p0wyangz p0wyangz is offline
Default Just went single turbo!! - 06-27-2018, 01:17 PM
Hello everyone. I just went single turbo . I did all the before and firmware updates. Seems like I'm stuck in map1 when I go map 2 it reverts back to map 1. I took a 2nd gear log.
Default 06-27-2018, 01:46 PM
O2 codes? AFR in both banks are pegged at 20. That's why you're getting kicked to map 1.
Default 06-27-2018, 01:57 PM
I wasn't getting any codes before but now I am. 2c24, 2a2b, 2a2c, 29e0, 29e1
Default 06-27-2018, 03:31 PM
Have a full screen shot of the descriptions?
Clear the codes and get a log on map 1 for me.
Default 06-27-2018, 05:32 PM
So I switched the O2 sensor plugs and now it reads and idles way better. I'm still not hitting the 17psi on map 2
Default 06-27-2018, 08:47 PM
Here is another log. Do I have some kind of boost leak?
Default 06-28-2018, 10:21 AM
Some settings need to be fixed.
3rd gear your boost limit value needs to be at 0
DWP should be at 60
Set FF at 20
Get a log for me on map 1 first.
What psi springs are in the wastegate?
Default 07-01-2018, 02:59 PM
Here is another log with those changes. I believe I was in map 3 though. 11.8lb spring in wastegate.
Default 07-01-2018, 11:53 PM
After a few pulls it's started to hit target. Eventually it started to over Target at 22psi on map 3. Is this something I should be worried about?
Default 07-02-2018, 09:02 AM
Here is a 2nd gear log on map1 still hitting 21.8psi?
Default 07-02-2018, 10:36 AM
Check your vacuum lines, that's the only thing that would cause that on map 1 if you were hitting wg spring before.
Default 07-03-2018, 11:48 PM
You were right sure enough my vacuum line from the compressor hosting came loose. I replaced it and now map 1 hits wg spring target . But map 2 and 3 don't even come close.
Default 07-04-2018, 07:51 PM
More logs cleaner ones
Default 07-05-2018, 09:54 AM
No worries, much better now that you have that under control.
Raise FF to 35 and get another log for me on map 2, that should help you hit target or get closer.
Default 07-05-2018, 12:47 PM
Here is the log you requested. Still not coming close to hitting 17psi
Default 07-05-2018, 05:17 PM
Can't see anything in this log. Get me a log in third gear from 2krpm until redline. Make sure you're at 100% pedal for consistent logs and data.
Default 07-06-2018, 09:00 AM
Here is a 3rd gear pull
Default 07-09-2018, 10:11 AM
Raise FF to 70 and get another log when you can, it's almost there!
