(#4376)
UNEEK UNEEK is offline
Not a Racer
Default 07-01-2019, 09:39 AM
JB4_VR30_7.hex is the most recent file.. but to confirm, do you have a JB1 or JB4? This are JB4 files
I have a JB4, thank you for confirming
Also on the saving part, do you just click on Disconnect or Quit?
2019 Infiniti Q50 S
Car: q50
Default 07-01-2019, 10:39 AM
got any time to teach me how to read logs? A high level 101 is all I need
Terry know the most, I've just picked up queues from him about this specific platform and I added it to my tuning experience over the last decade or so on other platforms. If you look at the picture I made the comment about to Terry, you'll see that in the 1st 3 gears the timing continues jumping up through out the gear. But in 4th gear, it looks like it keeps getting pulled back down when it would otherwise increase. To me that seems like it's either picking up knock or something else is happening. Since BMS hasn't found the knock counts PID yet, the timing graph is the only thing we have to go off of. Whenever timing drops to 5 degrees or less, or is jagged back and forth, that says to me you're running too much boost or not enough octane and should back it down.
jrobohm's Avatar
jrobohm jrobohm is offline
Default 07-01-2019, 10:57 AM
Originally Posted by RandyNester
I think this was the 4th gear pull.
Big boost number 19+ - you have fuel wires installed? Any reason why you donít have them turned on? (Log shows FUD = 0)
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HE w/ Aux Tank
  • AMS LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
  • Mishimoto Oil Catch Can
Car: q50
Default 07-01-2019, 12:14 PM
Terry, my jb4 won't connect via Bluetooth anymore. I've tried troubleshooting it several different ways. Pretty sure I need to send it back. Can you help?
Car: 2018 Q60 3.0
Default 07-01-2019, 12:48 PM
How do you turn them on?
2019 Q50 Red Sport
Burger JB4
Burger Cold Air Intake
Burger Fuel Wires
Burger Elite Heat Exchanger
Megan LDP
Santeen Santeen is offline
Car: 2018 Infiniti Q50
Default 07-01-2019, 03:47 PM
Seems OK but it's over-revving a bit. Are you letting it shift itself?
I was using the paddle shifter and it accidentally over revved a couple times
Car: Red Sport 400
Default 07-01-2019, 04:14 PM
Can someone look at this short Map 2 log? I was going to go for a 1st-3rd gear pull/log and the car struggled in first so I decided to just back off of it. Felt like car was not building boost at all until closer to 5000rpm
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
12.19 @ 115.87 on 93 (Map 6)
Dc5guychillin Dc5guychillin is offline
Car: Infiniti Q50s
Default 07-01-2019, 07:47 PM
Terry, Just added lower *********, could you take a look...
Car: Infiniti Q50s
Default 07-01-2019, 07:48 PM
Terry, just added lower do...could you take a look?
Default 07-01-2019, 09:43 PM
Makes sense. I'd just let it shift itself most of the time.
Default 07-01-2019, 09:44 PM
It's not but I'm not sure why, DSC kicking in maybe?
Default 07-01-2019, 09:45 PM
Grab a longer run with more full throttle!
boostfeen boostfeen is offline
Car: Q50 RS400
Default 07-02-2019, 05:56 AM
Terry,
help please... my buddy gave me his JB1 but car has no throttle response after installing. Verified same issue on another car, any help is appreciated
jrobohm's Avatar
Default 07-02-2019, 05:57 AM
Check the first post of this forum for details - I use the JB4 iPhone app / BT Kit to make changes to my JB4. In the JB4 app it is in Settings - User Adjustment Settings. Scroll half way down and you will see a section that reads Future Use: You want to select Future Use D - this will bring up another screen titled FUD Options. If the value is 0 - then you have to turn on Bit0. This will make the value = 1 (Fuel Wires are enabled.) Be sure to his SAVE to exit out.
Take another run and look at the log at the top - your want to look at the CSV log file and at the top - mid way left to right - there is a column that has MethSafeMode under that there should be a value of 0. Under that is FUD - under it you want a value of 1 (Fuel Wires Enabled.)
