(#2401)
Traf Traf is offline
Car: 2009 135i Coupe
Default 04-19-2016, 09:40 AM
Originally Posted by n54wagon
They are married to another VIN. You can recode them pretty easily with proper software or take it to a dealer to have them recode. I just figured since it was so cheap its not a bad thing to have in my toolbox for down the road, especially because I plan on doing a lot more mods to my car over the next 6 months.
Right now I'm on the v5 93 octane stage 1. I don't think I will use another BETA, I will wait until final releases are made. I also plan on getting a custom tune once I finish all of my modding...
Funny i thought once they are programmed with a VIN it is pretty much impossible to reprogram them.
f*** v-bands clamp
HairyWelshSteve HairyWelshSteve is offline
Car: '07 335i MSport Convertible
Default 04-19-2016, 10:49 AM
Originally Posted by BeastMode335i
Problem found..
https://www.youtube.com/watch?v=ig1JAS6R4Ik
Now I'm just trying to figure out if I should just replace the Injector 1 MOSFET, or all 6.. I ordered 6 new coils already and 10 MOSFET chips so I'd have spares, and those along with my MOSFET chips should be here within the next 2-3 days.. Injectors and spark plugs are basically brand new still, so I don't see needing new ones of those..
Didn't watch the vid. Easy to diagnose which mosfet with a multimeter. I DIY'd my change but took me a while and getting a pro to do is for $15 is a good idea.
BeastMode335i's Avatar
BeastMode335i BeastMode335i is offline
Car: 08 E92 335i
Default 04-19-2016, 01:22 PM
Yeah i found out it's injector 1 mosfet.. After speaking with a few people about it, seems like I should replace all 6 while I'm in there to avoid this issue from happening again..
E30t387 E30t387 is offline
Car: 08 535xi sport
Default 04-20-2016, 05:54 PM
I might have skipped over it ,but I think I read it somewhere, but I'll ask to be on the safe side, I have the jb+ in my 535 right now, but just downloaded the MHD app, and ordered the cables. Will I be able to keep the jb+ on the car with a mhd flash?
scratch009 scratch009 is offline
Car: E92 N54
Default 04-21-2016, 06:31 AM
Been running JB4 together with latest MHD BEF (pump). I would like to reflash again with MHD, (same map file) and select the "remove noisy cold start" feature will the flash take 2mins if I pick the same file, or 38mins again?
ThaCuda's Avatar
ThaCuda ThaCuda is offline
Car: 2007 335i
Default 04-21-2016, 07:16 AM
less than 2 mins.
2007 335i 4dr JB4, Hexon RR600, Inlets, 4Bar, Index 12, Boost Concept Pump, DCI, FMIC, ** and full exhaust, Burger Meth, MHD BEF. Auto.
boosting4me boosting4me is offline
Car: 2008 335xi Alpine white Coupe
Default 04-21-2016, 08:23 AM
Forgive me Ive been paging through this thread for a few months now Car is a 2008 335xi auto e92 Ive had jb4 g5 for a while With ********* *** dci stock intercooler and the occasional e28 blend on map 5. I have a few questions
Ive bought the cable couple months ago and it connected to my note 3 etc I recently upgraded my phone to a Samsung s7 Im assuming it will work the same
now is my car i8a0 production date is 11/2007
I downloaded the latest map pack which map do I run Im on stock fuel pump the Jb4_MHD_I8A0s_PUMP ? or the e85
thanks cheers! :D
08_335i 08_335i is offline
Car: 2008 335i
Default 04-21-2016, 10:00 AM
thanks cheers! :D
Pump, e85 maps are for heavier e85 mixes. I would run race with an e28 mix though, runs higher timing values.
Default 04-21-2016, 10:20 AM
Gotcha thats what I figured. So if I did the pump race... and say I was running e28 for jb4 settings for 93 or e85 blend should be 4/2 and what map should be running on jb4 map 5 or disabled ?
ThaCuda's Avatar
Car: 2007 335i
Default 04-21-2016, 10:48 AM
4/2 is so you can use the JB4 in conjunction with BEF. So thats good... setting on map5 is generally a good idea for 93 or e85 mix. Until you get some logs and experience with it.
