(#3001)
Aimfor500's Avatar
Aimfor500 Aimfor500 is offline
Car: 2010 BMW 135i
Default 11-09-2016, 03:48 PM
what map should I run?
Mods: Oil Catch Can, DCI, 5" intercooler, vrsf chargepipe, muffler delete
2010 135i . BMS DCI . Deleted Secondary Cats . Deleted Resonator . Dual Turn Downs . VRSF Chargepipe . NGK 5992 Spark Plugs. MHD Stg1+ . RCA Voyager III Tablet . 93oct+E40
Lewis Cosgrove's Avatar
Lewis Cosgrove Lewis Cosgrove is offline
Car: BMW 135i E82 2008
Default How much hp would stage 2+? - 11-14-2016, 05:14 AM
135i N54 08'
Mods:
FMIC
3' ***
BMS DCI
BMS OCC
Secondary low pressure fuel pump 255lph
NGK 1 Step colder NGK spark plugs
Currently mapped 385hp 418tq (99ron UK)
Would the MHD stage2+ push it over 400hp?
Yardkidd87 Yardkidd87 is offline
Car: 2007 335i
Default 11-14-2016, 07:49 AM
It should, spoke with terry after he looked at my log. I switched to the pump map. Now am hitting 20.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 11-14-2016, 09:46 AM
Originally Posted by crazyyardie
Shouldn't a race map target 20 psi. Are u on map 6 or map 7. Looks like a custom map 6 that holds boost. Do you have inlet and oulets ?
With a jb4 on, it's the jb4 that target boost, not the flash.
Stg1+.
Originally Posted by Lewis Cosgrove
135i N54 08'
Mods:
FMIC
3' ***
BMS DCI
BMS OCC
Currently mapped 385hp 418tq (99 octane)
I suppose your 99oct is something lke Shell VPower in Europe, so in fact 99ron. Stage 2+ for 93 oct (98ron) is around 420hp crank.
scratch009 scratch009 is offline
Car: E92 N54
Default 11-15-2016, 06:08 AM
I've tried the stage 2+ for 98ron (with (98RON gas in Europe) and it seems too aggressive for my car, I get too many timing corrections. Lowered it to stage 2. I have access to 102RON but need to drive almost 40km for it (which I do )
E92 N54, DP, FMIC, JB4
amk29467 amk29467 is offline
Car: 2008 BMW 335i
Default 2008 335i Electrical Issues - 11-15-2016, 08:17 AM
I have a BMW 335i (manual) with 133,000 miles.
I recently started having what appear to electrical issues.
1.) When starting the car I get a handful of warning indicator lights that display.
2.) I turn on the heat to defrost the front windshield and the blower does not always appear to be at max power. The rear defroster turns on but does not defrost the rear window.
3.) The clock display is set to --.--.-- or not time has been set.
4.) The Tripdometer resets to 0 every time I start the car.
These are just the issues that I have noticed.
Any thoughts or suggestions?
brainsurgery brainsurgery is offline
Car: BMW E91 LCI 335xi
Default 11-15-2016, 08:29 AM
Your battery is running out.
335i LCI xDrive AT, JB4, ***, Stage1 LPFP, MHD E85 flash.
Car: 2008 BMW 335i
Default 11-15-2016, 08:37 AM
I appreciate the response Brainsurgery.
Do you have any links to documentation that supports this?
Again, I appreciate the quick response.
Default 11-15-2016, 08:50 AM
There's a list of things that won't work if voltage is low enogh and all those things you mentioned are on that list. I hope someone can link that list here.
AndrewA AndrewA is offline
Car: 2007 E90 335i
Default 11-15-2016, 11:57 AM
Any reason why BimmerBoost E85 Backend Flash has a higher timing curve than the MHD E85 Backend Flash?
What will make more power?
TravisWsparks TravisWsparks is offline
Car: 07 335i
Default what map to run - 11-16-2016, 06:24 AM
i have an 07 E90 6 speed with full bolt on plus Vargas turbos. Im currently on jb4 with a BMS pump backend flash on map 2. Can i swap to a E85 bef running about E40? And which map on the JB4 should i be running on?
