Geraldomi Geraldomi is offline
Car: Infiniti Q50S 2018
Default Map 6 log review - 11-27-2020, 08:52 AM
Two run logs on map 6. Does it look good?
Default 11-27-2020, 10:40 AM
The other graph was too big in size to be attached.
File Type: pdf P50_M6_R1_201126_055436_JB4 Mobile.PDF (522.1 KB, 16 views)
Default 11-27-2020, 04:48 PM
It looks fine but I think you're leaving a lot of performance on the table with the really heavy top end taper.
Default 12-02-2020, 07:16 AM
Thanks Terry. What do you recommend my targets to be between 5,000 rpm and 7000 rpm to achieve better results?
