Peter340's Avatar
Peter340 Peter340 is offline
Car: 2018 BMW 340i xDrive
Default Help with B58 logs - 08-28-2018, 05:16 PM
As the title states I need help reviewing my logs from my 2018 340i xDrive. The car has JB4, bms intake, and c@tless d0wnp1pe. All logs were 3rd gear pulls and it seems the logs are abnormal but I am new to logging parameters. The title of the log states the map and fuel, with E85 logs being 2.5 gallons to a full tank. Thanks in advance any help is appreciated.
Default 08-29-2018, 09:30 PM
I opened a couple and they looked OK, but I see the normal B58 ** overboost. Adding in EWG connector and setting FUA to 15 as a start should correct that.
Peter340's Avatar
Default 08-31-2018, 06:33 AM
Thank you for the advice Terry.
HitmanHearns HitmanHearns is offline
Car: 2016 340i
Default 09-03-2018, 11:14 PM
Terry, you can adjust the FUA even on map 1 or 2? Or is that only for Map 6 (Custom)?
2016 340i M-Sport |JB4|ER DNPIPE|BMS Intake|
Default 09-04-2018, 09:01 AM
It will be for all maps.