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
Car: 2018 Q60 3.0
Default 07-02-2019, 06:27 AM
Your thoughts on this 3-4 gear pull?
2019 Q50 Red Sport
Burger JB4
Burger Fuel Wires
Megan LDP
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 07-02-2019, 07:53 AM
I have the bluetooth interface, I never use either option. I just turn the car off
2019 Q50 Luxe RWD *JB4 with Fuel Wires*BMS Intakes*AMS Downers*Frozen Boost 101*Megan Y Pipe
12.68 @113mph @2700 DA, 38% humidity, terrible tires
0-60 4.48
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 07-02-2019, 07:56 AM
Still offline?
0-60 4.48
Car: 2018 Q60 3.0
Default 07-03-2019, 08:05 AM
Terry, your thoughts? I like it.
2019 Q50 Red Sport
Burger JB4
Burger Fuel Wires
Megan LDP
jrobohm's Avatar
Default 07-03-2019, 08:28 AM
What fuel are you running ?
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 07-03-2019, 08:50 AM
Are you trying to cook your turbos at this point? It's been stated more than a few times that an RS should not go past +5 at most after you posted
1500 3.5
2000 4.0
2500 4.5
3000 5.0
3500 5.5
4000 6.0
4500 6.5
5000 7.0
5500 7.0
6000 7.0
6500 6.5
7000 6.0
Runs like a bat outta hell.
So the fact that you are still above 5 must mean you are trying to get outta that car, or cook the turbos to justify an upgrade?
0-60 4.48
Car: 2018 Q60 3.0
Default 07-03-2019, 09:07 AM
Can you give a suggestion as to where boost should top out?
2019 Q50 Red Sport
Burger JB4
Burger Fuel Wires
Megan LDP
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 07-03-2019, 09:14 AM
1500 2.0
2000 2.5
2500 2.5
3000 3.0
3500 4.5
4000 4.5
4500 4.5
5000 4.5
5500 4.5
6000 3.0
6500 2.0
7000 1.0
Run this map since you don't appear to have a catback, therefore you have airflow restrictions after the *********. If you ever get a catback, you could dial each number up by .5
Also look into the WMI kit if you're not planning a catback and still want to obtain more power, and the Flex-It fuel kit
0-60 4.48
Car: 2018 Q60 3.0
Default 07-03-2019, 09:17 AM
1500 2.0
2000 2.5
2500 2.5
3000 3.0
3500 4.5
4000 4.5
4500 4.5
5000 4.5
5500 4.5
6000 3.0
6500 2.0
7000 1.0
Got it...I'll give that try!
2019 Q50 Red Sport
Burger JB4
Burger Fuel Wires
Megan LDP
Car: Red Sport 400
Default 07-03-2019, 09:24 AM
Here's Stillen's recommendation long read but very informative
TO INFINITI BEYOND - ANALYZING THE VR30DDTT TURBOS | STILLEN Garage
Tuning:
While there is still a lot of exploring to do when it comes to tuning, there are several things we can see just by looking at the turbo map and dyno sheets. Your biggest gains will all be in the mid-range (2500-5000 RPM) with the stock turbos.
Based on the turbo map, tuning to 18 PSI from 4000-5000 RPM puts you in a very ideal efficiency range for the turbos. Now dropping the boost after 5000 RPM is important as holding too much boost is not ideal for the motor or turbos, but also wonít gain much additional power. This fine tuning of boost pressure adjustment is made easier by the factory electronically controlled wastegate actuators.
That being said, I believe the JB4's that have dipped into 11's are running more than +5, some as high as +7 in mid range but tapering off aggressively
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
Car: Red Sport 400
Default 07-03-2019, 09:39 AM
From my very very limited experience with JB4 lol, other than pushing turbo's beyond recommended limit, this looks clean. what fuel are you on?
We basically have the same mods and im on 93 and I noticed my car's logs are much cleaner consistentlyif i go +3.5 max throughout 1500-7000. I've ran Map 2/Map 6 with +4,,+4.5,+5 tapered and while there were clean runs, the clean runs weren't as consistent.
Megan LDP's being installed today, a member suggested its better to let the turbo's breathe better than up the boost past it's efficiency zone which makes sense to me
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