THE BEAST's Avatar
Car: 2008 E93
Default 11-16-2016, 04:51 PM
Couple quick questions.....on a.t. the kickdown disable option. Does it always disable or in manual mode only ?
THE BEAST's Avatar
Car: 2008 E93
Default 11-16-2016, 04:57 PM
And the burble option.....ive had zero problems but i remember that thread on here....no issues to continue to run it ?
THE BEAST's Avatar
Car: 2008 E93
Default 11-16-2016, 05:04 PM
More timing generally means more power, BUT only if you can achieve it safely. Does no good to target higher timing and have the dme pull timing from low octane and such.
Default 11-17-2016, 12:12 AM
btw, it might be also failing alternator or generator but if you have 8-9 years old battery, I'd start replacing that.
N54QC N54QC is offline
Car: 07 BMW 335i
Default 11-17-2016, 01:42 AM
It's probably your battery getting weak. BMW are programmed to reduce strain on the electrical system when the battery starts to get weak. Similar things were happening to me like blower motor not going max, rear window defroster not working, etc. Replaced battery and all went back to normal.
AbacusRacingN54 AbacusRacingN54 is offline
Car: 07 335i
Default 11-18-2016, 04:36 PM
Do RB turbos count as hybrids? Trying to switch flashes. Thanks
Car: E92 N54
Default 11-21-2016, 08:57 AM
would like to know this also.. I've used it for a little while but turned it off since I was afraid it would stress some components? (although that's not based on any knowledge of my own)
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 11-21-2016, 09:16 AM
you should not really get less timing corrections on stg2 than 2+. Feel free to email me logs.
Maybe because it's targeting less load, so you should compare different cells rather than purely the last column?
There's a hybrid version of the e85 flash map for upgraded turbos. Start with map 2 and post a log in the support section for jb4 advice.
Alsways.
Yes.
Aimfor500's Avatar
Car: 2010 BMW 135i
Default 11-22-2016, 03:34 PM
Has anyone been successful with using MHD on a wireless bluetooth obdII thingy? I tried it and it didn't work.
nyt nyt is offline
Car: 335ix
Default 11-23-2016, 12:37 PM
it's not obd, it's not going to work
2010 335ix - speedtech 6466g2, cams, ported head, built bottom end, 7.5in hd ic, jb4, pi, fuel-it stg3, upgraded 6hp21+cooler, pr coils
Aimfor500's Avatar
Car: 2010 BMW 135i
Default 11-23-2016, 04:08 PM
Ah, I figured since it plugs into the obd port then it would work the same way as just running a bluetooth obd into the port and trying to connect to the monitor module on mhd. Oh well, guess i'll have to relocated the port so the cable isn't in the way when i get in and out of the car.
Alex!'s Avatar
Alex! Alex! is offline
Car: 135 I N54
Default 11-23-2016, 08:41 PM
Hi! Wich flash i have to use for a 1m?
135I - 6 MT -JB4 G5 ISO Map 3 - BB Race Flash - Riss Rasing ******* DP - AFE CAIs - BMS SDL - 93 Octanes - Sistem X wather meth - SPEC 2+ - RB Twins!!
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 11-28-2016, 08:44 AM
It depends on your mods / turbos / fuel and if you want to run flash only or flash + jb4. For a 1M the firmware version is IKM0S if that's your question.
Originally Posted by BoostedSedan
I seem to be over boosting on Map 2 [...]
post in the support section.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 12-02-2016, 02:29 AM
Originally Posted by cloudybimmie
hey guys, am pretty new the MHD game but i gotta say i'm very impressed with the tunes, am pretty familiar with some things like afr ratios, timing, and so far that looks good. i went to a dyno day here around my way and the car made 370ish whp and 420ish TQ... on Friday i tried the e25 mix on the car, and i honestly couldn't see much of a difference from the pump gas, am wondering if i need to do more e85 to actually feel the difference in terms of power?
There is something fishy with the low pressure pump which is way too flat to be 100% honest. Are there codes stored when you read codes with MHD?
