(#5526)
Car: q50
Default 07-08-2020, 05:18 AM
Originally Posted by roshg
I didn't know this was even possible. Its annoying reading through all the logged events looking for the WOT ones...how do we set this "only log WOT" setting?
Settings
App settings
Logging settings
WOT autolog Threshold- set it to something high like 70% throttle to start a log or something.
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
djslug2000 djslug2000 is offline
Car: 2017 q60 ss
Default 07-10-2020, 11:40 AM
Originally Posted by Black_VR3
Anybody know what could be causing me to get p0101? I just installed Fuel Wires and EWG and I only get the CEL at higher RPMS but no performance loss and logs still look good
I had a similar issue . I thought is was the pins not being lined up. It turns out even the wire connections have to be straight . My one wire was bent . Notice in the pic how black wire is slightly bent up
iamafrayedknot's Avatar
iamafrayedknot iamafrayedknot is offline
Car: 2019 Q50 Red Sport AWD
Default 07-10-2020, 02:11 PM
I had the same issue here, reseated all pins/connectors and used dialectric grease. Haven't had an issue since.
Josh
2019 Q50S AWD
Default 07-10-2020, 04:08 PM
Those connectors have been a bit of a headache at times. We changed suppliers maybe a year ago? Seems to have been a little better since but they can still get bent the wrong way somehow and not make good contact.
roshg roshg is offline
Car: 2017 Infiniti Q50S 3.0t Silver Sport
Default 07-11-2020, 12:07 PM
Can someone look at my log and see how I'm doing? I'm on a custom map 6 with 5.5psi peak on my SS. Mostly concerned with how my timing is...and what exactly is my peak PSI that I'm hitting?
Default 07-11-2020, 02:39 PM
Looks OK to me, around 15psi peak here.
Default 07-11-2020, 07:33 PM
Thanks Terry much appreciated!
butler3383 butler3383 is offline
Car: Infiniti q50 2016
Default Jb4 log 92 - 07-12-2020, 06:05 AM
Looking for feedback on map 6 log. Fuel trims high 92 octane
Default 07-12-2020, 10:03 AM
Attach the CSV directly
Default Yesterday, 12:34 AM
I need a final log analyzed. I did 3 new runs. This is an SS AWD. Turned off traction control & brake boosted the launch, sport+ mode.
Run 1 - Map6 +7 peak, manual paddle shifts
Had problems, noticed a loss of power after it shifted into 2nd gear, then picked up again...any reason why it did this?
Run 2 - Map6 +7 peak, automatic shift
Run 3 - Map 6 +5.5 peak, automatic shift
Need to know how if the data looks ok, any timing pulled, and any reason it cut my throttle?
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default Yesterday, 04:33 AM
Boostane runs?
12.64 @114mph
0-60 4.46
Car: q50
Default Yesterday, 07:14 AM
run 1 and 2 look pretty crappy. I would stick to run 3 settings.
Q50 Premium RWD
BMS HE
Low cost LSD
Default Yesterday, 09:55 AM
Boostane runs?
Yes lol
Thanks! I think I'm forever stuck on using 5.5 peak with jb4 on my car. I tried everything to run 7psi and it doesn't like it. I use boostane to up the octane level +5 (Canadian Octane 94 + boostane - hoping it was octane 99) but still doesn't like it! When I tried E85 mix (e20 ratio, or e30) I just get cuts in the lower rpm in 1st gear like crazy and it leans out...so that doesn't work for me either.
Sticking to the +5.5 for good now.
Car: q50
Default Yesterday, 11:38 AM
What's your exhaust? Maybe you just have too much back pressure.
Q50 Premium RWD
BMS HE
Low cost LSD
Default Yesterday, 01:59 PM
I have the megan racing LDP and rev9 axle-back, rest is stock...intake still stock with K&N drop-in. I have the BMS intake, but haven't re-installed it yet (i had taken it off when I had cutout issues, but end up being the e85). any clues there?
Car: q50
Default Yesterday, 02:31 PM
I wonder if the upper cats are holding you back or maybe the stock y and mid.
Q50 Premium RWD
BMS HE
Low cost LSD
Default Yesterday, 10:01 PM
I was planning on upgrading the stock y & mid...perhaps time to do it now! Once I get those on, I can provide an update in near future. Thanks!
Default Today, 01:14 PM
I'm still not a fan of these aggressive taper map6 people run. I think you'd be faster on our map3 for example. Just be sure you're using a dragy as a guide when evaluating performance differences between changes.
