(#2926)
ricpolo69 ricpolo69 is offline
Car: bmw 335i
Default 09-28-2016, 07:51 AM
Good afternoon. I was wondering if you can answer me a question. Im supposing when I see v1,2,6.7 on each map . Im thinking is an improvement. I guess as time goes by ,you guys improve each map for better performances. But when I go to the forums I see people still using v5 maps or v6 map and disscussions on which is better. So my questions is what are the difference on each map and how can I tell which will be better to use. Furthermore , if the newer version is improve then, why do we even have the choice to go back to an older version?
MaxiM MaxiM is offline
Car: 335i e92
Exclamation 09-29-2016, 06:27 AM
Good, I stand with my 335i e92 problem with the MHD flasher.
Today perform for the first time, flash charging stock, and two minutes to lock automatically after I get the error: Could not contact the ECU. Make sure ignition is ON and the OBD cord is plugged.
I removed the battery for 30 minutes, have if was reset and recognized the ECU, but no way still recognize, however the program Carly if it works perfectly with the cable and my mobile.
The phone is a Samsung S4 root, and cable D-Kan Aliexprees.
Any help ?? since the car will not start, commissioning works but does not work.
Thanks in advance, and sorry for my English, I is translated by google from Spanish.
noow noow is offline
Car: 335i e92 n54
Default 10-03-2016, 10:00 AM
https://www.youtube.com/watch?v=_-gz-jXvQko
Same error ? at 3:52
mca312's Avatar
mca312 mca312 is offline
Car: 335is
Default 10-03-2016, 10:08 AM
I went to the track yesterday and my AFR's were between 13 and 14 using the v7.1 stage 2 map
http://***********/u/mca312/log-14754...0&data=4-16-21
335is DCT
DCI, Inlets, 5" IC, DP, MHD
Car: 335i e92
Default 10-04-2016, 04:01 AM
Originally Posted by noow
If it is the same error, but I jump after the connection has been interrupted in the first flashing (long), does not recognize the engine module, the other modules if ...
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-04-2016, 11:40 AM
Originally Posted by DetroitN54
When switching from v6 to v7 maps, do you have to do a full write or just a map flash?
2 min map.
Some v5 maps were more powerful but also used relax knock tables.
V7 maps are more balanced and pleasant to drive. It's a no brainer.
You're entering open loop (STFT pegged at 0) as you shift in 2nd. DME gets back to closed loop at the end of 4th gear, but runs too rich on bank 1 at 10.8. Looks like this is fueling related, in another log I see small AFR drops after shifting. Next time you log add the fuel mode channel and email us.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-05-2016, 02:21 AM
The latest v1.48 update adds a preview of the in app upcoming log viewer! Both MHD and JB4 .csv logs are supported. Graph can be zoomed and panned. Good alternative to datazap on the go.
In the next update numeric values will be displayed, along a default JB4 color scheme, and each channel scale will be customizable.
Default 10-05-2016, 07:07 AM
Nice!
N54 | Build Thread
mca312's Avatar
Car: 335is
Default 10-05-2016, 09:47 AM
Nice job MHD. I like it since I don't have internet on my tablet and don't want to always have to pair with my phone and upload to datazap right away. Thank you for your work
335is DCT
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default v1.49 - 10-07-2016, 06:11 AM
The log viewer receives sooner than expected a vertical ruler and numeric values.
x99percent x99percent is offline
Car: 2008 135i
Default 10-07-2016, 12:47 PM
This version crashes for me as soon as a JB4 log is selected. Tried on two different devices with the same result... Nexus 5X w/ Android 7.0 and Nvidia Shield K1 w/ Android 6.0.1
sparconl sparconl is offline
Default 10-07-2016, 12:50 PM
http://***********/u/sparconl/e92-335...1?log=0&data=1
I'm new to logging and dont quite know how to judge them. So i'm looking for advice on my log.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-07-2016, 01:11 PM
For jb4 tuning tips, post to the support section of this forum. Boost is a bit shaky and AFR is too lean for my taste.
