(#151)
Default 04-21-2019, 11:40 AM
Originally Posted by ThorVanEden
ok..
now i have the 6cyl. timing (5)
last run att.
i tryed map 5 , 6 ,7 ... its the same ... not more than 11PSI
What turbos?
ThorVanEden ThorVanEden is offline
Car: Z4 E89 35i +
Default 04-22-2019, 02:07 PM
i have bigger upgrade Turbos
New Chargepipe
le_roi_leo le_roi_leo is offline
Car: bmw 135i n55 e82
Default 07-01-2019, 04:44 AM
have a silly question ?
how you know that a log is good ?
he is necessary that the curve PWM and FF coincides?
and that the curve PWM has a minimal oscillation ?
Default 07-01-2019, 07:31 AM
Post a log in the support section and we'll take a look and tell you what to look out for.
Default 07-02-2019, 04:24 AM
finally, when i read, he show us just than he change the PID for adjust the curve.
but it not know if a PID hight or low is good for your engine ?
if i understand, FF Curve = Internal Mapping * duty bias/50 * FF/100
and terry said #20 than for DUTYBIAS 0 same 50.
so according to the formula:
if (for exemple) all the numbers DB = 65 and the FF =50
it's same than all numbers DB=0 (0=50) and FF=65 (50+15)
but when FUD=0, the setting FF is automatic,
ok you show us the effuences DB PID etc...
but for finally we said us to let FF Jb4 on the automatic setting ?
Meka11113 Meka11113 is offline
Car: 2010 bmw 335i
Default 03-10-2020, 07:50 AM
Originally Posted by SPANKY
I have the latest firmware and interface.i had my duty bias all set to 0. Then I tried all set to 50,did a log and noticed right away my car would do a bucking throughout 2nd ,3rd and fourth.i pulled over and set back to 0 on duty bias,did a log and car is fine.thought setting at 0 or 50 is same?ill post up the both logs later when I get home.
Dude the same thing is happening to me after I changed my dusty from 0 to 50 in my 2010 335i. What gives Terry?
Default 03-10-2020, 02:31 PM
Post the log.
