HKD126 HKD126 is offline
Car: 2014 335i
Default Tuner recommendation? JB4 (methanol) with MHD backend - 07-01-2019, 01:16 PM
Can anyone recommend a tuner for the N54 that works with the JB4 (methanol injection) and MHD backend flashes? The car is currently FBO with methanol, but also looking to upgrade the turbos and get a custom tune for it.
Please elaborate on your experience with your recommended tuners.
So far Ive heard good things about BQ and Wedge.
Thanks.
Zeezul's Avatar
Zeezul Zeezul is offline
Car: e92 n54 pre lci
Default 07-01-2019, 05:09 PM
Trebila is good. He's the only tuner I've ever used though.
FBO MT N54 w/stock turbos-tuned by Trebila
Default 07-01-2019, 10:41 PM
Trebila
PureEvil
Wedge
codesx's Avatar
codesx codesx is offline
Default 07-02-2019, 09:59 AM
If you do the tune and nothing else, it would be very interesting to see Dyno results of the before and after.
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Car: 2014 335i
Default 07-04-2019, 01:45 PM
Trebila
PureEvil
Wedge
Any particular one youd recommend over the others?