Thanks for the feedback, I submitted a fixed version that will hit the servers in an hour.
JazRedGT JazRedGT is offline
Car: 2007 335i E-92 6AT
Default 10-07-2016, 01:27 PM
Any chance we see an update to the backend flashes? Last update was in June. =-(
2007 AW 335i E-92 6AT MMP Stage 3 @ 25psi / JB4 G5 ISO / XHP STG3 / VRSF D-Ps / MMP INLETS&OUTLETS / WEDGE MHD E50 BACKEND / CW EXHAUST / CPe CP / GReddy RS BOV / BMS METH KIT / WAGNER IC / PR STAGE3 LPFP 10.92 @ 132 1.72 60ft 6.96 @ 103 1.55 60ft
DetroitN54 DetroitN54 is offline
Car: 2009 135i
Default 10-07-2016, 03:53 PM
Was running v7 stage 2+ 93 octane, just switched to 95 octane with 110 race fuel in the gas tank, it seems slower, is the 110 too much for the 95 oct map?
Car: 2008 135i
Default 10-07-2016, 03:56 PM
Thank you, it works great!
Icelandic Icelandic is offline
Car: 2008 335i 6MT
Default 10-07-2016, 06:52 PM
I just flashed a jb4 bef through this great app. I was wondering, are the options (burble, mt bog fix) not active with the jb4 bef license? I tried the burble option with everything at max but didnt notice any difference.
AbacusRacingN54 AbacusRacingN54 is online now
Car: 07 335i
Default Tablet not supported - 10-08-2016, 07:24 AM
Was all set to make the jump from BB and found out my ellipsis tablet that's an Android device isnt compatible.. bummed... I'm also only at version 1.35 where do I update to latest?
ninjacoupe ninjacoupe is offline
Car: 135i..First of the 1
Default 10-08-2016, 07:47 AM
They work fine for me. I use MHD with JB4 backend flash with burble on and off. Currently off. MT bog fix is always on and I never get any shift bog either.
Car: 2008 335i 6MT
Default 10-08-2016, 08:43 PM
Got it working But now Im getting the 2A13 DMTL code! And being a euro model my car doesnt even have a DTML system. Im running the pump jb4 BEF but I thought this Euro/Us conflict had been taken care of?
finnd1's Avatar
finnd1 finnd1 is offline
Car: 2009 e60 n54
Default Trouble finding car version - 10-09-2016, 03:04 PM
Getting hung up on this step.
8- now go into the jb4 phone app and Under the settings tab, read only tab, find the correct version of your car, IJEOS or I8AOS. Write this down for future use in selecting the correct Backend Flash you'll need in the upcoming steps.
It doesn't seem to be showing me my car version. It is a 2009 e60 n54 but the vin indicates it was made late 2008. I don't want to take any chances with flashing the wrong version.
enrita's Avatar
enrita enrita is offline
Default 10-09-2016, 05:34 PM
Best is that you use tunerpro and basically do a compaire of ur stock rom with the modified one and just change whats needed. I can do it for u if u want or search in how to do it. Using a usa based rom can cause high consuptiom
07 335i AT - MOTIV 750 - MHD BMS E85 Flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
LycanX4M40i LycanX4M40i is offline
Registered Users
Car: 14' F25 X3 xDrive28 M-Sport AlpineWhite DHP
Default 10-12-2016, 05:10 PM
Hey guys will there be any support for E84 X1 35i ?
My friend is on Pure Stage2 Turbo, FBO, + JB4 w/ Port Injection and desperately needs a BEF to open up some torque limiters among other things
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-14-2016, 02:47 AM
Too much octane doesn't hurst, but leaded fuel hurst your lamda sensors.
Active or shadow code?
There are a couple of maps (I8A0S based I think) where Terry hasn't disabled 2a13 yet (the old XDFs didn't have it). That can be done in tuner pro.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-14-2016, 02:50 AM
Don't worry. Go flash a IJE0S map. If your car has MSD80 and require I8A0S, MHD will refuse to flash the IJE0S map.
MHD N55 open beta is 2 weeks away.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Mon54ster
