f9kandy f9kandy is offline
Car: M140i
Default Map 3 ok Map 6 wild boost - 09-08-2018, 01:39 AM
Gradually stepping it up. Map 3 looking ok ish with the exception of fuel trims being on the high side (93 with octane additive, no fuel wires)
Switched to Map 6 with a flat line of 17psi target and I get wild overboost. If I'm reading this correctly, WGDC seems to be increasing further as the boost goes way over target? (I got a Wastegate Flap Sluggish code and reduced power mode saved the motor)
I have the wastegate wires and ******* pipe.
Anyone offer any guidance please?
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 09-08-2018, 09:03 AM
My map 3 trims were the same at first once i installed the fuel wires the trims dropped down even with the FOL on standard 60. You should install them.
