 G5 ISO board BMS Flash at 20.5psi]
Default 05-28-2013, 01:39 PM
28 iirc.
Car: 335i e92
Default 05-28-2013, 01:54 PM
28 iirc.
ha that's interesting.
19 was better than 20B, but 20D is better than both of them.
Togeneral99 Togeneral99 is offline
Car: 2007 E90 335i
Default 05-28-2013, 02:56 PM
has anyone had any issues with the gauges going out of whack when you use stealth gauges? (5/6)
Ive had to reset the gauges several times and cant seem to get the stealth gauges to turn on (always hijacked)
Im using ISO G5 21.hex
going to update to 22.hex and see if anything changes
mrbillytalent's Avatar
mrbillytalent mrbillytalent is offline
Probably being sarcastic
Car: e46 323i & e90 335i
Default 05-29-2013, 04:54 AM
Read the g5 faq and reset the gauges via the steering wheel controls
200k mi 99 blk 4dr e46 m52 323i w/ h&r's k&n cai shark'd
95 e36 m3 s50 5spd stg2 turner re11a's autox toy lol
07 BSM 6spd e90 n54 335i jb4 g5 iso ar **'s SPEC 2+ w/ SMFW BMW ssk bms dci RB pcv 455lph lpfp 50% e85 Syn. BOV hijk lmnop
94 e34 530it 290k 350ci sbc tko600 project
Closed Thread
