CPTN 510 CPTN 510 is offline
Car: e90
Default Log check - 10-18-2017, 04:33 PM
Anything look out of order? Car used to spool 18-19 pounds easy. Now, even the 13psi is taking way past 4k rpm to get to.
07 e90, ***, inlets, fmic, jb4 + mhd,
Default 10-18-2017, 08:43 PM
Pretty under target- boost leak?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: e90
Default 10-18-2017, 08:50 PM
smoke tested 3 different times, er chargepipe, no oily residue at any joints, no hissing noises. weak turbos? they might be original, 142k on car now, had it since 93k. doesnt burn oil, doesnt smoke at idle, in the morning, or wot.
OzBMR OzBMR is offline
Car: BMW M140i
Default 10-19-2017, 12:52 AM
Check wastegate actuator or solenoid?
Australian 2016 M140i LCI Mineral Grey ZF8 Auto
11.51@121.94MPH with 1.77 sec 60ft
MHD 95/102 OTS DME Tune with E30 fuel blend
xHP Gearbox Tune
Default 10-19-2017, 11:52 AM
Smoke test is no good, need to do pressure test at boost pressure (20psi). If that checks out, then I'd move on to hardware.
