Go Back   N54Tech.com - International Turbo Racing Discussion > General > Regional Forums > California
Reload this Page ◄ SPEED LOGIC ► Mods, Service & Installs for BMW N54/N55/S55/S63 (OC, LA, IE, SD)
Speed Logic Automotive's Avatar
Speed Logic Automotive Speed Logic Automotive is offline
Fullerton, CA (Socal)
Car: N54/N55/S55
Default ◄ SPEED LOGIC ► Mods, Service & Installs for BMW N54/N55/S55/S63 (OC, LA, IE, SD) - 11-15-2017, 10:26 PM
SPEED LOGIC AUTOMOTIVE
625 W. Valencia Drive, Unit A
Fullerton, CA 92832
Phone or Text: (888) 564-4215
Email: info@speedlogicauto.com
Website: www.speedlogicauto.com
Message: Send a Private Message
Hours of Operations: Mon - Sun: 10am to 5pm (PST)
*By Appointment Only*
We want to give a warm welcome to the N54Tech community! We are an automotive shop that specializes on the various BMW Turbo Engines (N54, N55, S55, S63, etc). Whether you may be looking for simple plug and play Bolt-Ons, a Turbo Upgrade, or complete Tuning solutions and packages; we can be sure to be able to help you with your needs. We have the resources and BMW specialty tools to get the job done correctly for all the services we offer. Thankfully our employees are car enthusiasts as well and can easily share insight and passion for the lifestyle. We work closely with many brands and vendors within the BMW community, continually staying informed of new product updates and releases. We are looking forward to working with fellow enthusiasts and serving the community!
As an official introduction to the community, we figured we would work out a few deals that many of you may need on your BMWs. All specials include Parts & Labor. All parts used are only Genuine OEM BMW parts with the exception of #6 which includes aftermarket performance parts. Please be sure to mention N54tech when contacting us for an appointment so we can sure to price the service accordingly. We are happy to package other items that are not listed, just be sure to let us know if you have any specific or other needs.
#1 ► Walnut Shell Blasting Service for N54, N55 Vehicles w/ Replacement of OEM BMW Intake Manifold Gaskets @ $200
#2 ► Waterpump and Thermostat Replacement for N52, N54, N55 Vehicles (Special applies to 1 series and 3 series) @ $730
#3 ► Oil Filter Housing or Oil Cooler Gasket Replacement for N52, N54, N55 Vehicles $400
#4 ► Valve Cover Gasket Replacement for N54, N55 Vehicles @ $350
#5 ► Oil Pan Gasket Replacement for N52, N54, N55 Vehicles @ $700
We are proud to offer a wide variety of services to accomodate for your BMW needs. All services we offer are always performed by qualified technicians using specialized BMW tools. Each service includes a full 1-year warranty on Parts & Labor to give each client full peace of mind. If there are any services or items unlisted that you may be interested in please feel free to reach out directly and we would be happy to accomodate.
  • BRAKES
  • Brake Pads & Wear Sensor Replacement
  • Brake Rotors Replacement
  • Stainless Steel Brake Line Installation
  • MAINTANANCE
  • Walnut Shell Blasting Cleaning Service
  • Vacuum Line Replacement
  • Belt, Belt Tensioner & Idler Pulley Replacement
  • Waterpump and/or Thermostat Replacement
  • Starter Replacement
  • Clutch & Flywheel Replacement
  • Turbo Replacement (Stock Turbos, Upgraded Twin Turbos, Single Turbos, etc)
  • IGNITION COMPONENTS
  • Spark Plug Replacement
  • Coil Pack Replacement
  • Fuel Injector Replacement
  • GASKETS & SEALS
  • Oil Filter Housing Gasket Replacement
  • Oil Cooler Gasket & O-Rings Replacement
  • Valve Cover Gasket Replacement
  • Oil Pan Gasket Replacement
  • Front & Rear Main Seal Replacement
  • FLUIDS
  • Oil & Oil Filter Change
  • Brake Fluid Flush
  • Coolant Flush
  • Power Steering Fluid Flush
  • Automatic Transmission Fluid, Pan, Mechatronic Sleeve Replacement
  • Manual Transmission Fluid Replacement
  • Differential Fluid Flush
  • SUSPENSION & DRIVETRAIN
  • Spring Installation
  • Coilover Installation
  • Differential Installation
  • PERFORMANCE BOLT-ON INSTALLS
  • Intake Installation
  • Chargepipe Installation
  • Front Mount Intercooler (FMIC) Installation
  • Turbo Inlet Installation
  • Exhaust Installation
  • Turbo Installation (Stock Turbo, Upgraded Turbos, or Single Turbo Kit)
  • Fuel System Upgrades (Available for all power goals)
  • OTHER
  • Engine Replacement
  • Transmission Replacement
  • Tapping Intake Manifold for 1/4" Nipple
  • Oil Catch Can Installation
  • MHD Tune or Backend Flash Installation
  • Coding/Programming of any type
  • Alpina Transmission Flash
  • xHP Transmission Flash
Phone or Text: (888) 564-4215 (Please leave a Voicemail or Text)
Hours of Operation: Mon - Sun: 10am-5pm (PST)
Availability: *By Appointment Only*
Website: http://www.speedlogicauto.com
Instagram: @speedlogicauto
Car: N54/N55/S55
Default 11-15-2017, 10:26 PM
Reserved
Car: N54/N55/S55
Default 11-15-2017, 10:32 PM
Reserved
Car: N54/N55/S55
Default 05-07-2018, 01:33 AM
Bump!
SPEED LOGIC AUTOMOTIVE -
PHONE OR TEXT: (888) 564-4215 (Leave a Voicemail or Text)
EMAIL: info@speedlogicauto.com
WEB: http://www.speedlogicauto.com/
INSTAGRAM: @speedlogicauto
Car: N54/N55/S55
Default 07-26-2018, 11:06 PM
To the top!
Car: N54/N55/S55
Default 05-30-2019, 01:28 PM
Bump to the top!
