stp72 stp72 is offline
Car: 2009 E90 335xi
Default Newbie be gentle - 04-09-2019, 01:05 PM
Hi guys, I just picked up a show room condition
2009 335xi 140,000 km. The old owner installed a JB4.
Is there a way to totally disable the jb4 system? Iím a diesel mechanic
By trade but in sure whether or not the jb4 will interfere with
The trouble shooting.
I used a cheap code reader and itís misfiring on 2&5 runs rough, smells like fuel inside the car, outside the car, and out of the exhaust *****.. it was stores for the winter, and the problem started upon start up.
He had the Coils and plugs changed last week and apparently it made the symptoms worse. He did give me the old coils and plugs..
I assume itís fuel injector issues or fuel related.
what diagnostic software would you recommend to purchase? I have the USB OBD cable and cables for an android device..
Thanks in advance for the help
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 04-09-2019, 02:24 PM
You need new injectors...
09 335 - 6266
07 335i - 6870, E85 - SOLD
Car: 2009 E90 335xi
Default 04-09-2019, 02:28 PM
Thatís what I figured..
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 04-09-2019, 03:59 PM
Pulling the plugs one by one and seeing if they smell like gas is a good way. They'll often be fouled a bit too. Did you guy label the old plugs by cylinder? If all the injectors are fairly old and at that mileage might as well do them all.
With new firmware, the JB4 will temporarily allow pass-through when you attach anything to ODB2 port like a scanner, or you can switch it to Map 0 manually through the steering wheel controls. It won't be totally disabled unless you remove it though.
Car: 2009 E90 335xi
Default 04-09-2019, 05:33 PM
Thank you for the input.
Nothing was labelled, I guess the mechanic that pulled and replaced them
And put them in a box. sourcing out injectors now 😱
Car: 2009 E90 335xi
Default 04-10-2019, 10:22 AM
Update : all the injectors are index -8
So I assume theyíve never been replaced?
Car: 2009 E90 335xi
Default 04-10-2019, 10:23 AM
Can I replace the the injectors on 2&5
With index -9? I just want to see if injectors are even the issue
Before I go buying 6 new -12ís
Milan's Avatar
Car: 08 335xi
Default 04-10-2019, 10:37 AM
I think 9 is regarded as the worst revision. You are a diesel mechanic so I don't think I need to tell you to put in brand new OEM injectors and not mess with anything used and refurbished. Pretend you are working on an LB7
09 335 - 6266
Car: 2009 E90 335xi
Default 04-10-2019, 10:53 AM
True enough, I have 2 boxes full of test injectors
But nothing for a 335.. I will purchase 6 new revised oem ones
Ones once I know for sure the injectors are bad in the 2 cylinders with the misfires..
Milan's Avatar
Car: 08 335xi
Default 04-10-2019, 11:31 AM
Don't forget to code the injectors...you need a bavarian technic cable and there is a good YT video on how to do it.
09 335 - 6266
ifjd073's Avatar
ifjd073 ifjd073 is offline
Car: 2007 BMW 335 (E90)
Default 04-10-2019, 12:51 PM
Also, if it smells like gas in and out of the car, take out the rear seat and check the top of the fuel sender bucket for standing fuel. They get old, cracks develop in the plastic and some gas seeps out. I had the same issue last year on my 2007 (that I've had since new) and replaced it.
'07 335 sedan, Stage 2 VVT, VVT inlets/outlets, VVT DCI, Phoenix CP with Tial BV, 3.5 bar TMAP sensor, Spec twin disk clutch with SMF, BMS OCC, RB PCV valve, ***less ***, VRSF catback with Vibrant *** installed, ETS 5" intercooler, Fuel-It stage 2 fuel pump, Fuel-It 650HP LPFP upgrade with 525 pump, JB4 with custom Trebila BEF, Phoenix PI intake manifold /w 550cc injectors, Fuel-it fuel lines, ethanol sensor and analyzer
Car: 2009 E90 335xi
Default 04-11-2019, 08:53 AM
Update- i removed all the fuel injectors, disconnected
The electrical connections, and the suspected misfire
On 2&5 are leaking injectors. 5- had the odd drop of fuel, #2
Was squirting like a garden hose. The rest of the injectors had zero leakage.
Now to shop for injectors 😱
Car: 2009 E90 335xi
Default 04-12-2019, 10:08 AM
Final update..
I changed the engine oil and filter, installed 2 working used injectors
Index 9.. I checked all injector coding, and not one injector was coded
Properly.. recoded them all, cleared all codes and now it purrs like a kitten..
Now that I know all is good, I will be sourcing out some index 12
Injectors.. does anyone know a good reliable source for injector purchase?
Thanks for the help
aus135i aus135i is offline
Default 04-15-2019, 01:56 AM
FCP Euro or ECS Tuning. I just had a look man they have gone up heaps!
ifjd073's Avatar
Default 04-15-2019, 08:31 AM
I'd go FCP Euro, lifetime guarantee is worth it at the price they sell for these days.
codesx codesx is offline
Default 07-12-2019, 10:14 AM
Final update..
Thanks for the help
Curious,
Are you still running the two Index 9 Injectors?
If so, how are they doing for you?
I'm assuming you bought them off Amazon or equivalent, where they have no metal caps on them? (used/rebuilt)
2008 335i Convertible, E93, N54, A/T (190,000+ km)
TUNE: JB4 Map 6 | RACE BEF | 94 Octane | @19 PSI
BMS JB4 | BMS WMI @ 60/40 (CM10) | BMS 5" FMIC | BMS OCC | BMS DCI | BMS Cowel Filters
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
NGK 5992 Plugs @ .020
Maintenance:
2019 - VCG | OFHG & O-rings | Alternator w/ Clutch Pulley | Water Pump & T Stat
