Vitto330e Vitto330e is offline
Car: Bmw 330e MSport
Exclamation Bmw 330e and JB4 issue - 09-02-2018, 04:31 AM
Hi, I am posting some logs of my car. Now also in map 1 car is fluctuating in a very strong way. Please take a look to the attached files. I tried to read codes but there isn't any error.
In stock mode everything is OK... And trying map 6 I see that the more boost I add and worse it goes... Seems like a problem of mass air measurement and throttle closure.
Thanks for your help
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 09-02-2018, 05:56 PM
What you using minimum of 91 octane?
Default 09-02-2018, 06:51 PM
Map1 looks normal to me. How does map2 look?
Default 09-04-2018, 11:01 AM
I am using a 100 Ron European fuel, similar to 93 AKI...map 2 improves the problem.
Could be a problem of cables or hardware? the car becomes undriveable as soon as "boost psi" becomes higher than "ecu psi", also at partial load.
It has the same effect of a broken ignition coil for example.
I am really depressed...Switching off JB4 everything goes ok. Please help me...
Default 09-04-2018, 11:12 AM
Logging ECU i cannot see MAF values...so is it possible that JB4 doesn't handle this signal and car cannot be smooth?
Default 09-06-2018, 03:28 AM
Good news. Problem solved. I tried a new firmware and an older one without any solution. So I stopped firmware upload at around 50%...so JB4 was without software I suppose. After that I reinstalled firmware from zero and everything is OK now! Probably software was corrupted and hardware wasn't able to do his job?
