(#201)
Odinist's Avatar
Odinist Odinist is offline
Car: 2018 Civic Si
Default 03-11-2019, 02:34 PM
Didn't get a chance to try higher boost levels on this one today, maybe down the road. Owner is happy with ~240whp.
Fair!
Hopefully I'll get some dyno pulls done in the next couple of months... I'd like to think that I have the highest powered, non-flashed CivicX.
Mishimoto intake, resonator delete, Vibrant 1040 muffler, JB4 tuner, Firehawk Indy 500 rubber, Lamin-X fog light covers, Xentec 35w 6000k HIDs, custom d20 shift knob, 20% tint, red "H" badges.
Default 03-11-2019, 03:49 PM
lol you very well might have! Unless TypeR counts as CivicX?
Odinist's Avatar
Car: 2018 Civic Si
Default 03-11-2019, 04:35 PM
It does, lol.
Guess we should clarify highest powered non-flashed 1.5 CivicX, haha.
jgklim's Avatar
jgklim jgklim is offline
Car: 2018 Honda Civic Sport
Default 03-11-2019, 05:48 PM
Video and lots from today's dyno fun.
Awesome! Great run!
Accurus Accurus is offline
Car: Honda C-RV
Default 03-14-2019, 09:27 AM
Quick logs in 33c heat, 95 ron fuel no additives.
Default 03-14-2019, 10:11 AM
Looks good to me, map2 next!
Car: Honda C-RV
Default 03-14-2019, 01:19 PM
Map2, 27c
I noticed that in map 2 in cruise control and the user setting 7 is off it feels like it is surging a bit between 40 and 55 mph, other speeds are fine.
Dumb question, have you tried to fit the BMS intake to a CRV yet?
Default 03-14-2019, 04:17 PM
I believe it uses our Si version intake. We'll have those in stock soon.
Car: Honda C-RV
Default 03-15-2019, 10:34 AM
reup logs
Odinist's Avatar
Car: 2018 Civic Si
Default 03-15-2019, 10:53 AM
Terry, could we change the hot/cold protection from 170 down to about 150-60?
Default 03-15-2019, 11:03 AM
We could but what would be the reasoning? You don't want to beat on a cold engine. Oil is thick and doesn't lubricate turbo and bearings as well, etc.
Default 03-15-2019, 11:04 AM
reup logs
Looks good to me!
Car: Honda C-RV
Default 03-15-2019, 11:22 AM
So set map 6 to 4.5 psi?
Default 03-15-2019, 11:25 AM
Let's log map3 next.
Odinist's Avatar
Car: 2018 Civic Si
Default 03-15-2019, 01:40 PM
5w30 is pretty liquid and gets moving within a few seconds of start-up. When it has been really cold here, there have been some times where I've been driving for quite a while, and my temps are still hovering in the 150-60 range, just because of ambient. The engine is plenty warmed up at that point, so I'd hate to not be making the power I could be making just because of 10 degrees.
Default 03-15-2019, 01:50 PM
There is a FUD option to disable the warmup safety if you're so inclined, fud.2 on. Looks like min setting for adding boost is set for 160f currently.
Car: Honda C-RV
Default 03-15-2019, 05:51 PM
didn't do wot but better than nothing
HouseN54's Avatar
HouseN54 HouseN54 is offline
Default 03-15-2019, 06:08 PM
Should be 0w-20 not 5w-30.
| ProCharged C6 Z06 | Civic-X Si | F30 330i |
Car: Honda C-RV
Default 03-15-2019, 06:26 PM
Depends on temp, in hot climates 5w-30 is fine, or if your running hard alot 10w-30 if its warm, in latin america and Australia 5w-30 and 10w-30 are the recommended oils. nothing thicker than a 30 tho
Odinist's Avatar
Car: 2018 Civic Si
Default 03-15-2019, 06:41 PM
You're fully correct; just not used to typing a "0" for oil so I second guessed myself, haha.
(For the record I'm past my first oil change, which I did myself, and I am indeed running 0 weight.)
Odinist's Avatar
Car: 2018 Civic Si
Default 03-15-2019, 06:45 PM
I don't want to fully turn it off, but if it's set to 160 instead of the 170 stated in the OP, then you can disregard my request, haha. :D
Also, while we're talking about the FUDs, can you explain a bit more about 7? Like, for instance, on the nights that I happen to run Mexico Map Siete, will it benefit me to have the more aggressive mapping turned on? I need to know by tomorrow. For science. ;-)
Default 03-15-2019, 08:19 PM
It's actually set to 160f.
The pedal mapping would only effect low pedal input, like half throttle. Not an issue for racing with gas pedal fully pushed. But some prefer a non-linear pedal input and that gives those who do the option.
gadgtfreek gadgtfreek is offline
Car: 2018 Honda Accord Sport 1.5T
Default 03-17-2019, 07:30 AM
Just ordered one with the BT kit for my 1.5T Accord. Can't wait!
2018 Honda Accord 1.5T CVT
PRL Stage 1 Intake
BMS JB4
Enkei TFR Wheels
Default 03-17-2019, 10:39 AM
Awesome! You're going to love it.
Default 03-17-2019, 01:05 PM
Ive been running 93 since I got the car and prob won’t go over stage 1. Do you guys want logs? Only aftermarket part is a stage 1 intake from PRL.
PRL Stage 1 Intake
BMS JB4
Enkei TFR Wheels