Default 04-21-2016, 11:05 AM
awesome thanks for the quick responses So I don't really need to have map 5 enabled ? when running e85 ? I just get the safety features and logging im assuming? If im using straight 93 and want to run my blend of e85 do i have to set to map 5
ThaCuda's Avatar
Car: 2007 335i
Default 04-21-2016, 11:19 AM
I'd refer back to Terrys instructions.. Just Log it. Then log some more.
Map 5 is a great idea for only using that low of a mix. Try logging Map 1 if you like.
infinity's Avatar
infinity infinity is offline
metanol pawa!!
Default 04-22-2016, 01:38 AM
How does the - Flash option: MT shift bog fix?
Is it like the NLS? if yes. Can we remove our STEP2 / NLS and enable this option JB4 board flash?
Time is the best teacher
Too bad it kills all its pupils ....
suspenceful's Avatar
Car: 2008 BSM 135i
Default 04-22-2016, 07:40 AM
No, it's supposed to eliminate the annoying power lag between shifts.
I tried it with my JB4 and MHD E85 stacked flash, but it didn't really do anything.
Race8877's Avatar
Race8877 Race8877 is offline
Car: BMW 135I
Default 04-22-2016, 10:20 AM
If I use the Duty Bias on the high rpm such as 70 or 80 , can that help control
boost not dropping below 19 or 20PSI ? Also using map6 .
Eristoff's Avatar
Eristoff Eristoff is offline
Car: BMW e92 335i n54 coupe (2006)
Default 04-22-2016, 04:23 PM
Can we guys without the 4tmap sensor installed still use this updated flash? Since its causin afr to go lean.. would this affect the people without tmap sensor?
E92 335i coupe 10/2006 @ BMS DCI ; JB4 G5 ISO ; AR Design 3" DPs ; APEX EC7 18" wheels ; BMS OCC ; BEF ; MMP inlets & outlets ; RB PCV valve ; Vibrant ressonators
jlcf22 jlcf22 is offline
Default 04-22-2016, 04:45 PM
is there a fix yet for the 2ABD code on 4bar sensor? Im getting the same code with MHD flash only
Default 04-22-2016, 05:39 PM
For those with the 4bar WHO also have 2ABD (which is maybe half?), the fix cured 2ABD but created a side effect on the AFR. If you don't have a 4bar OR have a 4bar and don't have a 2ABD code problem, does not effect you.
Default 04-22-2016, 05:40 PM
When I get some time next week I'll dig in deeper on the technical cause of the 2ABD fault. Oddly only some cars get it. From there a strategy to correct it on both the JB4 and flash map can be determined.
Eristoff's Avatar
Default 04-22-2016, 10:08 PM
Understood thanks Terry
chatz86's Avatar
chatz86 chatz86 is offline
Car: 08 E92 335i N54
Default 04-23-2016, 05:15 AM
Should i hold off from the 4 bar install until its stable? Are there any work arounds?
2008 e92 335i M-Sport|JB4 G5|MHD BMS BEF|BMS DCI|VRSF **|Alpina 7603537|BMS OCC|RB PCV|Stage 2 LPFP|Fuel It! ES-1 fuel lines with Ethanol Sensor and JB4 analyser|MMP Silicone Inlets|4 Bar TMAP|VRSF 7" FMIC
ThaCuda's Avatar
Car: 2007 335i
Default 04-23-2016, 05:30 AM
Id imagine You can pop it in and test with some logging. Set n20 to 2. Like Terry mentioned, only some cars are impacted by this. Mine is one of them, so running just fine with oe tmap for now.
chatz86's Avatar
Default 04-23-2016, 05:36 AM
Mine was one of them too. One of the first few so a replacement sensor was sent out. Thats what i was going to install. Can i ask what exactly your cars symptoms were after the install and removal of 2abd code? My trims would max out and afrs lean out causing hesitations etc. Ill just run oem for now too. Thanks.
dr.george dr.george is offline
Car: 135i 6 speed MT
Default 04-23-2016, 05:53 AM
Has anyone tried Andy Android Emulator for Pc and Mac? For flashing with MHD?
ThaCuda's Avatar
Car: 2007 335i
Default 04-23-2016, 06:09 AM
Same. More throttle meant lean hesitate and misfire from too lean. 2abd. I dont mind waiting for the changes and try it again.
