(#176)
Odinist's Avatar
Odinist Odinist is offline
Car: 2018 Civic Si
Default 02-22-2019, 12:34 PM
We have a local Si we'll be dyno testing in a week or two, to better evaluate the differences.
Hell yeah! I can't wait to see the numbers you hit!
Mishimoto intake, resonator delete, Vibrant 1040 muffler, JB4 tuner, Firehawk Indy 500 rubber, Lamin-X fog light covers, Xentec 35w 6000k HIDs, custom d20 shift knob, 20% tint, red "H" badges.
Odinist's Avatar
Car: 2018 Civic Si
Default 02-23-2019, 12:00 PM
Originally Posted by Odinist
Perhaps I need to wrap the MAF housing itself with some gold tape to further help intake temps.
Pure speculation, but I just had a thought... since these cars use a reciprocating bypass valve instead of a VTA BOV, could the air that's been heated by the turbo but then gets shot back into the intake between shifts cause the MAF to get hot?
If this is the case, then I'd have no idea how to combat it. Of course, an intercooler upgrade would help. You'd think a VTA BOV would too, but of course that's a bad mod since we're MAF and venting metered air results in rich conditions.
Default 02-23-2019, 05:30 PM
Couple logs from our CVT today on E30. Map5 and Map7.
Default 02-24-2019, 10:11 AM
New personal best this morning, 102mph traps!
Accurus Accurus is offline
Car: Honda C-RV
Default 02-27-2019, 10:15 AM
Ok now your just showing off.
question regarding firmware 5, I got the longer cable, it reaches but I don't like how it routes over the top of the engine so this weekend when I get more time I'll try going through a grommet to see if it routes better, with out the cable in would maps 1 and 2 still work with out changing the user settings?
Default 02-27-2019, 10:40 AM
Yes they will work without OBDII just not as smoothly as CANbus allows.
Benji@NGP Benji@NGP is offline
Car: 2019 Honda Civic Type R, 1991 Nissan GTR
Default 03-01-2019, 08:47 AM
Was able to hit the dyno today with a 2018 Honda Civic TypeR for a little JB4 tuning. Test car is 100% stock with around 12k miles on it. Running 91 octane pump gas.
After a lot of tuning the best results were found running around 4psi over stock down low and around 3psi over stock up top. Gains on map1 were around 30whp and 50wtq.
We played around with higher boost levels and while power went up a bit the data showed the engine wasn't as happy. Next time we'll try with some better fans and maybe an intake on it to see if we can push power up. But overall happy with the gains. Car feels like a rocket compared to our Civic Sport CVT.
We've split apart the JB4 firmware for the typeR and I'll be posting that separately in the first post shortly along with a typeR specific map guide.
I am very interested in trying this on my personal vehicle 2019 Type R. Pairing this with an intercooler would be great. Maybe I will do some dyno's as well.
Default 03-01-2019, 09:29 AM
We've got them in stock and on our both our retail and dealer websites.
Default 03-01-2019, 11:11 AM
Christine just helped me out. I will do some real world reviews for you guys.
Default 03-01-2019, 11:35 AM
Appreciate it!
Odinist's Avatar
Car: 2018 Civic Si
Default 03-03-2019, 12:37 PM
40-90 pull from last night. Map 7, E30 blend. I've been dailying Map 5 for a while now, but threw it up to 7 for this run. Everything looking okay?
BTW, what's the scaling for the trims column?
Default 03-03-2019, 02:00 PM
Looks good to me!
Both short and long term trims are scaled: 25 = 0%, 50 = +33%, 0 = -33%.
Just got in our "stock calibration" BMS MAF housing and will be testing that next week. Assuming it goes to plan then we'll cut the Si versions of it. And finally get back on the dyno with an Si.
HouseN54's Avatar
HouseN54 HouseN54 is offline
Default 03-03-2019, 06:12 PM
Looks good to me!
Canít wait to buy that Si intake!!!
| ProCharged C6 Z06 | Civic-X Si | F30 330i |
Lcwai Lcwai is offline
Car: Mini jcw f56
Default 03-04-2019, 05:02 AM
hi bro
pls help to view check my car log
( honda civic type r 2018 )
- intake
- intercooler injen
- supercircuit down pipe
jgklim's Avatar
jgklim jgklim is offline
Car: 2018 Honda Civic Sport
Default 03-04-2019, 08:31 AM
Originally Posted by Lcwai
hi bro
- intake
- intercooler injen
You may want to upload the csv file from the JB4. I'd be interested in your LTFT, (trims2)
Car: Mini jcw f56
Default 03-04-2019, 08:46 AM
Here bro
Odinist's Avatar
Car: 2018 Civic Si
Default 03-04-2019, 10:16 AM
So my LTFT is sitting at about a 17 then... Most likely because of my intake, I'm sure. Can this be tuned for?
Default 03-04-2019, 04:53 PM
From the E85 likely.
As long as it's not running off the scale there is no effect or cause for concern with the trims. Once you run off the scale air/fuel can be effected than then it would have to be evaluated.
Default 03-04-2019, 04:54 PM
hi bro
- intake
- intercooler injen
Looks clean to me for map1. You can give map2 a try for kicks.
Odinist's Avatar
Car: 2018 Civic Si
Default 03-04-2019, 05:08 PM
I didn't even consider the E85; that would absolutely make it add fuel, since it doesn't have the same energy potential. Good call dude.
Default 03-08-2019, 03:14 PM
Quick JB4 map1 run this am on a local customers Si, testing out our stock calibration BMS MAF housing. Trims are about perfect. 25 is the zero point. Long term -1%, short term +4%. During cruise they both hover around 0%/0%.
Will get this car back next week for dyno testing!
Odinist's Avatar
Car: 2018 Civic Si
Default 03-09-2019, 08:08 AM
Awesome!!
Default 03-11-2019, 12:02 PM
Video and lots from today's dyno fun.
Odinist's Avatar
Car: 2018 Civic Si
Default 03-11-2019, 12:11 PM
This is awesome!!!
Any plans on some Map 7 dyno runs? I'm curious to know what kinda power that makes.
Good to know what my daily map is giving me, though!
Default 03-11-2019, 02:23 PM
Didn't get a chance to try higher boost levels on this one today, maybe down the road. Owner is happy with ~240whp.
