listed5 listed5 is offline
Car: f30 ps2 335i
Default JB4 V2 board is a win, but need help bringing PI online - 05-13-2019, 09:58 PM
I have a 2013 f30 335i running Bootmod3 stage 2 tune and JB4 ISO (board version 1) that also runs PI and accepts a signal from the Fuel-It! e85 sensor. After installing a new control chip (wasn't sure how recent mine was), updating firmware, and loading the most recent Bootmod3 map; the JB4 is missing boost targets BADLY. With the JB4 in map 4 (or 0) and the ISO PWG wires disconnected, running tune only, the car makes crazy power up until the HPFP crashes. With the JB4 engaged, boost is very low and the car eventually hits a brick wall as the boost climbs. If I hadn't been using the JB4 to scale PI, I'd just leave it disconnected. Does anyone have any clues as to what may have happened? Maybe I damaged the board when I installed a new chip? The firmware is flawed? A wire came unpinned? I ordered a new V2 board from burger, hoping that may change things in some way, but am also uncertain what wire(s) needs to be changed to run the new board.
Attaching a log
Last edited by listed5; 05-21-2019 at 12:05 AM.. Reason: Changed title for new board. Scroll down.
Car: f30 ps2 335i
Default 05-13-2019, 10:53 PM
I found a log from when the car ran strong with PI. For those wondering, I switched back to a normal n55 TMAP also in an effort to resolve issues. My meth settings differ between the two logs, not sure why. And also still not certain what those are supposed to be as on thread says 99, one 100, and yet my car ran well when set to 0. I wish data were routinely updated with regards to settings and wiring pin-outs.
Car: f30 ps2 335i
Default 05-20-2019, 11:59 PM
I installed the newer V2 board without isolated boost control and it performs MUCH better! However, PI is completely gone. Meth reading sticks at 1 and Fuel_en never rises from zero. Additionally, I lost the e85 signal. Anyone know what may have happened? I had to start all over with settings, but used identical meth settings to what I had.
File Type: csv 2019-05-21 00_28_43_Map-6.csv V4 board.csv (6.3 KB, 22 views)
Car: f30 ps2 335i
Default 05-26-2019, 10:40 PM
bump
Default 05-27-2019, 08:55 PM
what flash ?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: f30 ps2 335i
Default 05-30-2019, 01:12 AM
what flash ?
Bootmod3 OTS stage 2. I was running this same map in previous logs, but E85, Meth, and Fuel_en all had values. The values went to zero and "meth" to 1 after installing the new JB4 board.
Default 06-02-2019, 05:11 PM
Update to v13 firmware, uncheck the WMI options, and relog so we can confirm the PI signal is working as it should be now.
