Hit Redline Hit Redline is offline
Car: 2012 135i DCT
Default 2012 135 N55 FBO BEF E45 map 7 DynoJet - 06-10-2016, 02:48 PM
Hey Guys,
Thought I would share my dyno results. I am installing a Pure Stg2 and Fuel-it TBI this weekend so I can see what gains the turbo makes.
Also attached is a csv file for review.
N55 135i DCT, Pure Stg 2, JB4 map 7 E50, N54tuning DP, VRSF 7" IC, VRSF CP, AFE sealed intake, Ohlins R&T, Voshlag camber plates, corner balanced, M3 front control arms, M3 FSB, M3 RSB, M3 rear subframe bushings, M3 rear wishbone, RPI quad exhaust, APEX Arc 8 wheels, Fuel-it stg2 LPFP- Fuel lines- E sensor, BMS OCC, Quaife LSD
Pure Turbos's Avatar
Default 06-10-2016, 02:58 PM
Sweet! Contact us if you need any tuning help!
Car: 2012 135i DCT
Default 06-10-2016, 03:36 PM
Great, thanks for the support. Is there an email or # I should call, or just post up on the forum if I need some help over the weekend?
Not sure if I am missing anything but here is what I have planned on the tuning side of things.
install N20 tmap and change settings on JB4
Load Fuel-it TBI BEF
change user adjustments as per N55 Large turbo thread
Run map 1, log and post.
1slowN55 1slowN55 is offline
Default 06-10-2016, 03:52 PM
Jesus those numbers are stupid low
2011 N55 335i E92
PURE STAGE 2 FBO
JB4+BMS MHD BEF E50
FX500 Clutch
Car: 2012 135i DCT
Default 06-10-2016, 04:01 PM
I was a little disappointed myself was hoping for like 370ish and 449.
The dynos where run in 4th gear as I have a DCT trans, is that correct?
houtan houtan is offline
Default 06-10-2016, 04:14 PM
You may have left a little HP on the table using map 7 vice map 6 and targeting 20 ish psi. This is with the stock flash? I wouldn't worry about it much. Seems like the car is running solid, looking forward to your ps2 results.
Weehe Weehe is offline
Default 06-10-2016, 04:24 PM
Agreed, could have made more with map 6 targeting 20psi. But that will all be fixed with the stage 2.
Car: 2011 N55 135DCT
Default 06-10-2016, 05:46 PM
Pure stage 2 is a demon turbo.
Car: 2012 135i DCT
Default 06-10-2016, 06:07 PM
Running BMS E85 BEF
keyap keyap is offline
Car: N55 135i
Default 06-11-2016, 01:28 AM
Good luck - hope it all goes well. I've had the PS2 and fuelling support from Fuelit for around 9 months and the support from both companies has been great. You're going to have some fun
When it's installed, and all dialled in, I wouldn't mind hearing your thoughts on the Quaife. I've still got the OEM diff and am less than happy. Traction control is on in 4th so you can image how anything below reacts. Really wish BMW had installed something better as stock!
[B]
n55e90 n55e90 is offline
Car: 2011 e90 335i
Default 06-11-2016, 02:01 AM
I dynoed 345rwhp with intake dp e50 jb4 on map7 so seems right to me.
suspenceful's Avatar
Car: 2008 BSM 135i
Default 06-11-2016, 08:39 AM
Nice. My buddy just made good numbers after a PURE turbo upgrade on his N55. Made 475whp and 477wtq on 23psi.
CantCatchMe CantCatchMe is offline
Car: '12 335i xDrive E92
Default 06-11-2016, 09:58 AM
That is a good plan. Good luck! Keep us posted with logs in the support section.
Car: N55 135i
Default 06-11-2016, 10:20 AM
May have missed this as only skimmed the thread, but a few thoughts:-
* Pure high flow inlet - are you fitting one. If Y then consider doing it after the turbo's installed. It's not too hard and you can line it up better once everything else is in place. On a side note, the o-rings on the inlet can break easily. If you need replacements they're on mcmaster.com - part no 9262K699
* Are you fitting a DV+ - if yes then make sure it's fitted when the Pure S2 goes on. Its very tricky to fit post PS2 install with no benefit. Also, make sure the fitter knows what spring configuration you want.
* BEF - do you have ATR as this will give you the ability to change scalars etc as per your E %? The BMS and FuelIt BEFs work within a certain E range so it's good to have the option to adjust yourself. If not you'll either need to run at the E range for the BEF or email Steve - I believer he / his tuner can supply tailored maps at a V competitive price.
* What plugs are you running. OEM generally won't handle what you're looking to do. NGK 5992's work well and others have had success with other alternatives too. You'll need to re-gap to around 0.020'' to 0.022'' though.
* Check your AFE sealed intake will fit OK with TBI - the stock airbox won't and has to be modified.
I also noticed in another thread that you mentioned about possibly changing the DP. Not sure of your plans for when but it would be good to do this during the install. It should mean no more work (hopefully therefore no additional cost) and save you a few hours post PS2 install.
Think that should be about it. Feel free to PM me if you need anything as I'm more than happy to share my experience during my PS2 install.
[B]
Bours Bours is offline
Car: 335i x-drive n55 2011
Default 06-11-2016, 10:41 AM
pump , meth or e85 ??
Car: 2012 135i DCT
Default 06-11-2016, 11:42 AM
Wow, Keyap thanks for the tips.
Yes on the inlet and DV valve.
DP being changed at the same time.
BEF just using the posted one in the large turbo thread or the TBI thread. Once I get everything going I hope to work with Steve and team to get me dialed in.
The AFE intake, if I can't make it work I also have a BMS intake so good there.
The plugs I am using are NGK that I got from the BMS website so I will need to check and see which ones they are. The current gapping I am not sure of, I don't remember what we did during the plug change.
My buddy who is doing the install is a BMW tech so the actual install should go pretty smoothly.
Again thanks for those suggestions and I may take you up on the help via PM.
VegasJD's Avatar
VegasJD VegasJD is offline
Car: 2012 bmw 135i
Default 06-11-2016, 12:24 PM
I love mine makes the car a beast when you want it to be enjoy if you got any ?s pm me I'm happy to help
2018 Individual Tanzanite Blue Competition M4
Car: N55 135i
Default 06-12-2016, 01:00 AM
Not a problem
Did you get one of the N54tuning ***?
[B]
Default 06-12-2016, 03:56 AM
can someone tell me how much whp a stock turbo n55 produces when its maxed out ? i mean fbo + meth ? cause 340 is low in my book...
Default 06-12-2016, 04:06 AM
My friend made 363 whp maxed out FBO at 1400m altitude
Default 06-12-2016, 04:16 AM
on pump gas ?
Default 06-12-2016, 04:17 AM
Originally Posted by Bours
on pump gas ?
i thought n55 maxed out on meth were like closer to 400s i had in mind 385 whp
Default 06-12-2016, 04:21 AM
No on meth and e. But it will be over 400whp at coast
Default 06-12-2016, 04:31 AM
looss 30 whp cause of altitude ?
Default 06-12-2016, 04:40 AM
About 35 kw
